9 registered members (The Austrian, Saxonian, Gordon D, RichardV6, kankeL, MOGSWE, Graham, G4FUJ, Edwin, Stewart S), 169 guests, and 13 spiders.
John V6 299
+8Rich 285
TBM 148
Peter J 141
Mystery rubber bit
by GPC1203. 09/03/21 01:24 AM
Electric 4/4
by nick w. 08/03/21 10:41 PM
Engine Management Fault Codes
by Barrythebrave. 08/03/21 07:59 PM
Good old Banksy
by +8Rich. 08/03/21 05:47 PM
How many Morgan miles did you do in 2020?
by howard. 08/03/21 05:41 PM
Restomod
by howard. 08/03/21 05:29 PM
Relay help, please
by vbalddave. 08/03/21 05:28 PM
Mandy's Morgan so far...
Skiing in Scotland
Some pics
More Lock-Down slides
Gearbox oil check 2nd attempt at pics
Steve Thornton, RubyWexford, Steve Van Dyke, Yanto, andypandy
7412 Registered Users
Topics40,660
Posts679,548
Members7,412
Most Online1,033
Dec 28th, 2019
Andyhirst, Morgan110
Morgan Plus +8 speedo connection to gearb #677682
12/12/20 05:45 PM
12/12/20 05:45 PM
FrancisD Offline OP
FrancisD  Offline OP
Chaps. I am going to install a speedometer connection between the Cosworth gear box to a speedometer.
Any suggestions how to do this,where is the gerbox connection
Where to buy a suitable cable?
Any wisdom would be appreciated
Thanks
Francis
Audi A8 4.2
Jaguar XKR
Golf
Morgan Plus 8
Re: Morgan Plus +8 speedo connection to gearb [Re: FrancisD] #677688
12/12/20 06:13 PM
12/12/20 06:13 PM
London
MOG 615 Offline
MOG 615  Offline
London
Francis
I am afraid we need a bit more information before we can really help you.
What year +8 do you have? I am unaware of a "Cosworth" gearbox fitted to any of the Rover engined cars.
Those fitted were :
Early cars : Moss 4 speed
Intermediate : Rover 4 speed
Post 77 : Rover LT77 then finally Rover R380
I am no expert on the Aero 8 based Plus 8 but I thought that had a Getrag/BMW manual box.
Andy G
1999 +8 , Indigo Blue.
Re: Morgan Plus +8 speedo connection to gearb [Re: MOG 615] #677693
12/12/20 06:55 PM
12/12/20 06:55 PM
SimonH Offline
SimonH  Offline
Originally Posted by MOG 615
Francis
Those fitted were :
Andy, this is the ex class A car being rebuilt into a road car
Francis
Nothing is standard on this car, you will need to have a custom cable made
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: Morgan Plus +8 speedo connection to gearb [Re: FrancisD] #677694
12/12/20 07:16 PM
12/12/20 07:16 PM
East Harling, Norfolk UK
RichardV6 Online NoMood
I've had a custom tacho cable made by Speedograph Richfield. If they can work with a vintage Smith's tacho driven via 1:3 gearbox from 1936 vintage diesel, I'm sure they can come up with something for your car.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Morgan Plus +8 speedo connection to gearb [Re: FrancisD] #677725
12/12/20 11:22 PM
12/12/20 11:22 PM
FrancisD Offline OP
FrancisD  Offline OP
Thanks thats most useful.
Yes Simon is quite right
I believe the set up is as follows.
Rover 3.9
Gearbox is a Ford Cosworth 2wd T5 CR gear set with AP clutch bearing and cover.
I guess the output for the Speedo is under the back rhs of the box where there is a removable cover.
I am also wanting to find out how to get a proper Rev counter with 100mm width and where best to get a suitable output.The coil i guess.
Audi A8 4.2
Jaguar XKR
Golf
Morgan Plus 8
Re: Morgan Plus +8 speedo connection to gearb [Re: FrancisD] #677781
13/12/20 10:25 AM
13/12/20 10:25 AM
London
MOG 615 Offline
MOG 615  Offline
London
Thanks Simon and Francis
There have been a couple of instances recently of race +8s being reconverted into road cars. On the face of it an appealing idea , but i suspect there is an awful lot of work to back-engineer before they become suitable for the road.
I am kind of surprised that the engine is a 3.9, as a Class A (not sure what class it is now with the new system) +8 is more likely to be a fire-breathing 4.6 V8 than a 3.9
Andy G
Re: Morgan Plus +8 speedo connection to gearb [Re: FrancisD] #677788
13/12/20 10:51 AM
13/12/20 10:51 AM
FrancisD Offline OP
FrancisD  Offline OP
You are quite correct
Its a brand new Rover 3.9 with Hurricane cam and Edelbrock 4 way downdraught carbs.
Any advice on Rev counters and Speedos apprciated
Audi A8 4.2
Jaguar XKR
Golf
Morgan Plus 8
Re: Morgan Plus +8 speedo connection to gearb [Re: MOG 615] #677794
13/12/20 11:03 AM
13/12/20 11:03 AM
SimonH Offline
SimonH  Offline
It was a fire breathing 4.6,along with a Getrag 265
All that’s left of the race bits now is the brakes and wheels really...
Simon @ Sifab.co.uk
Re: Morgan Plus +8 speedo connection to gearb [Re: SimonH] #678050
14/12/20 06:09 PM
14/12/20 06:09 PM
Culminator Offline
Culminator  Offline
Francis, I mentioned at the time what your best options were regarding the speedo but we talked about a lot of things, so maybe that bit just got lost in a heap of other info. Anyway, you have 2 options with the current situation.
First option is to acquire a Cosworth T5 speedo drive and also the cable. The speedo drive fits into the tail of the gearbox on the RHS and currently it's blanked off by a nice circular alloy blanking plate. The downside is that the speedo drives are not available new and second hand ones are rare and very expensive (circa £120) and you'll need to get the speedo recalibrated for the final drive ratio. Not a big problem but a bit of a faff.
Your second option, and the one I recommended was to simply buy a Smiths Classic digital speedo. These really do look very much like the original speedo you have but run off an electronic "pick up" usually on the front rotor. Really easy to do, endlessly configurable and not expensive. This is what most Morgan T5 gearbox users have.
You're nearly there!
Re: Morgan Plus +8 speedo connection to gearb [Re: Culminator] #678195
15/12/20 09:43 PM
15/12/20 09:43 PM
FrancisD Offline OP
FrancisD  Offline OP
That sounds a great idea and much better than the faf with the gearbox.
Audi A8 4.2
Jaguar XKR
Golf
Morgan Plus 8
