15 registered members (mph, jrt, Jon G4LJW, RedThree, HJF, The Austrian, Jens, PaulJ, Robbie, HeadlessBlue, ScotsGent, SFO, TimB, teifistar, Spanner Juggler), 176 guests, and 21 spiders.
John V6 310
+8Rich 284
Peter J 174
Maintenance Day
by Saxonian. 21/04/21 08:27 AM
How many Morgan 3 Wheelers left to be made?
by Red3W. 21/04/21 07:23 AM
maybe the era hasnt ended.
by howard. 21/04/21 06:58 AM
Brake pads Roadster 3,7
by Mats. 21/04/21 06:51 AM
Headlight bezel
by Tim Caddey. 20/04/21 10:19 PM
Bonnet hinge 97 +8
by Fus969. 20/04/21 06:06 PM
Advice re hardtop front mountings, please
by vbalddave. 20/04/21 09:36 AM
Lap of the Cairngorms
2017 Sport Blue M3W
Front spoiler
My M3W
Spring has sprung at Hintlesham...
tony1966, Grahameeyore, Animal, prf, Morgs52
7485 Registered Users
Topics41,048
Posts686,997
Members7,485
Most Online1,033
Dec 28th, 2019
Kurt
+8 exhaust #677953
14/12/20 10:51 AM
14/12/20 10:51 AM
north yorkshire
B3MOG Offline OP
B3MOG  Offline OP
north yorkshire
can somebody post a picture of the rear exhaust hanger for a plus 8 please. Its the rear exhaust that is a pipe that includes the silencer and is 3" dia at the end.
David Byrne
Re: +8 exhaust [Re: B3MOG] #677958
14/12/20 12:03 PM
14/12/20 12:03 PM
Luddite Offline
Luddite  Offline
Unsure if this is what you are after my +8 is of mid 80`s vintage and it has an aftermarket SS exhaust, the resonators on which I removed, to give it a bit more...err voice when the loud pedal is pressed a bit more than normal.. smile
Hope I am not muddying the water..
Re: +8 exhaust [Re: B3MOG] #677963
14/12/20 12:49 PM
14/12/20 12:49 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
I think the “pig’s nose rubber hanger is common to the various standard/most prevalent after market exhausts. Correct me if wrong.
Red Plus8
Re: +8 exhaust [Re: B3MOG] #677965
14/12/20 12:50 PM
14/12/20 12:50 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
That set up is still used on the modern Trads. The car bracket is the same. The tailpipe bracket is now usually welded on, and the rubber bracket is used at 90 degrees to that pic above.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: +8 exhaust [Re: B3MOG] #677973
14/12/20 01:18 PM
14/12/20 01:18 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
Here’s mine on a 2002 Plus8. 3” OD end box.
Red Plus8
Re: +8 exhaust [Re: B3MOG] #677979
14/12/20 01:34 PM
14/12/20 01:34 PM
Luddite Offline
Luddite  Offline
DaveW, sospan, my rubber hangar is non standard bought from Halfrauds as a universal type, it is turned to provide the maximum ground clearance for the tailpipe.
I recently bought a couple of spares from Melvyn that seem to be identical to the one in your pic sospan, though seems that the Halfrauds ones give a fraction more ground clearance for the tailpipe..
Re: +8 exhaust [Re: B3MOG] #677984
14/12/20 01:39 PM
14/12/20 01:39 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
Nice to know. I have scraped the exhaust end a few times!
Red Plus8
Re: +8 exhaust [Re: B3MOG] #678147
15/12/20 01:59 PM
15/12/20 01:59 PM
north yorkshire
B3MOG Offline OP
B3MOG  Offline OP
north yorkshire
Thanks for all the replies, the exhaust I want to fit has a lug welded to the end pipe/exhaust, which is elongated slightly and takes a 10mm nut and bolt sandwiched with two rubber washers this is what I was hoping to get an image of..
I tried posting an image but for some reason (file too big) it will not let me, I have never had this problem before, any ideas, (I am rubbish with a computer).
David Byrne
Re: +8 exhaust [Re: B3MOG] #678155
15/12/20 04:12 PM
15/12/20 04:12 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
This is the arrangement I have as it is a dual Librands Sport fitted, the lug is welded to the pipe and slides through the fleximount. It sounds as if yours is mounted with the Mini standard bobbins as per midpoint silencer.
Regards Richard
1994 Connaught Green +8 prev
Re: +8 exhaust [Re: B3MOG] #678190
15/12/20 09:16 PM
15/12/20 09:16 PM
Sandhurst, Berks
teknome Offline
teknome  Offline
Sandhurst, Berks
The Librands exhaust I have on my Plus 8 did have the welded lugs with a slotted hole. I cut them off and fitted an exhaust clamp with a welded on lug that fits in the same way as shown in the picture by sospan. I had the exhaust clamps lying around, originally came from BHM and fitted to a sports exhaust tailpipe for a 4/4/. I think they are a Librands item.
Found them at Librands - , https://www.librands.co.uk/products-category-76.html
MIKALOR HANGER CLAMP 73-79, and MIKALOR HANGER CLAMP 63-68
For the chassis end
Stainless tail pipe support bracket at rear, (although I got mine during a rummage in the stores at Melvyn Rutters)
I played around with those welded on slotted fixings for ages and couldn't come up with an elegant way to fit the tailpipe
Mike
Mike Smith
1995 +8
2007 +4
