17 registered members (linklaw, John07, SimonH, Alwlo, Jon G4LJW, JohnHarris, BLUE+4, HeadlessBlue, Luddite, KennyW, dmh, Spanner Juggler, Jens, AndyrIch, CasaLobo, Ritchie B, Trevor v), 173 guests, and 19 spiders.
John V6 310
+8Rich 285
Peter J 174
Maintenance Day
by Saxonian. 21/04/21 08:27 AM
How many Morgan 3 Wheelers left to be made?
by Red3W. 21/04/21 07:23 AM
maybe the era hasnt ended.
by howard. 21/04/21 06:58 AM
Brake pads Roadster 3,7
by Mats. 21/04/21 06:51 AM
Headlight bezel
by Tim Caddey. 20/04/21 10:19 PM
Bonnet hinge 97 +8
by Fus969. 20/04/21 06:06 PM
Advice re hardtop front mountings, please
by vbalddave. 20/04/21 09:36 AM
Lap of the Cairngorms
2017 Sport Blue M3W
Front spoiler
My M3W
Spring has sprung at Hintlesham...
tony1966, Grahameeyore, Animal, prf, Morgs52
7485 Registered Users
Topics41,048
Posts687,002
Members7,485
Most Online1,033
Dec 28th, 2019
Kurt
Page 4 of 5 1 2 3 4 5
Re: New Steering Wheel & Spacer - Thoughts [Re: JohnMat] #690450
23/02/21 07:56 PM
23/02/21 07:56 PM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
Originally Posted by JohnMat
Originally Posted by Chris99
It's a RAM 1” tough-ball, M6-1 fitting. RAM-RAP-B-379U-M616 which for the standard dash fits into one of the M6 dash panel mounting holes. You'll need to check if there's a suitable bolthole you can use for the Heritage dash.
It works well with the heritage dash, same size bolts. If you look in my photos you can see my sunglasses hanging from the RAM ball.
I did have to use Loctite to stop it coming loose.
thumbs
Red Leader drive
Re: New Steering Wheel & Spacer - Thoughts [Re: GregA10] #690466
23/02/21 10:15 PM
23/02/21 10:15 PM
Altrincham UK
GregA10 Offline OP
GregA10  Offline OP
Altrincham UK
I have in fact been wanting that solution, but had not found the exact parts to do it. I’ll consider that a kick to the backside wink
I’ll forego the clock for now. Love the look of it but already have one on the digital display so seems a bit superfluous.
Re: New Steering Wheel & Spacer - Thoughts [Re: Chris99] #690495
24/02/21 09:32 AM
24/02/21 09:32 AM
Oxon
PaulV Offline
PaulV  Offline
Oxon
Originally Posted by TimG
...also has a clock mounted in front of the wheel as I have....
https://www.ram-mount.co.uk/components/ball-size-a-b-c-d-e-2/
The clock is simply stuck on with velcro: https://time4bikes.com/British-Made-VerSa-Darkside-Billet-Casing-with-Black-Clock
I forget who suggested it, but the bolt-in dash clock holder is
https://www.ebay.co.uk/itm/Clip-for-1-Stopwatch/123865766407 - I think I needed to use a longer bolt though!
I use the following clock to fit. Really its a watch face but does the job!
https://www.ebay.co.uk/itm/Premium-...sert-movement-for-52mm-hole/292617518167
The analog clock I find useful as the tonneau makes the digital miniclock difficult to read (and really I need to be watching the road not studying some tiny dash display!).
Re: New Steering Wheel & Spacer - Thoughts [Re: GregA10] #690523
24/02/21 12:47 PM
24/02/21 12:47 PM
Madrid, Spain
Marmota Offline
Marmota  Offline
Madrid, Spain
GregA10 check for the exact part numbers here: https://www.speedymarmots.com/works-6-phone-mount/ cheers
Re: New Steering Wheel & Spacer - Thoughts [Re: Marmota] #690532
24/02/21 01:36 PM
24/02/21 01:36 PM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
But why buy the RAM ball with the female socket and then have to cut a bolt when you can buy the RAM version with a bolt?
Red Leader drive
Re: New Steering Wheel & Spacer - Thoughts [Re: GregA10] #690537
24/02/21 02:39 PM
24/02/21 02:39 PM
M3W55 Offline
M3W55  Offline
Bear in mind that the above advice is for a mount to fit Garmins. The Alternative Parts List has a source for the smaller threaded ball to fit TomToms. I cut the head off a 6" bolt which we substituted for the LH lower dashboard fixing screw. We secured it with a 15mm long nut and screwed the ball onto the other end. Simple.
Re: New Steering Wheel & Spacer - Thoughts [Re: GregA10] #690541
24/02/21 02:43 PM
24/02/21 02:43 PM
Las Vegas
JohnMat Offline
JohnMat  Offline
Las Vegas
Here’s the Ram type ball I used on Amazon.
It comes with M6 longer bolts, but is not Ram branded.
2020 M3W
Re: New Steering Wheel & Spacer - Thoughts [Re: Chris99] #690548
24/02/21 03:07 PM
24/02/21 03:07 PM
Madrid, Spain
Marmota Offline
Marmota  Offline
Madrid, Spain
I remember there is a M6 version. But it's just 6mm long. The screws of our dashboards are 20 mm (standard) or 35 mm (heritage). That's why I did not used the M6x6mm RAM ball. As this ball will be holding a large smartphone and under heavy vibrations, a long thread with locktite is IMHO needed. With 6 mm thread insert, I bet this ball will get loose permanently.
Re: New Steering Wheel & Spacer - Thoughts [Re: Marmota] #690600
24/02/21 06:43 PM
24/02/21 06:43 PM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
On mine the RAM ball had a through hole and came with 3 different length M6 bolts - the longest of which was good for the standard dash.
The RAM parts list is a bit of a minefield!
Red Leader drive
Re: New Steering Wheel & Spacer - Thoughts [Re: GregA10] #690865
26/02/21 04:25 PM
26/02/21 04:25 PM
2017 Betty Offline
2017 Betty  Offline
I love the look of a wooden steering wheels but i also like the feel of the softer standard wheel.
So my first attempt was to dress it up with the center hub. So far I like the look. Much better than looking at three screw heads.
Tim[Linked Image]
