8 registered members (HeadlessBlue, Fuel.inj, Alan Patterson, RichardV6, Andrew Kidney, ChrisConvertible, MiltonMan, atalante83),
211
guests, and 15
spiders. |
Topics40,572
Posts677,957
Members7,354
Most Online1,033 Dec 28th, 2019
Wing beading
#677964
14/12/20 12:50 PM
14/12/20 12:50 PM
Posts: 42 South Shields
Leroy
South Shields
I'm after a steer in whether I need to have some remedial work done on the area beneath my nearside door, in particular the join between the wing and the body. The beading is bulging in a couple of places and has quite a bit of wet grime between the joins. The expensive route would be to have the wings removed, a good clean up the beading replaced. The other options I'm considering is squirt a load of acf50 in the join, and repeat before washing, or apply some clear silicone sealant in the join to keep any water out. Or something else that you guys suggest. Is it a scenario thst will only get worse over time?
2004 Series 1 Roadster
Re: Wing beading
[Re: Leroy]
#677966
14/12/20 12:51 PM
14/12/20 12:51 PM
Posts: 19,118 Suffolk
Suffolk
Can you post some pictures?
JohnV6 2006 Indigo Blue Roadster S1 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Wing beading
[Re: Leroy]
#677971
14/12/20 01:11 PM
14/12/20 01:11 PM
Leroy
South Shields
Any advice on uploading photo's. It says I can't upload any bigger than 1000 bytes?
Re: Wing beading
[Re: Leroy]
#677977
14/12/20 01:30 PM
14/12/20 01:30 PM
Posts: 1,544 Newcastle Upon Tyne
James B W
Newcastle Upon Tyne
I'm afraid I can't answer your question Leroy but, please don't use silicone sealer.
If you ever need to get that area re-painted the silicone will be a 'mare to get rid of and it can cause real problems with the paint.....
James
Aero8 , Series 1 - Boston Green Range Rover Evoque S Smart Brabus Convertible Honda Monkey Z125
Re: Wing beading
[Re: James B W]
#677981
14/12/20 01:35 PM
14/12/20 01:35 PM
Posts: 3,329 Yorkshire
Yorkshire
I'm afraid I can't answer your question Leroy but, please don't use silicone sealer. If you ever need to get that area re-painted the silicone will be a 'mare to get rid of and it can cause real problems with the paint..... James Agreed, plus it will never seal well enough to stop moisture getting in, & once in will partially trap it & slow the drying out, often accelerating corrosion
Re: Wing beading
[Re: Leroy]
#677991
14/12/20 02:05 PM
14/12/20 02:05 PM
Posts: 4,952 Llanelli
Ray
Llanelli
Unfortunately you may have a major problem, it was common on older cars to rot the wooden rocker and rust the outer metal skin.the only treatment is to remove the rot. But .I hope it's not that serious.
Re: Wing beading
[Re: Ray]
#677993
14/12/20 02:13 PM
14/12/20 02:13 PM
Leroy
South Shields
It's a 2004 roadster so it won't gave the rust issue with its aluminium body. I've have a thin wooden skewer along the beading and scraped out a load of grey/black greasy slime so hopefully it'll dry off. Don't think there's any rot issues, but just want some advice on whether it's a wing off job, or whether a good greasing either side of the beading will fill in and crevices/recesses to keep the water out is a sufficient remedy.
