7 registered members (Barkingdog, Graham, G4FUJ, Bonesie, Ian Wegg, Riverstar, Socalm3w, sprinty), 137 guests, and 20 spiders.
John V6 305
+8Rich 296
TBM 146
Peter J 142
morgan service needed in west sussex
by Nick55. 07/03/21 07:21 PM
Tri Bar Lights
by Craig Jezz. 07/03/21 06:14 PM
1992 Plus 8 5 mph Bumper Removal
by Rex. 07/03/21 05:00 PM
REPLACEMENT FRONT INDICATOR LIGHTS
by Steve19. 07/03/21 02:45 PM
+4 brake disc removal
by g2gsoon. 07/03/21 08:11 AM
Selling up :-(
by Bonesie. 07/03/21 06:29 AM
occasional starting during winter?
by HalfFull. 06/03/21 06:52 PM
Skiing in Scotland
Some pics
More Lock-Down slides
Gearbox oil check 2nd attempt at pics
Checking gear box oil
andypandy, BearDee, Gerorge4+41998, Daniel O, Louis
7408 Registered Users
Topics40,647
Posts679,361
Members7,408
Most Online1,033
Dec 28th, 2019
No Birthdays
Mystery Wire #683752
17/01/21 11:36 PM
17/01/21 11:36 PM
Granville, Ohio, USA
O
OhioM3W Offline OP
OhioM3W  Offline OP
O
So I was changing the oil and next to the filter i discover a wire hanging down after I changed the oil filter. Everything looks to be in order - nothing exposed - but this thing is hanging. I can push it in to a nut just outside the filter but it doesn’t feel right. And it’s not threaded. Any thoughts? Can’t figure out how to post a photo small enough to share 😩
Re: Mystery Wire [Re: OhioM3W] #683755
17/01/21 11:49 PM
17/01/21 11:49 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Post your question on Facebook on the Thre Wheeler forum, photos are waaaaay more easy.
Re: Mystery Wire [Re: OhioM3W] #683776
18/01/21 09:28 AM
18/01/21 09:28 AM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
The wire could be the oil pressure sensor wire as it is next to the filter. In the photo (this isn't quite like the standard set up as it has a sandwich plate) the pressure switch is the silver and black item at about 4 o'clock in relation to the filter housing, with a wire going to it. If it is disconnected the oil pressure light will not operate correctly. For info there is a section on posting photos in the "Welcome Forum" at the top
Re: Mystery Wire [Re: OhioM3W] #683784
18/01/21 09:48 AM
18/01/21 09:48 AM
Lincolnshire, the hilly bit!
hugo Offline
hugo  Offline
I would think it is the oil pressure switch, i broke mine when changing the filter
2012 M3W
1981 Lambretta GP225
1955 James Trials
2015 Scomadi 125
Re: Mystery Wire [Re: OhioM3W] #683800
18/01/21 10:50 AM
18/01/21 10:50 AM
Hertfordshire
O
Obie Offline
Obie  Offline
O
Hertfordshire
That's why i switched over to using the KN-171B filter listed in Planenuts alternative parts list as it has a nut on the end so removing is easy.
Re: Mystery Wire [Re: OhioM3W] #683801
18/01/21 11:31 AM
18/01/21 11:31 AM
O
OhioM3W Offline OP
OhioM3W  Offline OP
O
Thanks. That’s definitely it. It looks like everything is hooked up correctly but the whole steep just needs a place to live, and I must have knocked it off while changing the oil filter like Hugo. I think even taping it would work. Hugo?
Re: Mystery Wire [Re: OhioM3W] #683816
18/01/21 12:31 PM
18/01/21 12:31 PM
hugo Offline
hugo  Offline
I had to replace the oil pressure switch as the nut had snapped off and the spring had come out swear
2012 M3W
1955 James Trials
2015 Scomadi 125
Re: Mystery Wire [Re: OhioM3W] #683835
18/01/21 01:16 PM
18/01/21 01:16 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
I relocated the oil pressure switch by putting in a grease gun flex line and then mounting the switch to the frame members. It gave more room around the filter and it also allowed for an oil pressure gauge sender to be installed.
This was my crude test to see how well it worked with the massive oil pressure sender that came with my gauge. I need to find a smaller sender.
