Topics40,572
Posts677,956
Members7,354
Most Online1,033 Dec 28th, 2019
Aero S4 Vibration Issues
#676845
08/12/20 08:34 AM
08/12/20 08:34 AM
Posts: 66 Gloucestershire
drewg
Gloucestershire
Having recently bought my S4 it has a vibration issue from the rear which gets worse at speed. Initially thought it was wheel balance as rear tyres had just been replaced. Had the wheel balance done on the rear and found there the nearside wheel was buckled. Bloke said no problem balanced the wheels and now have the vibration at lower sppeds too  .Took the car to Williams last friday who have replaced the buckled wheel and rebalanced the wheels and....only marginally better but they did find that there was a split on thge outer casing of the propshaft which could be the culprit  Any ideas welcomed. I'm still trying to master adding photo's so hopefully they are attached of the split propshaft. Cheers
AnDrew G 2009 Aero S4
Re: Aero S4 Vibration Issues
[Re: drewg]
#676853
08/12/20 08:59 AM
08/12/20 08:59 AM
Posts: 3,329 Yorkshire
Yorkshire
That's a significant crack, I'd only drive it very slowly (on to a trailer) There are specialists out there who advertise propshaft balancing, and I assume they could build you another & transplant the 'ends' Also worth a call to the factory perhaps on the off-chance of a spare / who made them originally
[Re: drewg]
#676861
08/12/20 09:48 AM
08/12/20 09:48 AM
Posts: 296 North Yorks
John07
North Yorks
No way should that be welded. That is a very straight crack, I do hope it's not ERW seamed tube? I would cut it open to find out. Other Aero owners need to know if that is the case. I know a place in Leeds that will rebuild/make a new one but I assume you'll be able to find somewhere a lot nearer to you. Cheers John
[Re: drewg]
#676867
08/12/20 10:29 AM
08/12/20 10:29 AM
Posts: 1,544 Newcastle Upon Tyne
James B W
Newcastle Upon Tyne
what could cause a crack like that?
I too would be wary of driving any distance/speed 'till it was fixed (or replaced)
Good luck with getting it sorted......
James
Aero8 , Series 1 - Boston Green Range Rover Evoque S Smart Brabus Convertible Honda Monkey Z125
[Re: drewg]
#676877
08/12/20 11:25 AM
08/12/20 11:25 AM
Posts: 19,195 South Yorkshire
South Yorkshire
It looks like a seam fail, being so straight, and not fresh either. I've never seen a prop fail like that.
DaveW 2005 Corsa Red Roadster S1 2016 Saffron Yellow (Narrow) AR Plus 4
[Re: drewg]
#676880
08/12/20 11:37 AM
08/12/20 11:37 AM
Posts: 13,548 Salisbury, UK
Peter J
Formerly known as Aldermog
Salisbury, UK
Gosh... not a sight one wants to see.  My impression is that it is a tube manufacturing problem and I'd want to have a new prop shaft tube. Yes, it could be repaired, but there is no way of knowing how far along the tube the weakness exists and that could later fail. If you have bottomless pockets a new carbon fiber prop shaft would be the way to go,,,,,,,
Peter, V8s are best.... Tarka the 'Otter Mog....2014 Plus 8 AMG C63 Estate.
[Re: drewg]
#676888
08/12/20 12:16 PM
08/12/20 12:16 PM
Posts: 26,710 Devonshire
Devonshire
Sorry to see this Andrew, what with the wheel and this it's taken the shine off new ownership for you. Once it's sorted you will have lots of fun with her I'm sure.
Regards Richard
1999 Indigo Blue +8 2009 4/4 Sport Green prev 1994 Connaught Green +8 prev
