12 registered members (Marchogion, +8Rich, 2017 Betty, JMT, ewn, Alistair, HJF, Ray, JoeSpeetjens, Pmh44, petemog, sprinty), 158 guests, and 22 spiders.
+8Rich 322
John V6 286
Peter J 149
TBM 147
exploded compressor vid.
by Luddite. 18/01/21 07:59 PM
2019 Plus 4 Freon?
by Morgan Atlanta. 18/01/21 04:46 PM
Audi fresh out of chips
by +8Rich. 18/01/21 03:38 PM
Starting - Battery?
by Amrum. 18/01/21 12:57 PM
third brake light wiring?
by Hogzilla. 18/01/21 02:12 AM
Mystery Wire
by OhioM3W. 17/01/21 11:36 PM
Surplex adjustable rear shocks
by Mark H. 17/01/21 10:50 PM
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
Boddam and Ravenscraig
First post
Steam loco build
PH1954, HJF, Valespecial, Berlin, Spizz Oil
7327 Registered Users
Topics40,290
Posts671,039
Members7,327
Most Online1,033
Dec 28th, 2019
No Birthdays
Re: Heated Screen Light Question [Re: Peter J] #682910
13/01/21 05:24 PM
13/01/21 05:24 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Yes, KISS. That or take out the bulb but that is more difficult.
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Heated Screen Light Question [Re: Peter J] #682918
13/01/21 05:48 PM
13/01/21 05:48 PM
Salisbury, UK
Peter J Offline OP
Formerly known as Aldermog
Peter J  Offline OP
Salisbury, UK
The battery this evening shows 12.4v and 95% charged on the RING charger/conditioner.
We shall see what happens overnight!
V8s are best....
Tarka the 'Otter Mog....2014 Plus 8
AMG C63 Estate.
Re: Heated Screen Light Question [Re: Peter J] #682970
13/01/21 09:29 PM
13/01/21 09:29 PM
Taffmog Offline
Taffmog  Offline
My Aero plus 8 does exactly the same, light glows dimly when ignition is off and brightly when heated screen is working. I would imagine it does drain the battery eventually but I always knock the power switch off under the bonnet when parked up overnight so can't comment.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Re: Heated Screen Light Question [Re: Peter J] #683063
14/01/21 01:20 PM
14/01/21 01:20 PM
Salisbury, UK
Peter J Offline OP
Peter J  Offline OP
Salisbury, UK
And what happened...?
12.4v and 80% charge.
I'll charge it to 100% and then see how long it holds. More in a few days.
V8s are best....
AMG C63 Estate.
Re: Heated Screen Light Question [Re: Peter J] #683075
14/01/21 02:34 PM
14/01/21 02:34 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
FWIW Peter 12.4 volts if an accurate off load figure taken an hour or so after last use, equates to 70% charge of whatever battery capacity you have. Don't be fooled by figures from your charger.
Can I assume you were holding back from charging whilst the screen heater switch lamp was off using the trick you found of turning off engine with heater on, in order to establish any reduced drain?
By far the best way to check on drain is to insert an ammeter of sufficient range (several amps) in either of the main battery leads and not after any split. Don't be tempted to turn anything on whilst performing this test as you'll likely blow the meter.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Heated Screen Light Question [Re: Peter J] #683278
15/01/21 03:34 PM
15/01/21 03:34 PM
Salisbury, UK
Peter J Offline OP
Peter J  Offline OP
Salisbury, UK
I put the charger on, presently showing 12.9v and 90%.
When it is showing 100% I'll stop the charge and leave it, to see how it lasts!!
V8s are best....
AMG C63 Estate.
Re: Heated Screen Light Question [Re: Peter J] #683601
17/01/21 11:32 AM
17/01/21 11:32 AM
Salisbury, UK
Peter J Offline OP
Peter J  Offline OP
Salisbury, UK
11:30 am the battery charger test is showing 13.7v, 100% charge.
I've disconnected the charger and will check again every. 24 hours until the battery charge has dropped to 70%.
Not exactly exciting... but interesting!
V8s are best....
AMG C63 Estate.
Re: Heated Screen Light Question [Re: Peter J] #683605
17/01/21 11:40 AM
17/01/21 11:40 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Peter, I hope it works out for you. I hate modern car electrics. Far too complex frankly.
Re: Heated Screen Light Question [Re: Peter J] #683686
17/01/21 05:06 PM
17/01/21 05:06 PM
Salisbury, UK
Peter J Offline OP
Peter J  Offline OP
Salisbury, UK
John,
in the end it is almost academic.
If turning the ignition off with the heated screen on solved the loss of charge then the job is done.
If it does not then we have an unknown drain, so I know:
1. The battery loses charge with time.
2. I have a battery maintenance charger
3. As long as I remember to keep the car connected to the charger I can always start the engine...
V8s are best....
AMG C63 Estate.
Re: Heated Screen Light Question [Re: Peter J] #683691
17/01/21 05:22 PM
17/01/21 05:22 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
True
