19 registered members (pandy, JMcL, DCH, R1NGA, Berlin, Image, Frank K, M3W55, TBM, DavidR, jaypee, Mike D, Bourbonmog, ajsms999, Robbie, planenut, donaldosaurus, Hamwich, PaulyG), 140 guests, and 16 spiders.
+8Rich 387
John V6 301
Alistair 172
Peter J 132
Wanted M3W car cover
by donaldosaurus. 28/01/21 04:05 PM
Replacement door hinge fasteners
by JimV6. 28/01/21 02:32 PM
Fancy the other half?
by M3W55. 28/01/21 02:05 PM
Classic Engines: Briggs and Stratton
by Hamwich. 28/01/21 12:44 PM
Before I bought my first Morgan...........
by DaveW. 28/01/21 12:11 PM
Fuel pump problem
by jaypee. 28/01/21 09:05 AM
Some very expensive Morgans
by JohnMat. 27/01/21 10:23 PM
Another High Level brake light
Morgan puzzle made to order
TOK 258 drawings
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
bear65, Mogster +4, JimV6, IainG, Ollie
7346 Registered Users
Topics40,364
Posts672,710
Members7,346
Most Online1,033
Dec 28th, 2019
Hiwex
Brake Disc Removal #674740
25/11/20 08:43 PM
25/11/20 08:43 PM
Staffordshire
IvorMog Offline OP
IvorMog  Offline OP
Staffordshire
Sometime in the not too distant future I'm going to be changing my brake discs.
A while back when I had the hubs off I did try a half hearted attempt to separate the hub and the disc but they were seized solid and as I didn't need to get it done for the job I was doing I left them as a job to be done later.
Well later has arrived.
Will penetrant be enough to get the job done and if so what does the team consider to be the best penetrant.
I would prefer to avoid using too much heat so it doesn't damage the grease seals as I changed them a year ago.
Is this an excuse to buy a small bench press as an essential item?
Thoughts please?
Bob
1999 4/4 2 litre Zetec
Re: Brake Disc Removal [Re: IvorMog] #674741
25/11/20 08:54 PM
25/11/20 08:54 PM
Gloucestershire, UK
Hamwich Online content
Hamwich  Online Content
Gloucestershire, UK
I would use PlusGas, that's been the best in my experience. Rather than using heat, if you can get the hub secure in a vice you could use a brass drift to apply a bit of shock to free the discs. It's many years since I did mine but I think I might have used an old screwdriver as a wedge to get between disc and mount.
You won't need me to tell you to spend a lot of care to make sure the new discs are truly bedded square with the hub, even a fraction of runout will cause horrible pulsing in the brake pedal.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: Brake Disc Removal [Re: IvorMog] #674751
25/11/20 11:58 PM
25/11/20 11:58 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
I did mine last year. Standard solid discs replacement with HiSpec callipers and stainless flexi hoses. I had discs ready and bought the rest from Mulfab. I didn’t go with vented discs as the standard ones are more than good enough for road use. The new flexi hoses are an improvement.
My discs were stuck solid. Rust. The mating area with the hub. I took the hubs off to split the discs off.
I soaked them with Plusgas, leaving them overnight. If only I had a press! They were persuaded off with repeated tapping with a drift. The hub bearings were protected.
When you do yours clean the mating surfaces before refitting, the hub mainly as the disc will be new. I also put some copper grease on the mating surfaces, very light brushing on. As mentioned, make sure the disc is located on the hun squarely. A final clean with sprayed on brake cleaner.
I finished the job by replacing the brake fluid as well. An Eazibleed made that easier.
Red Plus8
Re: Brake Disc Removal [Re: IvorMog] #684071
19/01/21 05:28 PM
19/01/21 05:28 PM
Staffordshire
IvorMog Offline OP
IvorMog  Offline OP
Staffordshire
Finally got round to replacing the discs.
Good soaking with Plusgas and a little "gentle" help from my trusty brass drift separated the disc and hub reasonably easily.
Cleaned everything thoroughly, especially the mating faces and I'm very pleased to say I only have .03 / .04 mm runout TIR. Or less than 2 thou in old money.
I'm going to try Mintex 1144 pads after a chat with Cain. Hope they're no too dusty.
Bob
Re: Brake Disc Removal [Re: IvorMog] #684079
19/01/21 05:55 PM
19/01/21 05:55 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Bob, whilst on the subject of Mintex their Ceratec anti-seize/squeal grease is better than copper slip
Re: Brake Disc Removal [Re: IvorMog] #684100
19/01/21 07:44 PM
19/01/21 07:44 PM
SimonH Offline
SimonH  Offline
I think I’ve got a set on the shelf
Make sure you bed them properly or else they are squeaky as hell at low speed
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: Brake Disc Removal [Re: IvorMog] #684101
19/01/21 07:55 PM
19/01/21 07:55 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
As I may need to change pads later in the year, be really pleased to hear how you get on with these. Although Simon has often recommended them as a good pad, I see also his advice above to avoid the squeaks.
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: Brake Disc Removal [Re: IvorMog] #684104
19/01/21 08:10 PM
19/01/21 08:10 PM
Solihull
Spanner Juggler Offline
Solihull
If it’s a one off light press job you can sometimes use a trolley/bottle/screw jack and a couple of wood blocks, then a length of stout timber in the garage door frame.
It’s only normally a very light load to separate them but if tight a light press and a tap with a brass drift works wonders.
BR
Colin
BR Colin
Re: Brake Disc Removal [Re: IvorMog] #684105
19/01/21 08:12 PM
19/01/21 08:12 PM
Staffordshire
IvorMog Offline OP
IvorMog  Offline OP
Staffordshire
Mintex do seem to be quite specific about bedding in their "racing" pads.
Varies a bit depending on which compound, the 1144 being the least racey and therefore bed in with lighter applications and speeds.
On the 1144 they recommend 3 or 4 light applications from 30 to 0 then 6 or 7 medium applications from 70 to 30.
Must make sure my rear view mirror is well adjusted.
Bob
Re: Brake Disc Removal [Re: CooperMan] #684142
20/01/21 07:32 AM
20/01/21 07:32 AM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
I was both surprised and pleased that our local old school village mechanic approaching retirement was aware of the negatives of using Copperslip and used the correct stuff when replacing pads on our Mini recently.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
