24 registered members (Dean-Royal, BobJ, Jan_1, Alan Patterson, TBM, merlin123, Alan_Bass, JMT, Jeff D, RobCol, Dada, HawkMog, 2017 Betty, westgardronning, Peter J, Spanner Juggler, RichardV6, DavidR, Hamwich, Plus4, stefan s, RedThree, DCH, V8Dave), 230 guests, and 19 spiders.
+8Rich 387
John V6 303
TBM 149
Peter J 137
Switches
by Lance. 27/02/21 06:09 PM
UK Vaccinations now available to all over 60s
by Hamwich. 27/02/21 05:40 PM
Hannu Mikkola
by +8Rich. 27/02/21 03:08 PM
Electrical questions : 1934 3 wheeler Super Spo
by patrickt. 27/02/21 01:07 PM
Fuel Guage
by Chiltern. 27/02/21 11:31 AM
Vintage Morgan forum?
by merlin123. 27/02/21 09:31 AM
Spain ferry
by Image. 27/02/21 09:12 AM
Gearbox oil check 2nd attempt at pics
Checking gear box oil
French collection
Visiting France
Winter in Puy de Dôme
Rosenlid, Chiltern, Gorgounet, Dinko, Garagehelp
7397 Registered Users
Topics40,582
Posts678,077
Members7,397
Most Online1,033
Dec 28th, 2019
GJT, Theo69
exploded compressor vid. #683919
18/01/21 07:59 PM
18/01/21 07:59 PM
Luddite Offline OP
Luddite  Offline OP
I thought to post this URL of a vid taken showing the aftermath of a compressor which exploded, perhaps as the result of internal corrosion weakening the tank. The compressor tank in the vid is similar to many inexpensive compressors of the type that may be purchased by car enthusiasts for home use.
https://youtu.be/sm_FJ6Pat4I
Re: exploded compressor vid. [Re: Luddite] #683930
18/01/21 08:34 PM
18/01/21 08:34 PM
Dorset, UK
milligoon Offline
milligoon  Offline
Dorset, UK
I wonder if people who have them at home ever bother getting them checked?
In the UK work places have to abide by the following
https://www.hse.gov.uk/pUbns/priced/l122.pdf
Mark - No Longer driving
Re: exploded compressor vid. [Re: Luddite] #683931
18/01/21 08:39 PM
18/01/21 08:39 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
From the comments, including the youtube posters reaction on some comments it appears that the air tank was welded, a dangerous repair of the rusted tank instead of throwing it away. This should not be done.
Re: exploded compressor vid. [Re: Luddite] #683936
18/01/21 08:58 PM
18/01/21 08:58 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
Horrific!. There is also the possibility that the pressure cut off switch may have been faulty? I regularly drain mine down to release trapped water but of course, who knows what the internal condition is like.
I used to work in the electricity supply industry and the air receivers fitted to compressed air operated 33kv switchgear had to have an internal visual inspection every 22 months for insurance purposes. Of course, they had a removeable end cap for access and were of a considerable thickness with a well painted interior.
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: exploded compressor vid. [Re: Luddite] #683937
18/01/21 09:05 PM
18/01/21 09:05 PM
howard Offline
howard  Offline
You can guess the internal state from the obvious corrosion and rust on the outside of the tank. Mine has a drain to the tank to allow you to get rid of the water that naturally condenses inside. I am sure that I drained it a few years ago as well as tomorrow.
Re: exploded compressor vid. [Re: Deejay] #683948
18/01/21 10:01 PM
18/01/21 10:01 PM
Renfrewshire
BobtheTrain Offline
BobtheTrain  Offline
Renfrewshire
I use one for the brad nailer I have in my woodworking shed. I open the valve after each use and leave it so that the valve is at the bottom for water egress.
Best Regards
Lang may yer lum reek
Re: exploded compressor vid. [Re: Luddite] #683954
19/01/21 12:08 AM
19/01/21 12:08 AM
Solihull
Spanner Juggler Online content
Spanner Juggler  Online Content
Solihull
Standard practice is to drain down each day of use and to drop the tank pressure to zero after use. The inside of the tank is normally just untreated mild steel so rust is a constant issue. As soon as rusty water comes out of an air gun I scrap the compressor, they are cheap enough so why take a risk. I used a 55 Ltr 16 CFM type for years for general garage use. Sufficient for most tools but not a CP DA sander which is air hungry.
BR
Colin
BR Colin
Re: exploded compressor vid. [Re: Luddite] #683962
19/01/21 06:15 AM
19/01/21 06:15 AM
Gloucestershire, UK
Hamwich Online content
Hamwich  Online Content
Gloucestershire, UK
Blimey, my compressor must be at least 25 years old, probably nearer 30. I think I'd better think about replacement. Does anyone know anything about ABAC compressors? Italian made, I'd rather avoid one of the cheapo Chinese jobs.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: exploded compressor vid. [Re: Luddite] #683967
19/01/21 07:51 AM
19/01/21 07:51 AM
North Yorks
John07 Offline
John07  Offline
North Yorks
I've had one for the past 30 or 35 years, I do drain it down once in a while. Did you notice how thin the tank was!! It just unzipped. And yes as Heinz said it looked as if it had been welded. I've seen one go at I site I was working on, but it was very badly rusted and it just started leaking from all the weak spots, not a problem at all.
The thing is a new one is liable to be even worse (cheaper) made than my 35 year old Italian one so will it be any safer?
Cheers
Re: exploded compressor vid. [Re: Luddite] #683974
19/01/21 08:45 AM
19/01/21 08:45 AM
East Anglia
madmax Offline
madmax  Offline
East Anglia
Need to look at a new compressor as mine has done a lot of work , machine mart/ sealeys etc , flag has been brilliant for spraying underseal on old cars , cleaning rust , air spannering , usual tyre jobs , lets find a really good one !
