11 registered members (+8Rich, Bishmog, SFO, JMT, Barry M, bmgermany, RedThree, pandy, Alistair, bear65, AndyN),
110
guests, and 17
spiders. |
Rad Work
by Treesurveyor. 25/01/21 06:05 PM
Topics40,343
Posts672,244
Members7,346
Most Online1,033 Dec 28th, 2019
1997 Plus 8 tickover
#675184
28/11/20 04:22 PM
28/11/20 04:22 PM
Posts: 36 Cumbria
Phil+8
Cumbria
Hi, When I first bought my 1997 Plus 8 in August, the tickover was very erratic and would quite often just cut out. Sometimes hunting or over revving first. I changed the stepper motor, HT leads and distributor cap, and Matt at Lifes Motors tried a different MAF sensor and ECU that he had on the shelf. Nothing seemed to make much difference until we changed the temperature sensor and Lambda sensors. Coincidentally, I fitted Librands manifolds this week and was thankful for the new Lambda sensors. Now, when started, it appears to tick over steadily for a minute or two, then it is like the engine has been switched off, it just cuts out. I have checked all the hoses for air leaks, I have tried it without the air filter and I have scrupulously checked the new Magnecor HT leads to make sure they are correctly fitted and not touching each other.
I would be grateful for any ideas on where I can go with this now.
Many thanks, Phil
Re: 1997 Plus 8 tickover
[Re: Phil+8]
#675195
28/11/20 04:56 PM
28/11/20 04:56 PM
Posts: 3,204 Yorkshire
Yorkshire
Is it an ECU that logs fault codes ?
[Re: Phil+8]
#675200
28/11/20 05:07 PM
28/11/20 05:07 PM
Posts: 567 Chester, UK
Grumpy2
Chester, UK
There’s an odd thing with the librands that pass under the sump. You need to also swap the wiring looms to the lambda sensors from side to side.
Apparently confuses the ecu no end if you don’t.
94 plus 8 in Westminster Green - I think!
[Re: Grumpy2]
#675226
28/11/20 07:08 PM
28/11/20 07:08 PM
Posts: 733 North Somerset, UK
Deejay
North Somerset, UK
Apparently confuses the ecu no end if you don’t. That’s the very thing that happened to a friend. Ended up with several trips to a garage, bits replaced with no improvement and it turned out to be lambda sensors needed swapping over from side to side. Forgive me but are you sure the Librands instructions are correct and have been interpreted correctly??
Doug
2011 +4 in Rich Maroon 1972 750 “ComDom” sprinter 1958 Triton 650 1992 Triumph Trophy 900
[Re: Phil+8]
#675241
28/11/20 08:51 PM
28/11/20 08:51 PM
Posts: 949 Evergreen, Colorado, USA
britmog
On my 94 +8 I had the issue of the engine stalling when the vehicle came to a stop, fault code 48 showed on the ECU LED readout which is mainly the Stepper Motor sticking or incorrect base idle speed adjustment and possible throttle butterfly adjustment. After replacing Stepper Motor the problem persisted, I also checked the butterfly adjustment and in the end established it was a poor earth on the road speed sensor. Rough running can be attributed to fuel or ignition issues, do you know what code is being shown? These links might be useful: http://www.britishv8.org/Articles/Rover-14CUX-EFI.htmhttp://www.v8wizard.com/Setting_Air_Mass_Flow_Meter_and_Throttle_Pot.phphttps://www.actproducts.co.uk/2011/lucas-14cux-fuel-injection-system-%e2%80%93-installation-and-diagnostic-notes/
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
