10 registered members (Spanner Juggler, MarioCP, bmgermany, yobtaf, Rainer Duell, mphcarpaintings, AndyA, ajsms999, Culminator, drewg),
155
guests, and 11
spiders. |
Topics40,987
Posts685,831
Members7,473
Most Online1,033 Dec 28th, 2019
Is this normal questions π
#690620
24/02/21 09:10 PM
24/02/21 09:10 PM
Posts: 31 Belgium
PiGo
Belgium
Hi Guys
I have a question concerning a new plus four with manual gearbox. I have some small things but I don't know if they are normal or that they need to be looked at:
1. If I put the car in neutral and apply a little bit of throttle to 1500rpm all sounds well. If I put the car in a gear ( first or reverse), hold the clutch down and apply a little throttle you hear a slight rumble/rattle on the passenger side. Also if you pull away and the revs rise to around 1500rpm you hear the rumble/rattle. Could somebody check if they have the same?
2. If I drive over small bumps the driver side door catch squeaks. I have applied some silicone grease on the small rubber block and it is a little better but still not gone. Anybody has an idea where I have to apply some grease?
Many thanks
PiGo
Re: Is this normal questions π
[Re: PiGo]
#690621
24/02/21 10:00 PM
24/02/21 10:00 PM
Posts: 19,305 South Yorkshire
South Yorkshire
2) The squeak may be the side-screen rubbing on the B panel where it overlaps. Trap a piece of microfiber between the two to test it.
DaveW 2005 Corsa Red Roadster S1 2016 Saffron Yellow (Narrow) AR Plus 4
[Re: PiGo]
#690623
24/02/21 11:14 PM
24/02/21 11:14 PM
TheCustomer
Strewth. Build quality is improving!
Aero 8 S5 BMW i8 Coupe Triumph Stag '72
[Re: TheCustomer]
#691062
27/02/21 07:24 PM
27/02/21 07:24 PM
Posts: 1,094 Evergreen, Colorado, USA
britmog
Strewth. Build quality is improving! In danger of becoming a normal car.
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
[Re: PiGo]
#691162
28/02/21 02:43 PM
28/02/21 02:43 PM
Posts: 19,567 Suffolk
Suffolk
Nah give it time for the features to appear.
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
[Re: Dada]
#691167
28/02/21 04:06 PM
28/02/21 04:06 PM
Posts: 1,070 North of Stamford, UK
HeadlessBlue
I might be wrong but it looks like on the Plus Four the miles per gallon figure isnβt a cumulative or journey figure but rather a snapshot at the time you look at it, which is a bit of a shame ie it is only based on how much youβre pressing the throttle at that time...I donβt know if it is the same on the Plus Six....I havenβt worked out yet if I can change it so it reflects the period for a whole journey or the average as such. HB
Plus Four (Bellagio) Bentley Velvet Red prev 2019 110 Plus 4 Tesla Model 3 βErnieβ A3 S Line
