16 registered members (Saxonian, JMcL, HeadlessBlue, IcePack, milligoon, Spanner Juggler, SimonH, mph, Alan Patterson, Jads, TBM, Robbie Mathisen, R1NGA, SFO, Rog G, John07), 158 guests, and 18 spiders.
John V6 310
+8Rich 284
Peter J 175
Maintenance Day
by Saxonian. 21/04/21 08:27 AM
How many Morgan 3 Wheelers left to be made?
by Red3W. 21/04/21 07:23 AM
maybe the era hasnt ended.
by howard. 21/04/21 06:58 AM
Brake pads Roadster 3,7
by Mats. 21/04/21 06:51 AM
Headlight bezel
by Tim Caddey. 20/04/21 10:19 PM
Bonnet hinge 97 +8
by Fus969. 20/04/21 06:06 PM
Advice re hardtop front mountings, please
by vbalddave. 20/04/21 09:36 AM
Lap of the Cairngorms
2017 Sport Blue M3W
Front spoiler
My M3W
Spring has sprung at Hintlesham...
tony1966, Grahameeyore, Animal, prf, Morgs52
7485 Registered Users
Topics41,048
Posts686,996
Members7,485
Most Online1,033
Dec 28th, 2019
Kurt
Page 3 of 4 1 2 3 4
Re: Starting - Battery? [Re: Amrum] #690456
23/02/21 08:53 PM
23/02/21 08:53 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
Standard Banner 530 30 is L187mm, W128mm, H165mm. Try a search for JMT YTX30-FP Lithium Ion battery, they seem to be easier to get these days. There is a list of batteries that fit in the Alternative Parts List page 6, that is now available from the "M3W resources" link in the stickies at the top of this forum list.
Re: Starting - Battery? [Re: Amrum] #690458
23/02/21 09:18 PM
23/02/21 09:18 PM
Tourtour, France and Lewes, UK
WilsonLaidlaw Offline
I have found the Banner spec from the Banner 530-03-!2v 30AH as shown in my original 2012 parts book. They are: 300A coldcrank. 187mm L, 128mm W, 165m H. LH Front Negative bolt on post. The only battery I have found with a quick search in France that has a suitable cranking current is over €400. In any case I have found the French storage people have already bought a lead acid replacement for my M3W. I just hope it is not one of the useless Banner batteries. That will make battery #4 since 2012, 2 x Banner and 1 Yuasa. I had hoped the Yuasa might be better in the M3W, since on my Yamaha 700cc (single cylinder) Raptor R quad bike, I only replaced the Yuasa starter battery once in 15 years and the second one was still going strong when it was stolen.
Wilson
Re: Starting - Battery? [Re: Amrum] #690459
23/02/21 09:25 PM
23/02/21 09:25 PM
M3W55 Offline
M3W55  Offline
I had the JMT. Fits perfectly, has 400A+ cranking power and from memory was c.£200.
Re: Starting - Battery? [Re: Amrum] #690540
24/02/21 02:43 PM
24/02/21 02:43 PM
New River Valley, VA
rcmatt Offline
rcmatt  Offline
As most of these vehicles have energy loss do to things like clocks, etc. even a lithium battery will need an intermittent charge up
Rodger
2004 Plus 8 (wife's)
Re: Starting - Battery? [Re: rcmatt] #690551
24/02/21 03:20 PM
24/02/21 03:20 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Except for the clock function are there any other things that draw power with the ignition OFF?
Re: Starting - Battery? [Re: Amrum] #690553
24/02/21 03:30 PM
24/02/21 03:30 PM
M3W55 Offline
M3W55  Offline
The blasted immobiliser. I joined Red Leader in fitting a Battery Brain to isolate the battery, setting the trigger level to 11.5.
Re: Starting - Battery? [Re: Amrum] #690554
24/02/21 03:34 PM
24/02/21 03:34 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
I was thinking of just putting in a switch on the battery, either great big switch or a relay operated one.
Re: Starting - Battery? [Re: LightSpeed] #690577
24/02/21 05:21 PM
24/02/21 05:21 PM
Oxon
PaulV Offline
PaulV  Offline
Oxon
Interestingly I had to boost my Lithium battery after a few weeks. It claimed a charge but not enough to turn the engine over... maybe the wet sumping added too much load? Paralleling my old (and by itself defunct in terms of M3W starting) Banner (technically only 2yrs old, but swapped out last year) got it started.
Possibly I have an "electrical leak" somewhere. Only outstanding electrical issue is that the heated seats havent worked since I put the insides back together again last year... probably I should pull the fuse!
Re: Starting - Battery? [Re: Amrum] #690590
24/02/21 06:05 PM
24/02/21 06:05 PM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
I think it's wise to fit a battery disconnect to all infrequently used machines.
The only downside on a M3W is that any updated settings in the ECU adaptive maps are lost when the power is disconnected. Not a big deal if the machine is stock. But if you have intake/exhaust/cam mods it will take a number of miles for the engine to get back to it's happy place.
A replacement unlocked ECU with merged maps solves this issue, but isn't an absolute requirement.
Older photos, as this was the very first mod I did on my car. Disconnect is on the negative side of the battery. Have since fitted covers to the exposed terminals.
2012 M3W
Re: Starting - Battery? [Re: Amrum] #690595
24/02/21 06:28 PM
24/02/21 06:28 PM
M3W55 Offline
M3W55  Offline
As a matter of interest, with your skills why did you not fit the isolator key under the dashboard rather than having to take the hood off every time?
Page 3 of 4 1 2 3 4
