Topics40,647
Posts679,360
Members7,408
Most Online1,033 Dec 28th, 2019
Re: M3W Aero Racing Luggage Rack
[Re: Jonathan G]
#684634
22/01/21 04:09 PM
22/01/21 04:09 PM
Posts: 1,475 New River Valley, VA
rcmatt
Mine came with the MMC rack and it came with the clamp mounts and did not require any drilling.
[Re: rcmatt]
#684635
22/01/21 04:12 PM
22/01/21 04:12 PM
Posts: 64 Worcestershire
Jonathan G
Worcestershire
Rodger - was yours like the pics above?
2017 Morgan Roadster 2012 Morgan Three wheeler 2020 Land Rover Defender 110
[Re: Jonathan G]
#684639
22/01/21 04:22 PM
22/01/21 04:22 PM
Posts: 1,309 Near Windsor Berkshire
Rog G
Your rack is the original type supplied by MMC.
The brackets with the pins are bolted to the front of the rack. The other two brackets with length of tube welded to them are bolted through the roll hoops, you will need to drill the roll hoops to fit. The pins that you have bolted to the front of the rack then go into the tubes bolted to the roll hoops.
As Planenut says there are alternative ways to fit without drilling the roll hoops, using roll bar clamps or homemade clamps.
2013 M3W 1971 4/4 2 Seater 1934 Sports
[Re: Jonathan G]
#684642
22/01/21 04:37 PM
22/01/21 04:37 PM
Jonathan G
Worcestershire
Christ I don't fancy drilling. I will look at Mark H's solution first.
[Re: Jonathan G]
#684678
22/01/21 07:43 PM
22/01/21 07:43 PM
Posts: 35 Gloucestershire
2to3wheels
Gloucestershire
I bought the later clamp fitting rack. Not impressed. The angles bored through the clamp halves did not match the angle of the roll hoops. When the clamps were tightened the sliding dowels for the quick release locked solid. Only way to make the quick release system work, leaving the clamps tight on the roll hoops, was to drill the two outer dowel holes from 8mm to 10mm. Not what you expect for an accessory costing over £1000. (Dealer wanted an extra £80 to fit it - I now understand why). I always thought Harley accessories were expensive, but at least they fit.
2to3wheels 2016 M3W 2016 Harley Road King 2015 Triumph Bonneville 2013 Land Rover County 110
