15 registered members (SeaTacTom, Dougie, Laurens, Moggo, JohnMat, +8Rich, Neptune, StevieMac, Steve +8, ChrisConvertible, MJF, Ian Wegg, BobtheTrain, HJF, brownbaker), 138 guests, and 16 spiders.
+8Rich 384
John V6 301
Alistair 167
Peter J 139
Some very expensive Morgans
by JohnMat. 27/01/21 10:23 PM
Lockdown project
by BillMiller. 27/01/21 07:45 PM
nouveau membre Sud-ouest France
by Déo47. 27/01/21 05:49 PM
DeLorean: Documentary
by Fuel.inj. 27/01/21 04:53 PM
LED H4 Bulbs
by John V6. 27/01/21 12:35 PM
97 +4 boss
by John V6. 27/01/21 12:22 PM
HomerS drives a MTW
by CooperMan. 27/01/21 11:50 AM
Another High Level brake light
Morgan puzzle made to order
TOK 258 drawings
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
bear65, Mogster +4, JimV6, IainG, Ollie
7346 Registered Users
Topics40,357
Posts672,575
Members7,346
Most Online1,033
Dec 28th, 2019
No Birthdays
Problem with key #674658
25/11/20 02:37 PM
25/11/20 02:37 PM
Scottish Highlands
Morgan110 Offline OP
Scottish Highlands
Just to ask a question.
I have a plus 4 when I turn the key to start it some times nothing happens and then turn it again and it fires up.
Not sure if this is normal or not.
Thanks for any info
Ian
Ian
Morgan Plus 4. 110 Anniversary
Volvo S60. R Design t5 2020 70 reg
Re: Problem with key [Re: Morgan110] #674660
25/11/20 02:51 PM
25/11/20 02:51 PM
Derby
PhilRoyle Offline
PhilRoyle  Offline
Derby
Do you leave a few seconds for everything to switch on before firing up the starter motor?
I get in the car, turn the key for the electrics then fasten the seatbelt & check mirrors before starting the engine. It works for me.
Re: Problem with key [Re: Morgan110] #674671
25/11/20 04:18 PM
25/11/20 04:18 PM
Thatcham
Tresco Offline
Tresco  Offline
Thatcham
Yes I can confirm mine does that on occasions. I do normally wait a bit as Phil said so not sure if it happens when I get inpatient and don’t wait.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
Re: Problem with key [Re: Morgan110] #674676
25/11/20 04:30 PM
25/11/20 04:30 PM
Solihull
Spanner Juggler Offline
Solihull
I have had 2 +4’s with an immobiliser (both 2008 cars) and this was a regular issue. Someone mentioned to use the model ignition on, wait for all the whirring and clicking to stop as the car sets itself, by then the codes will be exchanged with the key transponder and the car will start.
Never had it happen again after I gave it the few seconds time to ‘set up’.
My current 2012 4/4 is the same.
BR
Colin
BR Colin
Re: Problem with key [Re: Morgan110] #674677
25/11/20 04:33 PM
25/11/20 04:33 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
Another possibility could be the battery in the key. I think there are also posts from a while back about the sensors in the key and ignition failing to “speak” to each other. People have posted about the problem in the past.
Red Plus8
Re: Problem with key [Re: Morgan110] #674696
25/11/20 05:04 PM
25/11/20 05:04 PM
Cornwall
griffo Offline
griffo  Offline
Cornwall
There are no batteries in the key but there is a chip which should be detected by a transponder in the ignition switch. Sometimes it fails to work and sometimes the tiny chip falls out of the hole in the key. So best to always carry a spare key otherwise (usually in the French Alps in my experience) one can be stranded. A good key cutter these days can copy the chip and make a spare key with the correct chip in it.
Re: Problem with key [Re: Morgan110] #674708
25/11/20 05:58 PM
25/11/20 05:58 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
IIRC there is a thread on here about the detector for the transponder chip being known to move.
Edit - found it:
DaveW Woskshop Note on Transponder Issue
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: Problem with key [Re: Morgan110] #674713
25/11/20 06:02 PM
25/11/20 06:02 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Yes, I think Dave W is the expert on curing this
