18 registered members (Alistair, Matt C, kankeL, Mike D, Barrythebrave, atalante83, Supamog, Robbie, griffo, Jep, PJC, Image, CooperMan, Ian Wegg, HeadlessBlue, RichardV6, RB1, nippymog), 171 guests, and 21 spiders.
John V6 308
+8Rich 283
Peter J 177
Sport Steering Wheel
by PhilRoyle. 21/04/21 12:16 PM
Maintenance Day
by Saxonian. 21/04/21 08:27 AM
How many Morgan 3 Wheelers left to be made?
by Red3W. 21/04/21 07:23 AM
maybe the era hasnt ended.
by howard. 21/04/21 06:58 AM
Brake pads Roadster 3,7
by Mats. 21/04/21 06:51 AM
Headlight bezel
by Tim Caddey. 20/04/21 10:19 PM
Bonnet hinge 97 +8
by Fus969. 20/04/21 06:06 PM
Lap of the Cairngorms
2017 Sport Blue M3W
Front spoiler
My M3W
Spring has sprung at Hintlesham...
tony1966, Grahameeyore, Animal, prf, Morgs52
7485 Registered Users
Topics41,049
Posts687,034
Members7,485
Most Online1,033
Dec 28th, 2019
Kurt
Silicone Brake fluid - Holy Grail #690477
24/02/21 08:13 AM
24/02/21 08:13 AM
UK
BuyBritish Offline OP
UK
Currently I have the standard DOT4 hydroscopic (absorbs water, damages by rust brake components etc) also damages paintwork!
I've the opportunity to upgrade to Silicone which has so many advantages so it looks they way to go
Any advice TMers?
Some more reading reveals that it has some serious cons to think about
It is more compressible so not as hard fell on actuating brakes
It is more viscous so bleeding is more difficult
Due to being more viscous the pads have a delayed 'on' braking effect as the fluid vacates the cylinder after brake release.
So lots to think about...
Rob Davies
Morgan 3 Wheeler 1934 MX
Morgan Series 1 1947
Morgan +4 1956 TR4
Morgan +4 2000 T16 Rov
Re: Silicone Brake fluid - Holy Grail [Re: BuyBritish] #690479
24/02/21 08:23 AM
24/02/21 08:23 AM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
This topic, like waterless coolant, has been discussed a number of times.
If I recall correctly silicone fluid can only be filled into an all new system, it cannot be used to replace DOT 4 fluid. It is also incompatible with some older rubber materials and doesn't lubricate as well as DOT 4.
It is also expensive.
In my opinion it is better to change the DOT 4 brake fluid every year!
Any other thoughts, team?
V8s are best....
Tarka the 'Otter Mog....2014 Plus 8
AMG C63 Estate.
Re: Silicone Brake fluid - Holy Grail [Re: BuyBritish] #690481
24/02/21 08:30 AM
24/02/21 08:30 AM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
And DOT 4 (like 3) is hygroscopic not with a "D" - a common mis-spelling.
As Peter says, just change fluid on a regular basis...
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'06 Saab 9-3 Convertible
Re: Silicone Brake fluid - Holy Grail [Re: BuyBritish] #690484
24/02/21 08:37 AM
24/02/21 08:37 AM
UK
UK
Yes agree looks best option is to stay glycol based and change every year see my other edit in earlier message
Here is the reason for my not liking corrosion on a morgans rear brake cylinder, it has 2 pistons only one side working ...so it passed its MOT with this...
[Linked Image]DSC_0339 by Robert & Ali Davies, on Flickr
Rob Davies
Morgan +4 1956 TR4
Re: Silicone Brake fluid - Holy Grail [Re: BuyBritish] #690489
24/02/21 09:07 AM
24/02/21 09:07 AM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
Agree with everyone else on this. Dot 4 changed regularly.
As far as rusting is concerned, I don’t think that the hygroscopic fluid is totally to blame. When you go through a puddle, water is easily able to enter the brake drum. Many people who have suffered corroded cylinders seem to have it most commonly on the nearside (where puddles are most prevalent on the roadside. )
Also, when parked up, moisture can condense inside the drum as it cools. If not driven for a while, I sometimes hear a rear brake squeak going down my driveway but it soon disappears as surface rust rubs off.
For longevity, when fitting new cylinders best to peel back the rubber boot and pack with Ceretec grease or similar, something manufacturers often fail to do.
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: Silicone Brake fluid - Holy Grail [Re: BuyBritish] #690493
24/02/21 09:23 AM
24/02/21 09:23 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Rob,
I agree with DOT4 changed annually with greasing of the rear pistons. If Belle is parked up for a long time in the garage I also chock the wheels & let off the handbrake.
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Silicone Brake fluid - Holy Grail [Re: BuyBritish] #690498
24/02/21 09:55 AM
24/02/21 09:55 AM
London
MOG 615 Offline
MOG 615  Offline
London
Bob
As a chemist involved in brake fluid production for a few years (admittedly about 20 now!) please don't use silicone brake fluid in an old system.
It does have applications in brand new systems, but the two fluids are totally incompatible, and the smallest trace of old glycols/glycol ethers/glycol ether esters are going to render the silicone system very compromised.
It really isn't a big job to change brake fluids regularly, so that it is by far the best option for us.
Yes , there are several disadvantages with the glycol etc based systems , only some of which you have highlighted, but silicones are also not without their problems.
Although DoT 4 is hygroscopic (thank you Graham), it should last at least 2 years in our applications, although an annual change won't hurt anything (except your wallet)
DoT 3 fluid is less hygroscopic, but the boiling point is lower, however for light cars like Morgans it is probably more than good enough, but DoT 4 is a good compromise between the cheaper DoT 3 and the much more hygroscopic (but even higher boiling) DoT 5.1
Andy G
1999 +8 , Indigo Blue.
Re: Silicone Brake fluid - Holy Grail [Re: BuyBritish] #690502
24/02/21 10:27 AM
24/02/21 10:27 AM
UK
UK
Thank you...so what to use for the caliper and lubrication to rubber parts on the pistons please? any recommendations
Rob Davies
Morgan +4 1956 TR4
Re: Silicone Brake fluid - Holy Grail [Re: BuyBritish] #690505
24/02/21 10:46 AM
24/02/21 10:46 AM
Llanelli
Ray Offline
Ray  Offline
Llanelli
I had silicone in my old+8 , done by the previous owner. I owned the car for 18 years. Never had any problems with the brakes apart from wear to the pads.approx 4000 miles a year.
Re: Silicone Brake fluid - Holy Grail [Re: BuyBritish] #690514
24/02/21 11:33 AM
24/02/21 11:33 AM
Salisbury, UK
Peter J Offline
Peter J  Offline
Salisbury, UK
Another comment, dragged out of my bike days memory, is to replace all the flexible hoses with Aeroquip or similar high spec lines: it was believed that most of the moisture got into the fluid through the hose walls.. No idea if it is true, but on a bike braided hoses with nicely anodised couplings look so cool...
V8s are best....
AMG C63 Estate.
