12 registered members (ajsms999, Alwlo, TBM, Craig Jezz, SimonH, jimmyw, Mogdavid, vbalddave, John Winn, nippymog, hugo, Tresco), 172 guests, and 18 spiders.
John V6 309
+8Rich 285
Peter J 174
Sport Steering Wheel
by PhilRoyle. 21/04/21 12:16 PM
Maintenance Day
by Saxonian. 21/04/21 08:27 AM
How many Morgan 3 Wheelers left to be made?
by Red3W. 21/04/21 07:23 AM
maybe the era hasnt ended.
by howard. 21/04/21 06:58 AM
Brake pads Roadster 3,7
by Mats. 21/04/21 06:51 AM
Headlight bezel
by Tim Caddey. 20/04/21 10:19 PM
Bonnet hinge 97 +8
by Fus969. 20/04/21 06:06 PM
Lap of the Cairngorms
2017 Sport Blue M3W
Front spoiler
My M3W
Spring has sprung at Hintlesham...
tony1966, Grahameeyore, Animal, prf, Morgs52
7485 Registered Users
Topics41,049
Posts687,012
Members7,485
Most Online1,033
Dec 28th, 2019
Kurt
Radiator Grill Mesh #691057
27/02/21 06:57 PM
27/02/21 06:57 PM
PlusTim Offline OP
PlusTim  Offline OP
Hi gals and guys
I've just bought a Roadster 2004 , to be transported on Monday
very happy but no radiator grill mesh ->What to do ?
i looked on. eBay and Lockwood heavy mesh is there and lots of others
I take it if you can cut it with scissors, it's no good ?
Is it easy to find the right mesh and cut to size or do the ( possibly very expensive ) dealer grill meshes win as they have bolt holes?
Can anyone please tell me what to do I want the looks and longevity and not so expensive if possible -> simple to you all , to me less simple and I would be so grateful for some advice
thanks in advance,Tim
Re: Radiator Grill Mesh [Re: PlusTim] #691060
27/02/21 07:10 PM
27/02/21 07:10 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Welcome to TM Tim.
Even the original mesh is problematical to fit because it can so easily damage the sides of the cowl going in. Some meshes are quite well attached to the grille, but others are much looser, maybe aftermarket.
I suggest you wait until your Roadster arrives, take the grille off and then you'll see what's involved.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Radiator Grill Mesh [Re: PlusTim] #691070
27/02/21 08:04 PM
27/02/21 08:04 PM
Llanelli
Ray Offline
Ray  Offline
Llanelli
Welcome, I wouldn't worry about the grill mesh Morgan's have managed many years without it.
Re: Radiator Grill Mesh [Re: PlusTim] #691071
27/02/21 08:11 PM
27/02/21 08:11 PM
PlusTim Offline OP
PlusTim  Offline OP
Thanks
Is the grill mesh actually ( really ) useful - stopping rad damage etc or do most people fit them simply as a cosmetic thing?
Just feeling my way around this subject, thanks. Tim
Re: Radiator Grill Mesh [Re: PlusTim] #691072
27/02/21 08:13 PM
27/02/21 08:13 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Hi Tim, the mesh could probably be trimmed using heavy duty tin snips, but bear in mind it's stainless so quite hard. It has complex curves to match grill and original has hook eyes spot welded on to attach to the grills two tangs at the top. See below.
I suggest it would be a lot easierr to source a factory made one.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Radiator Grill Mesh [Re: PlusTim] #691076
27/02/21 08:38 PM
27/02/21 08:38 PM
Germany, Rhein-Main Area
X
xc68anc Offline
xc68anc  Offline
X
Hello Tim,
I was on the same way. But I do it different with a 10x5mm mesh from „Racegitter.de“.
If you (and others) are interested send me a PM with your email for pictures. I‘m not able to public pictures here.
Greets René
2018 plus4
Re: Radiator Grill Mesh [Re: PlusTim] #691078
27/02/21 09:24 PM
27/02/21 09:24 PM
Belgium
MATTMOG Offline
MATTMOG  Offline
Belgium
Welcome Tim
I drive 2 Morgans.
1 with more than 180000 Km and no mesh grill.
The other with grill and about 40000 Km.
The only difference other than the better looks is that fewer insects get into the radiator.
The installation was quite simple. No cuting or adjustments at all.
Grts
1990 4/4 1.6 Ford CVH
2014 +4 2.0 Ford
2005 BMW Z4 2.2 6Cyl
Re: Radiator Grill Mesh [Re: PlusTim] #691271
01/03/21 08:40 AM
01/03/21 08:40 AM
Dinko Offline
Dinko  Offline
Hello Tim, I made one from stainless steel mesh purchased from a local metal dealer for around £8 (this was a good few years ago and had enough to make two) My reason for this extra protection was that returning from a holiday in Spain in the Morgan and we had just entered France when a car in front picked up a flattened can which flew up into the air and came bouncing down the road heading towards our car. By pure luck it missed the radiator and went under the car. However it could have destroyed the radiator.
I made a cardboard template to obtain a good fit then cut out the mesh using a grinder with a cutting disc after marking the mesh with a black marker pen. It took a little time to get it right but the peace of mind of giving the radiator some extra protection was worth the effort. Yes to purchase a new grill is expensive but to have one fitted for the extra protection is for me worth it. We were a long way from home when this happened.
Dinko
Re: Radiator Grill Mesh [Re: PlusTim] #691279
01/03/21 09:34 AM
01/03/21 09:34 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Tim,
I have had both without a problem. As Richard says newer cars have lugs to fit the mesh to tabs on the grill. M previous Roadster didn't have this & the mesh was essentially only held by the two bolts at the bottom.
This is the 2014 car manual showing the grill fitment
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Radiator Grill Mesh [Re: PlusTim] #691280
01/03/21 09:46 AM
01/03/21 09:46 AM
Solihull
Spanner Juggler Offline
Solihull
I was shown a very helpful way to fit a mesh by Steve Simmonds years ago. Place a soft towel on the floor, put your grill face down on the towel (prevents scratching) place mesh on top and if possible get someone to GENTLY press in centre with their hand.
The idea is to concave the mesh a little.
Fit cable ties to hold the mesh in place, use a good number to hold the shape.
Now put on bench and in turn pull the cable ties tighter and tighter to curl the mesh into the shape of the grill, it will also reduce the outside dimensions and help avoid scratching when fitting.
Now refit whole assembly to car ensuring your happy with location and security.
Finally cut all the cable ties and remove. The mesh with spring outwards slightly and be secure in place. I have fitted a few for owners using this method.
It can also be used in reverse to secure the mesh to the grill if a grill needs removing!
BR
Colin (all credit to Steve S for this method)
BR Colin
