22 registered members (Jensen1960, Fuel.inj, JohnHarris, Heinz, HeadlessBlue, Budster, RB1, petemog, AZJowett, Dave Collis, Steve +8, DCH, Image, Bunny, Matt C, Craig Jezz, CasaLobo, Mats, dmh, nick w, PJC, Alwlo),
150
guests, and 18
spiders. |
Topics41,049
Posts687,033
Members7,485
Most Online1,033 Dec 28th, 2019
Re: exhaust hanger
[Re: B3MOG]
#683680
17/01/21 04:48 PM
17/01/21 04:48 PM
Posts: 19,655 Suffolk
Suffolk
It is padding. GoMog sillsbut aren't the bolts further in board ?
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: exhaust hanger
[Re: B3MOG]
#683687
17/01/21 05:11 PM
17/01/21 05:11 PM
Posts: 323 Salisbury, England
DaveK
Salisbury, England
John Many thanks for the GoMog link. A few years back I bought some sills covers which I will be fitting.
Navy Dave 1976 Morgan 4/4
Re: exhaust hanger
[Re: B3MOG]
#683693
17/01/21 05:24 PM
17/01/21 05:24 PM
Suffolk
Dave how is the covid? Are you getting better?
Re: exhaust hanger
[Re: Arwyn Williams]
#683719
17/01/21 07:53 PM
17/01/21 07:53 PM
Posts: 3,688 East Harling, Norfolk UK
You will need to peel back the sill trim
When I made the brackets up for my Plus 4, I welded the two stainless bolts to a piece of stainless steel strip and had the nuts (nyloc) on the outside of the chassis. This meant that you could check for tightness without having to strip the interior of the car
Not sure using riv nuts would be practical as they are too soft.
Arwyn That's effectively what the factory use on later cars. Two studs welded to captive plate and inserted from the inside of chassis rail to take nuts on the outside. Probably a PIA to remove though, although replacing the L shaped exhaust support from the outside would be easy.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1960 Velocette Venom
Re: exhaust hanger
[Re: B3MOG]
#683743
17/01/21 10:35 PM
17/01/21 10:35 PM
Posts: 243 Sandhurst, Berks
teknome
Sandhurst, Berks
The brackets/kits available from Librands come with bolts that are assembled in pairs with the heads linked by stainless steel strip. So the bolts are inserted from inside, and the nuts are on the outside. The internal trim is pinned or stapled to the floor. I just removed the staples, lifted the trim and drilled the holes and inserted bolts from inside. I did put a bit of padding over the bolt heads to prevent the heads damaging the trim. I removed the seats before starting the work.
--------------------------- Mike Smith
1995 +8 2007 +4
Re: exhaust hanger
[Re: B3MOG]
#683901
18/01/21 06:27 PM
18/01/21 06:27 PM
teknome
Sandhurst, Berks
Thank you all for the replies, it has been helpful.
teknome, the brackets from Librands do not come with the bolts welded to a strip. (cost cutting)?
David Byrne I have to admit I did buy mine a few years ago, times must be hard in order to remove a critical feature, or maybe it is a lack of knowledge regarding how the product is used
1995 +8 2007 +4
Re: exhaust hanger
[Re: teknome]
#683970
19/01/21 08:06 AM
19/01/21 08:06 AM
Arwyn Williams
David Byrne I have to admit I did buy mine a few years ago, times must be hard in order to remove a critical feature, or maybe it is a lack of knowledge regarding how the product is used When I made my brackets up, the cost of the bolts/strip element was about 5 quid including the stainless welding. Arwyn
