18 registered members (JohnS, Fuel.inj, James B W, DCH, aerotaff, Tally Ho, M3W55, +8Rich, Stringers Best Mate, John07, Island Mog, StevieMac, Scrambledsignals, LightSpeed, SeaTacTom, MJF, MiltonMan, JohnHarris), 165 guests, and 14 spiders.
+8Rich 384
John V6 301
Alistair 167
Peter J 139
Some very expensive Morgans
by JohnMat. 27/01/21 10:23 PM
Lockdown project
by BillMiller. 27/01/21 07:45 PM
nouveau membre Sud-ouest France
by Déo47. 27/01/21 05:49 PM
DeLorean: Documentary
by Fuel.inj. 27/01/21 04:53 PM
LED H4 Bulbs
by John V6. 27/01/21 12:35 PM
97 +4 boss
by John V6. 27/01/21 12:22 PM
HomerS drives a MTW
by CooperMan. 27/01/21 11:50 AM
Another High Level brake light
Morgan puzzle made to order
TOK 258 drawings
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
bear65, Mogster +4, JimV6, IainG, Ollie
7346 Registered Users
Topics40,357
Posts672,576
Members7,346
Most Online1,033
Dec 28th, 2019
No Birthdays
Replacing diff oil seal #675705
01/12/20 06:44 PM
01/12/20 06:44 PM
RedSocks Offline OP
RedSocks  Offline OP
Hi
I am a relatively new owner. I have a 1986, 4/4, 4 seater, which I have had for just under a year. It’s in pretty good condition, one previous owner and only done around 28000 miles. Due to COVID restrictions I haven’t had much chance to get out and talk to other owners.
As such I am after a bit of advice.
There is an oil leak which appears to be coming from the oil seal in the diff.
Is replacing the seal a job that I should tackle, and are there any tips or things to look out for?
Alternatively, should I steer clear of it?
Re: Replacing diff oil seal [Re: RedSocks] #675712
01/12/20 07:12 PM
01/12/20 07:12 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Depends where the leak is. Is it on the flange between the backplate & the diff casing then that is relatively easy with liquid gasket or a new gasket.
If on the drive shaft that is much harder. I am sure experts will come along and help soon but here is a guide.
GoMog diff info
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Replacing diff oil seal [Re: RedSocks] #675741
02/12/20 07:47 AM
02/12/20 07:47 AM
Arwyn Williams Offline
From my experience, its pretty straightforward albeit with limited access to do the job but you need to be aware of a few things
1.) I've never actually seen a torque figure for the diff flange nut, so ended up marking up the nut and working out the torque setting. Turned out it was something in the region of 146 ft lb, I think. There's a crush spacer used to set the crown wheel and pinion mesh, so this figure is crucial!
2.) There's 3 types of oil seal so make sure you get the right one, from memory, one at 6 quid, one at 12 quid and one at 40 quid!
3.) Its very unlikely the old seal will come out as one! Be prepared to take it out in bits!
4.) Finally, check the breather hole on the rear axle tube, its a small 3mm hole which easily gets filled up with muck and causes the axle to pressurise
Arwyn
Re: Replacing diff oil seal [Re: Arwyn Williams] #675748
02/12/20 08:56 AM
02/12/20 08:56 AM
Ross-on Wye, Herefordshire
bilibib Offline
bilibib  Offline
Which begs the question, how do you determine which type of lip seal is fitted is to the pinion shaft of your Salisbury Diff.? To ensure that everything is at hand before you start the strip down
Owen
"bilibib"
1982 4/4 Twin Cam
Royal Ivory, Dark Red Leather
Re: Replacing diff oil seal [Re: RedSocks] #675758
02/12/20 10:30 AM
02/12/20 10:30 AM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
I've done three MGB diffs, all Salisbury. In each case, there was only one seal available, although this was years ago. Probably best to get the old one out for examination first.
As Arwyn said, a collapsible spacer sets the pinion position, and if you over tighten beyond that point, it should either be replaced, or I do know one case where it was removed and de-collapsed, then reused. But this is hassle.
The ones I did, I marked the nut and flange, counted the turns off. Changed the oil seal. Counted the turns back and tightened until the marks aligned.
The second one was little more than finger tight to be honest , just nipped up from that. A bit of Loctite to make sure, but it was fine.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Replacing diff oil seal [Re: DaveW] #675761
02/12/20 10:56 AM
02/12/20 10:56 AM
bilibib Offline
bilibib  Offline
So where does the 146 ft/lbs come in ?
Owen
"bilibib"
1982 4/4 Twin Cam
Re: Replacing diff oil seal [Re: RedSocks] #675762
02/12/20 11:05 AM
02/12/20 11:05 AM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
For seals, I would suggest contacting the Bellingers at JB Sports Engineering
1972 4/4 4 seater - 3G Morganeer
Too many ratty motorbikes
Re: Replacing diff oil seal [Re: bilibib] #675769
02/12/20 11:56 AM
02/12/20 11:56 AM
I marked the nut and the pinion shaft with aligning marks using a straight edge and TCT scriber and it took 146 ft lb to move the marks out of alignment.
Arwyn
Re: Replacing diff oil seal [Re: Arwyn Williams] #675771
02/12/20 12:12 PM
02/12/20 12:12 PM
bilibib Offline
bilibib  Offline
Arwyn
Does that mean I do not need to use a torque wrench, just mark the pinion shaft and nut positionally, count turns made in removing the nut and replace to the same values ?
Owen
"bilibib"
1982 4/4 Twin Cam
Re: Replacing diff oil seal [Re: bilibib] #675775
02/12/20 01:08 PM
02/12/20 01:08 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Arwyn
Thats how I did it. There was a lot of correspondence at the time on the MGCC grapevine after a few V8s had the roll pin collapse, and destroy the diff, so it was headline news for a while.
