24 registered members (Dean-Royal, BobJ, Jan_1, Alan Patterson, TBM, merlin123, Alan_Bass, JMT, Jeff D, RobCol, Dada, HawkMog, 2017 Betty, westgardronning, Peter J, Spanner Juggler, RichardV6, DavidR, Hamwich, Plus4, stefan s, RedThree, DCH, V8Dave),
230
guests, and 19
spiders. |
Topics40,582
Posts678,077
Members7,397
Most Online1,033 Dec 28th, 2019
Re: Rad Work
[Re: Treesurveyor]
#685122
25/01/21 06:17 PM
25/01/21 06:17 PM
Posts: 4,952 Llanelli
Ray
Llanelli
Never trusted the fitting on my 79 +8 ,rigged up a couple of cable ties to secure it.
Re: Rad Work
[Re: Treesurveyor]
#685126
25/01/21 06:40 PM
25/01/21 06:40 PM
Posts: 230 Cotswolds
Treesurveyor
Cotswolds
This one had a metal spring affair. To be honest, it would have been entirely sensible to have waited for everything to cool down before investigating , but far less dramatic!
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Re: Rad Work
[Re: Treesurveyor]
#685128
25/01/21 06:46 PM
25/01/21 06:46 PM
Posts: 19,123 Suffolk
Suffolk
Glad you weren't hurt & that it is fixed
JohnV6 2006 Indigo Blue Roadster S1 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Rad Work
[Re: Treesurveyor]
#685132
25/01/21 07:01 PM
25/01/21 07:01 PM
Treesurveyor
Cotswolds
Thanks John, I did sustain stupidity blisters, but I self patched and got on with it. The rads at the fabricators, their man's not in until tomorrow, so a few more days yet. Typical that this would happen two days before the MOT booking.
Re: Rad Work
[Re: Treesurveyor]
#685137
25/01/21 07:33 PM
25/01/21 07:33 PM
Treesurveyor
Cotswolds
Grommet, that's the word I was searching for, thanks Luddite 😊 I've read a fair bit on it, and decided to go for the threaded conversion. I think it widens up the options too as far as future replacements go. I think my bottom fitting was rated on at 99degrees c, at least it never came on below 100 on the temp gauge although I'm aware that's not necessarily accurate. If I put a 15mm threaded bung in, I can experiment with on temperatures. Never had a problem with overheating per say, as the fan always kicked in between 100 and 105 on the guage. If anything, I've always thought it runs a bit on the cool side. I've set up the override switch, and am happy with that function for backup. Just need to splice in some fresher cable for the relay loop now.
Re: Rad Work
[Re: Treesurveyor]
#685139
25/01/21 08:14 PM
25/01/21 08:14 PM
SimonH
The threaded bungs I weld into my radiators have an M22x1.5 thread This opens up a huge variety of fan switches and temperatures
I fit them in the top tank in most cases, and supply a 98/93 thermoswitch in with the radiator kit I prefer the fan switch to see the highest temperature- IE when the coolant leaves the engine rather than the lower temperature coolant after it’s passed through the radiator If I fit the bung in the bottom tank I supply a lower switching thermoswitch (93/88 from memory)
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: Rad Work
[Re: Treesurveyor]
#685140
25/01/21 08:22 PM
25/01/21 08:22 PM
Posts: 1,487 Oxon
Craig Jezz
Oxon
Wouldn’t this be the time to off set the costs and invest in a new aluminium radiator, I believe they are more efficient and less chance of overheating ?
I’m very pleased with my SiFab one, looks good to
Craig Jezz
Morgan 4/4 Sports Sand
