12 registered members (Scrambledsignals, Barry M, +8Rich, bmgermany, Taffmog, DJC, IcePack, BobtheTrain, James B W, Heinz, TBM, Treesurveyor),
211
guests, and 20
spiders. |
Rad Work
by Treesurveyor. 25/01/21 06:05 PM
Topics40,343
Posts672,237
Members7,346
Most Online1,033 Dec 28th, 2019
Re: wire for third brake light
[Re: Hogzilla]
#674930
27/11/20 08:15 AM
27/11/20 08:15 AM
Posts: 3,424 East Harling, Norfolk UK
If its a factory item, I would be very surprised if it doesn't have a lead long enough, terminating in an AMP Econoseal two way plug, to reach matching socket on loom.
ETA: you may have to assemble the supplied connector after fitting lamp to car.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1960 Velocette Venom
[Re: Hogzilla]
#674938
27/11/20 08:56 AM
27/11/20 08:56 AM
Whoops  , just spotted your picture Andy on OP's previous thread. If the loom socket doesn't have enough spare cable wrapped away to reach, I would be tempted to obtain fresh female pins and extend the cables to loom socket to reach the plug on lamp. AMP Econoseal connectors are readily available on eBay. ETA: Loom schematic does show only 15cm at best on that portion of loom eminating from convoluted cover
[Re: RichardV6]
#675108
28/11/20 12:39 AM
28/11/20 12:39 AM
Hogzilla
Whoops  , just spotted your picture Andy on OP's previous thread. If the loom socket doesn't have enough spare cable wrapped away to reach, I would be tempted to obtain fresh female pins and extend the cables to loom socket to reach the plug on lamp. AMP Econoseal connectors are readily available on eBay. ETA: Loom schematic does show only 15cm at best on that portion of loom eminating from convoluted cover  When this light made of "gold" arrives, I will cut into the loom and see if the wire is long enough to reach. I am hoping it is just wrapped up in there.
[Re: Hogzilla]
#675114
28/11/20 02:12 AM
28/11/20 02:12 AM
Posts: 2,900 Port Orchard, WA.
LightSpeed
Port Orchard, WA.
They way I did it cost very little and I documented it in this web site.
Stephen 2019 M3W, AR Stage 2
