18 registered members (linklaw, John07, SimonH, Alwlo, Jon G4LJW, JohnHarris, BLUE+4, HeadlessBlue, Luddite, KennyW, dmh, Spanner Juggler, Jens, AndyrIch, CasaLobo, Ritchie B, Trevor v, DonM), 165 guests, and 20 spiders.
John V6 310
+8Rich 285
Peter J 174
Maintenance Day
by Saxonian. 21/04/21 08:27 AM
How many Morgan 3 Wheelers left to be made?
by Red3W. 21/04/21 07:23 AM
maybe the era hasnt ended.
by howard. 21/04/21 06:58 AM
Brake pads Roadster 3,7
by Mats. 21/04/21 06:51 AM
Headlight bezel
by Tim Caddey. 20/04/21 10:19 PM
Bonnet hinge 97 +8
by Fus969. 20/04/21 06:06 PM
Advice re hardtop front mountings, please
by vbalddave. 20/04/21 09:36 AM
Lap of the Cairngorms
2017 Sport Blue M3W
Front spoiler
My M3W
Spring has sprung at Hintlesham...
tony1966, Grahameeyore, Animal, prf, Morgs52
7485 Registered Users
Topics41,048
Posts687,002
Members7,485
Most Online1,033
Dec 28th, 2019
Kurt
Electrical questions : 1934 3 wheeler Super Spo #690847
26/02/21 03:30 PM
26/02/21 03:30 PM
Manila, Philippines
patrickt Offline OP
patrickt  Offline OP
Manila, Philippines
Hello All,
I wasn't sure whether to post here or the 3 wheeler forum. The 3 wheeler forum appears to be for the new 3 wheelers only ? ? This is for our 1934 3 wheeler Super Sports with JAP LTWZ 1100cc sidevalve engine, that is being fitted with a 6 volt Thorspark electronic ignition kit. Just a couple of questions.
1) I am using the 6 volt starter, generator and lights. May I ask what the original Battery Electrical Specs were for this engine ? Please include ampere hours.
2) What is the diameter of the original Lucas generator pulley
I appreciate any help. Thank you.
Patrick
Re: Electrical questions : 1934 3 wheeler Super Spo [Re: patrickt] #690870
26/02/21 04:56 PM
26/02/21 04:56 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Patrick, try the 3W forum, Ian Parkinson on there has a '34 SS
Re: Electrical questions : 1934 3 wheeler Super Spo [Re: patrickt] #690885
26/02/21 05:40 PM
26/02/21 05:40 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
BuyBritish on here has also a 1930s 3 wheeler.
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Electrical questions : 1934 3 wheeler Super Spo [Re: patrickt] #690922
26/02/21 09:17 PM
26/02/21 09:17 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Patrick, speaking in generic terms, a six volt system and that size engine would require a minimum 70 amp hour battery.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Electrical questions : 1934 3 wheeler Super Spo [Re: patrickt] #690929
26/02/21 11:59 PM
26/02/21 11:59 PM
Arwyn Williams Offline
I've probably got the battery specs somewhere but for all intents and purposes, the battery i used in my 1934 MX4 Sports Family is from an early MGB, is one half of the pair of 6V batteries they use.
I've since converted it to 12 v in the interests of safety and used one of Roger Orfords Bosch alternator conversion kits.
The standard dynamo didn't use a pulley, instead it used a pair of gears running off the gearbox cross shaft. One of the gears being a fibre gear which soon stripped and are often replaced with steel or alloy gears. The bracket isn't very strong either! It also means that the battery is not charged until the car is actually moving above 25mph.
Hope this helps
Arwyn
Re: Electrical questions : 1934 3 wheeler Super Spo [Re: patrickt] #690943
27/02/21 08:40 AM
27/02/21 08:40 AM
UK
BuyBritish Offline
BuyBritish  Offline
UK
My comments are same as Arwyn above,
Basically my 1934 3 wheeler was ^Volts in the beginning however
6V is feeble on todays roads it is poor for the starter which needs the decomprseor to be used so the 6V can turn the engine over
The DYNAMO works off of the gearbox so you need to be moving to charge and the DYNAMO has a feeble output
My MX had a pulley fitted to the flywheel which was connected to a dynamo meaning it would charge whenever the engine ran, the Dynamo was located beside the engine upfront so it got wet....
My new setup is a 12V ALTERNATOR connected to the gearbox under the seat (the Roger Orford conversion)
A 12V battery
12v Starter motor
12v electrics including 12v LED headlights which use much less current from the battery and alternator ....no charging occurs unless you are moving due to the alternator being driven from the gearbox....
[Linked Image]Ali 3 wheeler June 2020. 3 by Robert & Ali Davies, on Flickr
Alternator and drive is fitted to this side of gearbox and aluminium pulley is fitted to centre of swinging arm here
[Linked Image]DSC_1056 by Robert & Ali Davies, on Flickr
[Linked Image]DSC_0003 by Robert & Ali Davies, on Flickr
Rob Davies
Morgan 3 Wheeler 1934 MX
Morgan Series 1 1947
Morgan +4 1956 TR4
Morgan +4 2000 T16 Rov
Re: Electrical questions : 1934 3 wheeler Super Spo [Re: patrickt] #690989
27/02/21 12:29 PM
27/02/21 12:29 PM
Manila, Philippines
patrickt Offline OP
patrickt  Offline OP
Manila, Philippines
CooperMan - I take that to mean that they discuss vintage 3 wheelers as well. Thank you.
John V6 - Thank you.
RichardV6 - Thanks for the ballpark figure.
Arwyn Williams -
Interesting thing about how the dynamo of your MX4 is run by gears from the gearbox. And I'm guessing a fibre gear waa used to lessen noise and maybe to act as the sacrificial gear for whatever reason Matchless (or Morgan ??) deemed appropriate ??? Nevertheless it's obviously more practical to go the 12 volt route with a standard belt driven alternator. But for now, we would like to remain with the 6 volt dynamo-starter setup.
By the way, when you say that the MX4 standard dynamo is driven via the gearbox, did you mean this to apply to our JAP LTWZ 1100 sidevalve as well ? I asked about the pulley size because our dynamo is in fact belt driven ( perhaps a previous modification? ). Thanks for your reply.
BuyBritish -
As I told Arwyn, for now, we would like to maintain the 6 volt system. It does have the Thorspark electronic ignition mod, which responds easily to a slow turning crankshaft, so I'm not worried about a slow engine turnover. Lighting of course is a different story... But it will be used mostly for daytime fun drives on normally slow roads. You both are obviously having a grand time with that modernized electrical system ! Maybe someday we might follow your lead. Thank you as well for your response. And thanks for the pictures. Nice looking 3 wheeler !
Everyone-
I would still like to know exactly what the Battery Electrical Specs were for our particular engine, since finding a 6 volt battery with more than a mere 12ampere hours might be challenging to find.
I will check out the 3 wheeler forum then, since I just now found out that they catered to vintage 3 wheelers as well. Thank You all for your informative responses.
Patrick
Re: Electrical questions : 1934 3 wheeler Super Spo [Re: patrickt] #691017
27/02/21 03:42 PM
27/02/21 03:42 PM
RichardV6 Offline
RichardV6  Offline
Worth noting the 6 volt dynamo on my 500cc Velocette was converted to 12 volt by simply increasing the crankshaft drive pulley size a tad and fitting a solid state 12 volt regulator, which fits inside the old reg can to maintain originality. If you have a positive earth system it a good opportunity to convert to negative earth. Just fit battery that way around then run a temporary wire from battery positive and dab it on the dynamo's F (field terminal).
ETA: plenty of higher capacity 6 volt batteries around if you have deep pockets. This one on eBay is 80 amp hour and 600 CCA.
Re: Electrical questions : 1934 3 wheeler Super Spo [Re: patrickt] #691038
27/02/21 05:22 PM
27/02/21 05:22 PM
Arwyn Williams -
BuyBritish -
Everyone-
Patrick
Gear box driven dynamo was standard on all three speed twins from R type, modified R type through to D type irrespective of what engine was fitted. The F types had an engine driven dynamo
Personally, I'd be more concerned about other motorists seeing me rather than maintaining strict originality but each to their own.
Arwyn
Re: Electrical questions : 1934 3 wheeler Super Spo [Re: RichardV6] #691093
27/02/21 11:41 PM
27/02/21 11:41 PM
Manila, Philippines
patrickt Offline OP
patrickt  Offline OP
Manila, Philippines
Thanks for the suggestions Richard. The 3 wheeler still belongs to my dad, and he is trying to maintain its originality. So any 12 volt upgrading will likely not happen anytime soon...
