12 registered members (Jeff D, craig from mich, +8Rich, M3W55, DaveW, MiltonMan, Lizzy, James B W, Craig Jezz, meabh, DCH, milligoon), 159 guests, and 23 spiders.
+8Rich 323
John V6 285
Peter J 149
TBM 147
exploded compressor vid.
by Luddite. 18/01/21 07:59 PM
2019 Plus 4 Freon?
by Morgan Atlanta. 18/01/21 04:46 PM
Audi fresh out of chips
by +8Rich. 18/01/21 03:38 PM
Starting - Battery?
by Amrum. 18/01/21 12:57 PM
third brake light wiring?
by Hogzilla. 18/01/21 02:12 AM
Mystery Wire
by OhioM3W. 17/01/21 11:36 PM
Surplex adjustable rear shocks
by Mark H. 17/01/21 10:50 PM
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
Boddam and Ravenscraig
First post
Steam loco build
PH1954, HJF, Valespecial, Berlin, Spizz Oil
7327 Registered Users
Topics40,290
Posts671,041
Members7,327
Most Online1,033
Dec 28th, 2019
No Birthdays
Re: Chasis brace a DIY? [Re: TimG] #678969
20/12/20 01:07 PM
20/12/20 01:07 PM
Near Windsor Berkshire
Rog G Offline
Rog G  Offline
Originally Posted by TimG
My July 2013 car had the bolt in brace fitted Oct 2015 & 3000 miles later in March 2017 the chassis cracked & car went to MMC for a replacement chassis.
It seems to bit of the luck of the draw my car was built April 2013 and had the brace fitted in August 2017 at about 6000 miles, it has now done nearly 30000 miles and the chassis is OK.
2013 M3W
1971 4/4 2 Seater
1934 Sports
Re: Chasis brace a DIY? [Re: craig from mich] #678979
20/12/20 02:20 PM
20/12/20 02:20 PM
Ann Arbor
craig from mich Online content OP
craig from mich  Online Content OP
Ann Arbor
okay, thanks for the advice everyone. I will give it a thorough once over before the brace it installed. If there are cracks, I will post another thread about how to proceed. in the meantime, I think someone should nominate p.g. bleazey for a noble prize. his youtubes are really quite fine.
Re: Chasis brace a DIY? [Re: craig from mich] #679079
20/12/20 11:14 PM
20/12/20 11:14 PM
O'Fallon, Missouri USA
Dan_Lockwood Offline
Not having a M3W has it's limitations when offering suggestions on frame support, but I'm still a HUGE advocate that a front cross brace from the top of each forward upper frame tubes need to be connected together in front of the motor, like the ACE does. This will tie each upper side of the front frame tubes together giving them more resistance to flexing.
With the upper A arms just flexing up/down on each bump, they also push inward towards the motor and without any front cross brace, they WILL flex.
Craig, good luck with your future brace install.
Re: Chasis brace a DIY? [Re: craig from mich] #679101
21/12/20 08:52 AM
21/12/20 08:52 AM
Aberdeenshire
TimG Offline
TimG  Offline
Aberdeenshire
A visual inspection of the likely crack points may not be enough to find any developing cracks. I seem to remember a detection method on this forum involving spraying with WD40 wiping of after a time & dusting with talcum powder or chalk. You can buy commercial kits & it may be worth while
Re: Chasis brace a DIY? [Re: craig from mich] #679156
21/12/20 03:07 PM
21/12/20 03:07 PM
Berkshire, England
Mark H Offline
Mark H  Offline
Berkshire, England
Craig from mich, not meaning to be negative - Fitting the brace is only part of the solution, you may also need the chassis pillar triangular support mod from the factory welding into place which together with the brace provides the support. Quite a few guys on here have had that mod carried out and there are posts regarding this mod on this forum.
Although running a 2012 early M3W, I had a chassis change negating both the bolt on brace and subsequent pillar support modification.
All the best and above all, enjoy your M3W.
Re: Chasis brace a DIY? [Re: craig from mich] #679160
21/12/20 03:15 PM
21/12/20 03:15 PM
Berkshire, England
Mark H Offline
Mark H  Offline
Berkshire, England
Re: Chasis brace a DIY? [Re: craig from mich] #679786
25/12/20 01:22 AM
25/12/20 01:22 AM
Ann Arbor
Ann Arbor
thanks Mark
Re: Chasis brace a DIY? [Re: craig from mich] #682975
13/01/21 09:44 PM
13/01/21 09:44 PM
Ann Arbor
Ann Arbor
say, does anyone have a pic of the " triangular pillar support mod?"
Also, the number under my passenger seat of my 2012 is 504. Does anyone know if the pillar support is also needed with this chassis, perhaps? I find the info on this forum more helpful than calling the Morgan garage (who says I might have to pay to have the chassis brace put on??)
Re: Chasis brace a DIY? [Re: craig from mich] #682983
14/01/21 12:23 AM
14/01/21 12:23 AM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
If you go to the thread title list at the top of this forum there is a "M3W Owners Resource - Morgan Three Wheeler Info". There are a number of useful threads there, one is a "Buyers Guide" link to the Morgan Three Wheeler Club website. In the Buyers Guide, Page 6 is a photo of the pillar support you are looking for, along with plenty of other information about chassis cracks and other checks new owners should carry out. Your cars chassis number suggests this modification will be applicable to your car if cracks are found. The first 1027 cars produced had pre 2014 specification chassis fitted from new, although quite a few have had replacement post 2014 chassis fitted since.
Re: Chasis brace a DIY? [Re: craig from mich] #682986
14/01/21 12:54 AM
14/01/21 12:54 AM
Ann Arbor
Ann Arbor
page 6. got it. okay, I read this but didn't see the pillar support. thanks. I don think there are cracks, but I will insist that it's checked out. It sounds like I am staring down chassis replacement. thanks for posting, planenut
