16 registered members (TBM, OZ 4/4, +4competion, PeteMalvern, +8Rich, paulmog, GrumpyPa, Gambalunga, RichardV6, Montegue, yrr13, nippymog, Grumpy2, James B W, TalkMorgan, Chris Cosher),
153
guests, and 17
spiders. |
Topics44,895
Posts759,844
Members8,325
Most Online1,033 Dec 28th, 2019
Fuses
#683497
16/01/21 03:47 PM
16/01/21 03:47 PM
Posts: 5,142 Llanelli
Ray
Llanelli
Hi.i need help please.Does anyone know if there is a second fuse box On a 2007 Duratec 1800 4/4. I was fitting Peter's new wiper blades.But unfortunately When I started them .one wiper jammed After getting Clearance on the wipers. I found the wiper and washer System is dead.Ive checked the fuse box under the bonnet All the fuses seem ok.Is there a relay or online fuse to look for. Thanks Ray.
Re: Fuses
[Re: Ray]
#683503
16/01/21 04:29 PM
16/01/21 04:29 PM
Posts: 5,890 East Harling, Norfolk UK
According to wiring diagrams in the 2006 to 2014 parts book there is a 20 way fuse box. Fuse 8, 10 amp is shown for Wipers on all variants. Suggest pulling that one out and checking for continuity with a multimeter.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
Re: Fuses
[Re: Ray]
#683505
16/01/21 04:48 PM
16/01/21 04:48 PM
Ray
Llanelli
Thanks boys, just had a look with a torch there is another fuse box above the transmission tunnel I'll check them tomorrow. Looks a bit fidly . But has to be done.
Re: Fuses
[Re: Ray]
#683508
16/01/21 05:02 PM
16/01/21 05:02 PM
Posts: 329 Mercia, UK
SALMO
Mercia, UK
Hi Ray,
Yes, you’ve found it. Might help to use a mirror and a fuse puller or small pair of long nose pliers.
Watch your back!
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Re: Fuses
[Re: Ray]
#683543
16/01/21 07:51 PM
16/01/21 07:51 PM
Posts: 4,392 Essex
Burgundymog
Black Rat
Black Rat
Essex
Try the plug under the bonnet passenger side near the bulkhead, a constant problem.
Re: Fuses
[Re: SALMO]
#683546
16/01/21 08:08 PM
16/01/21 08:08 PM
Ray
Llanelli
Hi Ray,
Watch your back! . Looking forward to some new yoga moves.
Re: Fuses
[Re: Ray]
#683612
17/01/21 12:31 PM
17/01/21 12:31 PM
Posts: 8,641 Llanelli
sospan
Llanelli
Ray, my fusebox is in a similar place. Being a supple athlete helps get at it! NOT! My blade fuses have contacts For testing in situ with my multimeter so a bit easier. They are standard blade fuses not mini size. I have a few spare and a good mixed pack of the smaller mini blades you can have if needed.
Red Plus8
Re: Fuses
[Re: Ray]
#683615
17/01/21 12:38 PM
17/01/21 12:38 PM
I wouldn't rely on testing for blown fuses in situ. Random paths in connected circuitry could distort reading.
Re: Fuses
[Re: Ray]
#683621
17/01/21 12:50 PM
17/01/21 12:50 PM
Posts: 20,751 South Yorkshire
South Yorkshire
Fuses can develop hairline cracks which test OK, but under load will heat up and break the circuit.
