Topics40,647
Posts679,360
Members7,408
Most Online1,033 Dec 28th, 2019
Main Beam Indicator (Blue)
#684234
20/01/21 04:31 PM
20/01/21 04:31 PM
Posts: 69 Sanderstead
Tim Crump
Sanderstead
I have a 2018 Plus4 The standard dash puts a set of tell tale indicators right in front of the driver. Hopefully when driving the only ones that light up are the turn signal and the main beam. They are very bright, probably LEDs During the day not a problem but at night the main beam indicator in particular which is the topmost one is almost blinding, to the extent that I rarely use main beam or have to drive with one hand at the 12 o'clock position on the steering wheel (not a good thing).
So suggestions please One would be to fit some neutral density filter sheet ?
Tim Plus 4 2018
Re: Main Beam Indicator (Blue)
[Re: Tim Crump]
#684238
20/01/21 05:07 PM
20/01/21 05:07 PM
Posts: 3,559 East Harling, Norfolk UK
A suitable resistor in series with warning light would dim it.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1960 Velocette Venom
[Re: Tim Crump]
#684245
20/01/21 05:44 PM
20/01/21 05:44 PM
Posts: 19,201 Suffolk
Suffolk
Or paint the bulb. I hate electricery
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
[Re: RichardV6]
#684250
20/01/21 05:57 PM
20/01/21 05:57 PM
Barry M
A suitable resistor in series with warning light would dim it. Or a potentiometer which would allow you to set the brightness you want. A bag of them is very cheap from RS Components.
[Re: Tim Crump]
#684283
20/01/21 09:01 PM
20/01/21 09:01 PM
Posts: 5,809 Köln Germany
Heinz
Köln Germany
...and on late 4/4 as well.
[Re: Tim Crump]
#684284
20/01/21 09:07 PM
20/01/21 09:07 PM
Posts: 297 North Yorks
John07
North Yorks
As I am in the middle of the dashboard upgrade I have access to all these parts, here is a pic on the light cluster. The Hi beam indicator is the centre one in the pic. Sticking tape or some other film over the light is about the only option. Like Tim I also think it's far too bright so I will be doing something before I put it all together again. Cheers John ![[Linked Image]](https://tm-img.com/images/2021/01/20/DSC03166rs.jpg)
[Re: Tim Crump]
#684354
21/01/21 11:22 AM
21/01/21 11:22 AM
Posts: 2,976 Co Wexford, Ireland
Robbie
Co Wexford, Ireland
I used a piece of Blue insulation tape - works well and still is blue when turned off!
Robbie 2018 Plus4 - Snoopy 181-WX-3082
