20 registered members (britmog, nick w, Graham, G4FUJ, Stevo666, hugo, KennethM, TimB, NeilM, mph, paulmog, kankeL, RJW, Heinz, teifistar, Ian Wegg, TBM, CasaLobo, AndyrIch, ShaunD, Robbie), 167 guests, and 17 spiders.
+8Rich 351
John V6 309
TBM 164
Peter J 139
Royal Mail again.
by DaveW. 04/03/21 02:07 PM
Moving seat belt mount?
by TBM. 04/03/21 11:35 AM
Bangers & Cash
by Ian Wegg. 04/03/21 10:04 AM
Air Filters..What can you still get?
by NickCW. 04/03/21 09:06 AM
Not too bad, this landing of SN10.
by Heinz. 04/03/21 02:21 AM
Stolen! 4 seater DHC
by morgan_75. 04/03/21 12:32 AM
broke the carburetor
by 2017 Betty. 04/03/21 12:05 AM
Some pics
More Lock-Down slides
Gearbox oil check 2nd attempt at pics
Checking gear box oil
French collection
Rosenlid, Chiltern, Gorgounet, Dinko, Garagehelp
7397 Registered Users
Topics40,620
Posts678,798
Members7,397
Most Online1,033
Dec 28th, 2019
Alexuels, HBPH, ticktock
Replacement door hinge fasteners #685614
28/01/21 02:32 PM
28/01/21 02:32 PM
JimV6 Offline OP
JimV6  Offline OP
Hi
Does anyone know who can supply replacement stainless steel door hinge socket screws. Tried Heart of England but they only have slotted head.
Thanks
Re: Replacement door hinge fasteners [Re: JimV6] #685622
28/01/21 03:26 PM
28/01/21 03:26 PM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
I think you might find it a bit tricky to get M6 CSK Cap screws in the correct length for the hinges. I replaced mine a few years ago and went for slotted heads simply because the place I buy my fasteners from (Namrick) could only supply max lengths of 70mm in capscrew format whereas they can do slotted screws up to 100mm.
But as I don't need to remove my doors very often (I think I've done it 3 times in 20 years) the idea of using slotted head screws didn't bother me.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: Replacement door hinge fasteners [Re: JimV6] #685627
28/01/21 03:44 PM
28/01/21 03:44 PM
Derby
PhilRoyle Offline
PhilRoyle  Offline
Derby
I got mine from Accu - they have a good selection - but they are UNC - Morgan use Whitworths - but they still go in with a bit of persuasion. They do come out a bit proud of the hinge - but it does not seem to affect it. If it did it would be a simple job to countersink the holes in the hinges a tad more.
Re: Replacement door hinge fasteners [Re: PhilRoyle] #685629
28/01/21 04:03 PM
28/01/21 04:03 PM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
That's why I switched to metric, a bit smaller than the originals so fit in easier.
Re: Replacement door hinge fasteners [Re: JimV6] #685649
28/01/21 05:33 PM
28/01/21 05:33 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
https://www.westfieldfasteners.co.uk/A2_ScrewBolt_PhilCsk_M6.html
I use Westfield. They do a s/s M6 x 100mm countersunk set screw.
A good site and they do a range types of metric/ non metric sizes and have a dimensions guide for head diameter/ angle
Red Plus8
Re: Replacement door hinge fasteners [Re: JimV6] #685720
29/01/21 08:03 AM
29/01/21 08:03 AM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
¼" UNC x 2" stainless csk socket bolts available here, just scroll down list to select thread size and length.
The same 20 threads per inch as OE BSW door bolts but slightly different thread angle of 60° v 55° of BSW. They should fit OE nuts or you could change to matching UNC.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Replacement door hinge fasteners [Re: RichardV6] #685722
29/01/21 08:19 AM
29/01/21 08:19 AM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
I think you need them a bit longer than 2" don't you? I just checked my order and it was for 70mm x M6 CSK, but it was back in 2018 and I honestly don't recall if I had to shorten them at all. I confess I always switch to metric fasteners wherever possible, it makes tooling easier, but I appreciate that some prefer to maintain original specs.
Re: Replacement door hinge fasteners [Re: JimV6] #685731
29/01/21 09:37 AM
29/01/21 09:37 AM
RichardV6 Offline
RichardV6  Offline
Two inch is the length from latest Classics parts book Tim but that assumes no mistakes wink
Re: Replacement door hinge fasteners [Re: JimV6] #686437
01/02/21 08:40 PM
01/02/21 08:40 PM
JimV6 Offline OP
JimV6  Offline OP
Thanks for your quick responses. Will investigate further.
Re: Replacement door hinge fasteners [Re: JimV6] #686440
01/02/21 08:56 PM
01/02/21 08:56 PM
JimV6 Offline OP
JimV6  Offline OP
Follow up question. Does the screw go into a captive or caged nut. Just wondering how the screw is retained. Thanks for your feedback.
