8 registered members (Image, +8Rich, The Austrian, Craig Jezz, M3W55, pandy, Jeff D, planenut), 155 guests, and 18 spiders.
+8Rich 383
John V6 301
Alistair 167
Peter J 139
Some very expensive Morgans
by JohnMat. 27/01/21 10:23 PM
Lockdown project
by BillMiller. 27/01/21 07:45 PM
nouveau membre Sud-ouest France
by Déo47. 27/01/21 05:49 PM
DeLorean: Documentary
by Fuel.inj. 27/01/21 04:53 PM
LED H4 Bulbs
by John V6. 27/01/21 12:35 PM
97 +4 boss
by John V6. 27/01/21 12:22 PM
HomerS drives a MTW
by CooperMan. 27/01/21 11:50 AM
Another High Level brake light
Morgan puzzle made to order
TOK 258 drawings
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
bear65, Mogster +4, JimV6, IainG, Ollie
7346 Registered Users
Topics40,357
Posts672,576
Members7,346
Most Online1,033
Dec 28th, 2019
No Birthdays
Sealing wood #675479
30/11/20 04:00 PM
30/11/20 04:00 PM
South Shields
Leroy Offline OP
Leroy  Offline OP
South Shields
Have done a bit of research but can't find an exact answer. Looking at the wooden panels through the rear wheel archs and they look like they need sealing. One is a bit patchy, the other is nearly all bare wood. What was/is on is black, and assume is the original factory sealant. I've got some waxoyl for when I get around to doing the chasis, but would it be OK to use it on the wood panelling as well? I'm just concerned about sealing in moisture that will let the rot set in. What are your thoughts?
2004 Series 1 Roadster
Re: Sealing wood [Re: Leroy] #675493
30/11/20 05:23 PM
30/11/20 05:23 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Waxoyl should be fine, I have used it on all my cars.. If you are worried paint them with teak oil first.
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Sealing wood [Re: John V6] #675496
30/11/20 05:29 PM
30/11/20 05:29 PM
South Shields
Leroy Offline OP
Leroy  Offline OP
South Shields
Thanks John. I've got some Danish oil that I use for my oak worktops, so that could work out well. Being more fluid it would be able to creep into the tightest spaces that the waxoyl might not be able to reach, and then waxoyl to give more protection. I was quite surprised at the difference between the two sides as to how much more bare wood there was. Well that's my weekend sorted.
Re: Sealing wood [Re: Leroy] #675499
30/11/20 05:35 PM
30/11/20 05:35 PM
AndyrIch Offline
AndyrIch  Offline
I would read the label carefully on the Danish oil. You wouldn't want to get a hot exhaust near it until it had properly dried out.
The warning on the tin i've got, says to leave brushes submerged in water to prevent the risk of them spontaneously combusting after use!
Re: Sealing wood [Re: AndyrIch] #675503
30/11/20 05:41 PM
30/11/20 05:41 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
It's a strange thing to warn about. I've used Danish Oil inside on all the exposed wood over maybe ten years. Not only does it dry really fast, but it has a nice smell.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Sealing wood [Re: Leroy] #675507
30/11/20 05:53 PM
30/11/20 05:53 PM
South Shields
Leroy Offline OP
Leroy  Offline OP
South Shields
I had never considered it combusting. It'll definitely not be driven till I've finished doing the chassis so there'll be no issues with it catching fire from the exhaust.
Re: Sealing wood [Re: Leroy] #675508
30/11/20 05:55 PM
30/11/20 05:55 PM
Aberdeenshire
Image Online content
Image  Online Content
Aberdeenshire
Is the nearly bare one the nearside ? ..... the nearside of vebicles often suffers worse in lots of ways as that's the side that gets regularly 'powerwashed' with gravelly water by splashing through kerbside puddles.
Re: Sealing wood [Re: Image] #675516
30/11/20 06:33 PM
30/11/20 06:33 PM
South Shields
Leroy Offline OP
Leroy  Offline OP
South Shields
It's actually the offside, and quite a considerable difference. Virtually no black, as opposed to the top 3 or 4 inches on the nearside.
Re: Sealing wood [Re: Leroy] #675537
30/11/20 08:24 PM
30/11/20 08:24 PM
Lancaster
Phil Bleazey Offline
Lancaster
Simple quick and easy - mix linseed oil with terebenthine ( pure terpentine) 50/50 and splash it on - it soaks in well, dries quickly and if you have the time for several coats at one week intervals you will end up with a finish second to none. I have table tops finished in this way and they resist boiling water - hot trays from the oven - any type of kitchen spillage and the finish will cope with salt spray form the roads with no trouble. I use it inside chassis tubes and anywhere else you want to proof against water. Inside tubes it is particularly good if sealed in - linseed oil oxidises and so it gobbles up all the oxygen in the space and without oxygen there can be no rust. it is inflammable when wet - take care. It can be painted over. Some ladies even like the smell!
Beware things with brand names!
Phil
Re: Sealing wood [Re: Leroy] #675539
30/11/20 08:48 PM
30/11/20 08:48 PM
UK
clubsport Offline
clubsport  Offline
UK
When I received my new wooden frame and tub from the factory, I gave it several coats of cuprinol over a period of weeks and when dry painted it in yacht varnish. It still looks new today!
