14 registered members (Tally Ho, IcePack, Ray, Bitsobrits, SDJ, SFG, Robbie, Neptune, Heinz, aerotaff, M3W55, LightSpeed, rockabilly john, Island Mog),
160
guests, and 20
spiders. |
Topics40,357
Posts672,576
Members7,346
Most Online1,033 Dec 28th, 2019
Pulling bearings from hubs
#674593
25/11/20 04:04 AM
25/11/20 04:04 AM
Posts: 109 Amberley, OH, USA
NelsonG
Amberley, OH, USA
Hi all,
Any advice on pulling outer bearing races from the hubs? The outer inner bearing came out easy. The oil seal too, then the inner bearing lifts right out. But both outer races are stuck in the hubs. Should I try and whack them out (gently of course), with a drift, or is one of those blind hole pullers is the way to go?
-Nelson ‘66 plus 4 2-seater
- Nelson
1966 Plus 4 RHD
Re: Pulling bearings from hubs
[Re: NelsonG]
#674597
25/11/20 06:54 AM
25/11/20 06:54 AM
Posts: 842 UK
BuyBritish
UK
I use one of these to push out evenly dont use a drift or if you damage the hubs..... You may need an attachment to the end of the rod to fit the bearing Untitledpress by Robert & Ali Davies, on Flickr
Rob Davies Morgan 3 Wheeler 1934 MX Morgan Series 1 1947 Morgan +4 1956 TR4 Morgan +4 2000 T16 Rov
[Re: NelsonG]
#674604
25/11/20 08:24 AM
25/11/20 08:24 AM
Posts: 397 Lincolnshire
Guten
Lincolnshire
I’d use a brass dolly that way no damage. Regards Simon
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon Mercedes C Class estate Honda Jazz
[Re: NelsonG]
#674613
25/11/20 09:09 AM
25/11/20 09:09 AM
Posts: 3,128 Solihull
Spanner Juggler
Solihull
Nelson
If you do choose to buy a bench press you won’t believe how useful they are. Not crazy expensive, a basic one is a few hundred dollars and it’s not just bearings that they can be used for.
King pin bushes pressed in and out, all sorts of assembly work, holding small parts for drilling (how many times have you needed 3 hands?) I even used mine to bend sheet steel and metal strip. I had hear of MogBoxes coming detached so fabricated a safety clamp using the bench press.
One of those things that have you wondering how you ever managed without one.
BR Colin (Guys need ‘stuff’)
[Re: NelsonG]
#674682
25/11/20 04:36 PM
25/11/20 04:36 PM
Posts: 7,584 Llanelli
sospan
Llanelli
If I had room I would get a press. Changing front discs last year....stuck onto the hubs. A press would have made that job easier! It would double up as a fruit press too. Mmmmmmm home brewed cider.
Red Plus8
[Re: NelsonG]
#674693
25/11/20 04:59 PM
25/11/20 04:59 PM
Posts: 411 Lancaster
Phil Bleazey
Lancaster
This is for races which are impossible to remove any other way and it needs to be done with care and safety glasses! Run a weld round the inside of the race about middle of the width. When the weld cools the race will fall out. Bear this in mind when thinking of the stresses set up by welding chassis tubes like the M3W ones!
[Re: NelsonG]
#675886
03/12/20 02:30 AM
03/12/20 02:30 AM
NelsonG
Amberley, OH, USA
Great advice all. For those that use the press, it’s not a straight shot down at the bearing. How can you push them out with a straight press?
I did manage to get them out safely with a drift. But you really must angle the thing to get good purchase on the bearing race lip.
- Nelson
1966 Plus 4 RHD
