14 registered members (Jon G4LJW, Red3W, RJW, PaulJ, RedThree, TBM, HJF, tommog, Ian Wegg, mph, jrt, The Austrian, Jens, Robbie), 173 guests, and 20 spiders.
John V6 310
+8Rich 284
Peter J 174
Maintenance Day
by Saxonian. 21/04/21 08:27 AM
How many Morgan 3 Wheelers left to be made?
by Red3W. 21/04/21 07:23 AM
maybe the era hasnt ended.
by howard. 21/04/21 06:58 AM
Brake pads Roadster 3,7
by Mats. 21/04/21 06:51 AM
Headlight bezel
by Tim Caddey. 20/04/21 10:19 PM
Bonnet hinge 97 +8
by Fus969. 20/04/21 06:06 PM
Advice re hardtop front mountings, please
by vbalddave. 20/04/21 09:36 AM
Lap of the Cairngorms
2017 Sport Blue M3W
Front spoiler
My M3W
Spring has sprung at Hintlesham...
tony1966, Grahameeyore, Animal, prf, Morgs52
7485 Registered Users
Topics41,048
Posts686,999
Members7,485
Most Online1,033
Dec 28th, 2019
Kurt
exhaust hanger #683662
17/01/21 03:34 PM
17/01/21 03:34 PM
north yorkshire
B3MOG Offline OP
B3MOG  Offline OP
north yorkshire
I am in the process of fitting a different exhaust (bigger bore) I need to fit another "L" shaped support bracket but I assume the bracket bolts through the chassis, so how do you get to the nuts on the inside of the car, I suppose you have to remove the interior sill trim? but what is actually behind the leather is it just padding or is there some plywood bulking it out?
Or is it better to just use rivnuts ?
Any photos of the sill area please.
Its a 1985 +8
David Byrne
Re: exhaust hanger [Re: B3MOG] #683680
17/01/21 04:48 PM
17/01/21 04:48 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
It is padding.
GoMog sills
but aren't the bolts further in board ?
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: exhaust hanger [Re: B3MOG] #683684
17/01/21 04:54 PM
17/01/21 04:54 PM
Arwyn Williams Offline
You will need to peel back the sill trim
When I made the brackets up for my Plus 4, I welded the two stainless bolts to a piece of stainless steel strip and had the nuts (nyloc) on the outside of the chassis. This meant that you could check for tightness without having to strip the interior of the car
Not sure using riv nuts would be practical as they are too soft.
Arwyn
Re: exhaust hanger [Re: B3MOG] #683687
17/01/21 05:11 PM
17/01/21 05:11 PM
Salisbury, England
DaveK Offline
DaveK  Offline
Salisbury, England
Many thanks for the GoMog link. A few years back I bought some sills covers which I will be fitting.
Navy Dave
1976 Morgan 4/4
Re: exhaust hanger [Re: B3MOG] #683693
17/01/21 05:24 PM
17/01/21 05:24 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Dave how is the covid? Are you getting better?
Re: exhaust hanger [Re: Arwyn Williams] #683719
17/01/21 07:53 PM
17/01/21 07:53 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Arwyn
That's effectively what the factory use on later cars. Two studs welded to captive plate and inserted from the inside of chassis rail to take nuts on the outside. Probably a PIA to remove though, although replacing the L shaped exhaust support from the outside would be easy.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: exhaust hanger [Re: B3MOG] #683743
17/01/21 10:35 PM
17/01/21 10:35 PM
Sandhurst, Berks
teknome Offline
teknome  Offline
Sandhurst, Berks
The brackets/kits available from Librands come with bolts that are assembled in pairs with the heads linked by stainless steel strip. So the bolts are inserted from inside, and the nuts are on the outside. The internal trim is pinned or stapled to the floor. I just removed the staples, lifted the trim and drilled the holes and inserted bolts from inside. I did put a bit of padding over the bolt heads to prevent the heads damaging the trim. I removed the seats before starting the work.
Mike Smith
1995 +8
2007 +4
Re: exhaust hanger [Re: B3MOG] #683854
18/01/21 02:48 PM
18/01/21 02:48 PM
north yorkshire
B3MOG Offline OP
B3MOG  Offline OP
north yorkshire
Thank you all for the replies, it has been helpful.
teknome, the brackets from Librands do not come with the bolts welded to a strip. (cost cutting)?
old stainless system will be put up for sale later (manifolds to tailpipe)
David Byrne
Re: exhaust hanger [Re: B3MOG] #683901
18/01/21 06:27 PM
18/01/21 06:27 PM
Sandhurst, Berks
teknome Offline
teknome  Offline
Sandhurst, Berks
David Byrne
I have to admit I did buy mine a few years ago, times must be hard in order to remove a critical feature, or maybe it is a lack of knowledge regarding how the product is used
Mike Smith
1995 +8
2007 +4
Re: exhaust hanger [Re: teknome] #683970
19/01/21 08:06 AM
19/01/21 08:06 AM
David Byrne
When I made my brackets up, the cost of the bolts/strip element was about 5 quid including the stainless welding.
Arwyn
