22 registered members (DJC, esse16, petemog, westgardronning, John Winn, Marius, TBM, Bunny, Stevo666, ajsms999, MikeFromPembroke, Mogdavid, Image, IcePack, MarkR, Malcolm T, yobtaf, RJW, Paul F, M3W55, Bobajobbob, How),
166
guests, and 19
spiders. |
Topics41,049
Posts687,012
Members7,485
Most Online1,033 Dec 28th, 2019
Floor
#690267
22/02/21 03:59 PM
22/02/21 03:59 PM
Posts: 1,552 Purton, nr Swindon UK
rainbowj
Does anyone happen to know how thick the wooden floor be on a '92 plus4. I want to fit an organ pedal.
John 1992 plus4 connaught green
Re: Floor
[Re: rainbowj]
#690377
23/02/21 11:36 AM
23/02/21 11:36 AM
Posts: 202 Ross-on Wye, Herefordshire
bilibib
Does anyone happen to know how thick the wooden floor be on a '92 plus4. I want to fit an organ pedal. It should be 3/8" {10mm) marine ply
Owen "bilibib" 1982 4/4 Twin Cam Royal Ivory, Dark Red Leather
Re: Floor
[Re: rainbowj]
#690457
23/02/21 09:13 PM
23/02/21 09:13 PM
rainbowj
Thanks. How is the organ pedal normally secured to the floor. I could use straight through nut and bolts with penny washers on underside. Just wondered if there was an " accepted way".
Re: Floor
[Re: rainbowj]
#690473
24/02/21 07:18 AM
24/02/21 07:18 AM
Posts: 321 Bergen, Norway
Robbie Mathisen
Bergen, Norway
Are you sure you want to fit an organ pedal? You will be introducing one more mechanical piece, with it's own movement - the little roller sliding up and down underneath the pedal as you press/loosen the pedal. I have no personal experience, but I suspect it might feel a little less direct, and some someone here on TM mentioned that he has removed it due to stiction in the sliding movement. Looks good, though. Why not check out the pedal made by Cain Poulton at Wolf Performance? He makes a complete set of adjustable pedals, but you can also get the accelerator pedal separately. Would have been my choice. Or will be, most likely. I think the OEM roller pedal works, but the surface is a little small, and feels uncomfortable through the sole of my shoe after a long drive.
Robbie the Norseman 2004 V6 Roadster Sherwood green
Re: Floor
[Re: rainbowj]
#690483
24/02/21 08:37 AM
24/02/21 08:37 AM
Posts: 19,655 Suffolk
Suffolk
I have had cars with both & frankly found no difference.
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Floor
[Re: John V6]
#690507
24/02/21 11:02 AM
24/02/21 11:02 AM
Posts: 5,007 Llanelli
Ray
Llanelli
I have had cars with both & frankly found no difference. . Same here except for an annoying click from the organ peddle when you took your foot off it.
Re: Floor
[Re: rainbowj]
#690509
24/02/21 11:06 AM
24/02/21 11:06 AM
rainbowj
I thought the main reason for fitting an organ pedal was to facilitate heel and tow braking. Is this wrong.
