12 registered members (JMcL, TimB, Black Adder, TBM, SFO, DickJ, The Austrian, Saxonian, Scrambledsignals, Jens, PaulV, James B W),
165
guests, and 15
spiders. |
Topics41,048
Posts686,992
Members7,485
Most Online1,033 Dec 28th, 2019
Re: Anyone relocate their oil vent line?
[Re: Chris99]
#690549
24/02/21 03:12 PM
24/02/21 03:12 PM
Posts: 1,114 Evergreen, Colorado, USA
britmog
The bottom line on the engine drain the tank.
And if you are just blowing air up a hose that is connected to the tank you will be blowing crap up into the clean oil. I would disconnect the line at both ends and then clean it.
Which is what I think R1NGA is saying It is a 6 liter tank so what good is a two liter bottle? As I read it he is disconnecting both ends of the breather hose and then using an air pump to blow the gunk out of the breather pipe into the bottle. Agree that is what R1NGA is saying and it is what I do too, in my case I used my compressor to blow through and it certainly cleared the junk but I also took the precaution of relocating the pipe. It is a simple fix and easy procedure to add to the annual maintenance schedule.
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
[Re: Hogzilla]
#690603
24/02/21 06:51 PM
24/02/21 06:51 PM
Posts: 517 SW Iowa, U.S.A.
Bitsobrits
SW Iowa, U.S.A.
There is no vent to atmosphere, by design. That small vent through the throttle body is all that is required. And venting this way has the added benefit of creating a net negative pressure in the crankcase which aids the oil seals, as well as reducing emissions. Which is why all the OEMs went to this type of set up in the 1960's.
From an engineering perspective, going back to atmospheric venting is a retrograde step.
Steve 2012 M3W
[Re: Hogzilla]
#690708
25/02/21 03:28 PM
25/02/21 03:28 PM
Bitsobrits
SW Iowa, U.S.A.
As noted elsewhere, the whole gunk in the vent line issue goes away if you simply get the engine oil up to full operating temperature (220F+) most every time you take the vehicle out for a drive.
As my father in law once observed (with some measure of disgust) when he saw me using glass cleaner on the underside of my S1 Lotus Elan: "Just go out and drive the damn thing!"
Steve 2012 M3W
[Re: Bitsobrits]
#690713
25/02/21 04:09 PM
25/02/21 04:09 PM
Posts: 1,530 New River Valley, VA
rcmatt
As my father in law once observed (with some measure of disgust) when he saw me using glass cleaner on the underside of my S1 Lotus Elan: "Just go out and drive the damn thing!" the worse wear on an engine is the little old lady who only drives to church
[Re: rcmatt]
#690717
25/02/21 04:32 PM
25/02/21 04:32 PM
Posts: 1,209 Oxon
PaulV
Oxon
The mind boggles at the idea of a little old lady driving an M3W today! Cue photo contest...
