10 registered members (MJF, TheRabbit, brownbaker, Hamwich, yobtaf, DCH, jbk, jimmyw, CBY, teifistar), 261 guests, and 13 spiders.
OZ 4/4 151
John V6 130
+8Rich 122
Luddite 113
CooperMan 109
JJD1776, Newboy, Tractor Driver, Phil Bordeaux, Slushymud
8127 Registered Users
Sidescreen window sticking
by Felix42. 28/09/22 09:22 PM
CANBUS & LEDs
by Buzz44. 28/09/22 02:32 PM
S1 Aero on live UK online auction - Ends 27 Sept
by Volvos60s60. 28/09/22 08:07 AM
Whilst I'm at it...
by Treesurveyor. 27/09/22 08:06 PM
Wobbly Steering Wheel
by Treesurveyor. 27/09/22 06:56 PM
Greasing the front UJs
by John V6. 27/09/22 01:23 PM
Roaster 3.0 MK 1 Pulley Noise / Wobble
by flyfisher. 27/09/22 12:23 PM
MORGAN SUPER 3 SUPER CLASSIC
Mirror
Fun in the Sun
My 1991 Plus 8
Morgan Super 4 EV
Topics44,095
Posts743,434
Members8,127
Most Online1,033
Dec 28th, 2019
Dutch
Page 31 of 32 1 2 29 30 31 32
Re: Centra Compensator falling apart..... [Re: PhilipNZ] #676282
05/12/20 03:37 AM
05/12/20 03:37 AM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Clicked over 10000km last week and because off this thread had a look and a feel around the Centa. No sign of anything amiss, no chunks or shavings like above. Phew.
Me and my big mouth, today, an hour before going in a Christmas Parade, the centa rollers fell apart :-(
Looks like you get to learn how to pull the engine and steering rack as a Christmas present.
Re: Centra Compensator falling apart..... [Re: LightSpeed] #676285
05/12/20 07:04 AM
05/12/20 07:04 AM
Australia - NSW North Coast
OZ 4/4 Offline
OZ 4/4  Offline
Merry Christmas from the Morgan Motor Company
Re: Centra Compensator falling apart..... [Re: PhilipNZ] #676297
05/12/20 08:38 AM
05/12/20 08:38 AM
Auckland New Zealand
P964 Offline
P964  Offline
Hi Phillip
Having now taken motor out twice already, I can offer assistance if required.
I replaced the rubbers in my Centa last year? Simply because I was already in there. The old ones were in perfect condition.
Old ones are approx 1 mm shorter than new ones.
Currently off road due to broken valve spring yesterday! Must be something going around, possibly mechanical COVID!?
Re: Centra Compensator falling apart..... [Re: WarBird] #676299
05/12/20 08:46 AM
05/12/20 08:46 AM
Nr Watership Down UK
JMD Offline
JMD  Offline
Is this outbreak of Kiwi breakdowns some form of divine retribution for your successful handling of CV-19?? Sorry to hear your stories - hope you are all back on the road soon.
Re: Centra Compensator falling apart..... [Re: WarBird] #676421
06/12/20 12:28 AM
06/12/20 12:28 AM
Auckland, New Zealand
PhilipNZ Offline
ZK-Mog
PhilipNZ  Offline
ZK-Mog
Rubber barrels on their way to me already thanks to the amazing service from Grace and Dennis at Morganwest
Re: Centra Compensator falling apart..... [Re: WarBird] #683858
18/01/21 03:22 PM
18/01/21 03:22 PM
Hertfordshire
O
Obie Offline
Obie  Offline
O
Hertfordshire
I have just done Phil's Centa mod on a service exchange basis, i know this is old hat to many of you but i enjoy the posts about stuff being done to the cars so thought i would post a few pictures.
The main reason for doing it, apart from the well known benefits, was to try to get to the bottom of a rattling sound i was getting from the Centa area
which i think it has done.
The kit comes with everything done and just needs fitting, the splines on the hub will fit perfectly to an unworn crank without filing, Phil can supply undersize spline that will need fitting if your crank is worn.
Tightening the crank nut F.T.
The Centa with the new support bearing and full size crank nut.
New bolts supplied by Phil that replace the poor originals.
I also replaced the clutch support bearing as it felt gritty and was noisy when spun and all the grease had come out through the metal seal.
Phil supplied a replacement with a rubber seal.
Pressing the shaft into the new bearing using the cheapest press on Ebay but it did the job no problem.
This is link to a video of the original Hub fit on the crank or lack of!
https://www.youtube.com/watch?v=GSlf67Lfn7Q
The new hub is a perfect fit and now at idle the rattle is gone, i haven't been able to go for a test drive yet as the car is SORN at the moment but am sure the rattle i was getting at 3K plus will be as well.
Doing all this makes me appreciate the work Phil has done developing the kit as its a lot of work getting the engine in and out but the number of times he's done it he's probably got it sussed now!
Re: Centra Compensator falling apart..... [Re: WarBird] #683860
18/01/21 03:24 PM
18/01/21 03:24 PM
New River Valley, VA
rcmatt Offline
rcmatt  Offline
thanks for the pictures
Rodger
2004 Plus 8 (wife's)
Re: Centra Compensator falling apart..... [Re: Obie] #683869
18/01/21 04:24 PM
18/01/21 04:24 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
Thanks for all the photos and info Obie. Impressed that you did it all on an exchange basis yourself, I know some others have but it's quite a job. Looking at the clunky fit of the hub to the crank before, it should all run much quieter and smoother, certainly a job worth doing. I found a lot of the vibrations and clunks went after doing these Centa mods, not all of them but a lot laugh2
I know Phil says it's not needed but I drilled and wire locked the four Allen head bolts that hold the insert retaining plate in place. You don't want them falling out but as they occasionally need to come out you don't want to do them up too tight, use locking washers or Loctite, they need to be positively locked I think. Maybe overkill on my part?
Re: Centra Compensator falling apart..... [Re: WarBird] #683888
18/01/21 05:40 PM
18/01/21 05:40 PM
Hertfordshire
O
Obie Offline
Obie  Offline
O
Hertfordshire
I know everything else is Loctited to stop it coming undone on the engine but i did as Phil suggests and left them as is. They would be a pain to remove with the limited access if Loctited winding them out so maybe locking washers as you suggest?
Re: Centra Compensator falling apart..... [Re: Obie] #683953
19/01/21 12:04 AM
19/01/21 12:04 AM
planenut Offline
planenut  Offline
I drilled and wire locked them, that way they will be easier to remove when the time comes but positively locked.
