18 registered members (AlyMatt, Saxonian, TBM, PJC, Gordon D, westgardronning, Craig Jezz, britmog, +8Rich, JohnMat, IcePack, RobCol, Marius, Image, nippymog, Lance, BigSteve, HowthHead), 140 guests, and 17 spiders.
John V6 309
+8Rich 286
Peter J 177
Sport Steering Wheel
by PhilRoyle. 21/04/21 12:16 PM
Maintenance Day
by Saxonian. 21/04/21 08:27 AM
How many Morgan 3 Wheelers left to be made?
by Red3W. 21/04/21 07:23 AM
maybe the era hasnt ended.
by howard. 21/04/21 06:58 AM
Brake pads Roadster 3,7
by Mats. 21/04/21 06:51 AM
Headlight bezel
by Tim Caddey. 20/04/21 10:19 PM
Bonnet hinge 97 +8
by Fus969. 20/04/21 06:06 PM
Lap of the Cairngorms
2017 Sport Blue M3W
Front spoiler
My M3W
Spring has sprung at Hintlesham...
tony1966, Grahameeyore, Animal, prf, Morgs52
7485 Registered Users
Topics41,049
Posts687,027
Members7,485
Most Online1,033
Dec 28th, 2019
Kurt
Moving seat belt mount? #691742
04/03/21 11:35 AM
04/03/21 11:35 AM
Northants, UK
TBM Online content OP
TBM  Online Content OP
Northants, UK
Following a discussion on another thread, I'm thinking about moving my bottom seat belt mount.
It currently as shown in this photo, and prevents the seat moving backwards any further.
I'd like to move it further up the wheel arch. I'd use one of those special belts that allow you to set the 'angle' to make sure the inertia reel works ok.
My plan would be to drill through the wheel arch mount and bolt to it directly using a spreaderplate on the underside.
Any thoughts? Alternative suggestions?
1972 4/4 4 seater - 3G Morganeer
Too many ratty motorbikes
Re: Moving seat belt mount? [Re: TBM] #691744
04/03/21 11:47 AM
04/03/21 11:47 AM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
If it were me, I think I'd try and fabricate 2 spreader plates sandwiching the wheel arch between them and long enough so I could use bolts through both the new hole and the old. Then you could mount the seat belt on the upper bolt and have a second bolt going through the lower hole giving a really strong anchor.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: Moving seat belt mount? [Re: TBM] #691750
04/03/21 12:14 PM
04/03/21 12:14 PM
Northants, UK
Northants, UK
I think it would need a massive plate though. To gain any real rear depth they'd need to go up quite a bit (as the seat backs are not vertical) and the bottom belt bolt is right down near the chassis - there is already a z bracket that goes between the bottom mount and the seat reel.
Be useful to see how other belts are mounted - although like TimB, later cars seems to have narrower seats.
Re: Moving seat belt mount? [Re: TBM] #691782
04/03/21 03:30 PM
04/03/21 03:30 PM
Bonn / Germany
TimB Offline
TimB  Offline
Bonn / Germany
just a thought: How about getting a longer seat belt, moving the "retracting base" (no idea what the proper english term for this would be... ) and move it futher back on the rear wheel arch. It is just secured by a bolt through the wheel arch and big washers. On the top anchor would guide the belt over your shoulder - just that it is coming from the back. The lower anchor point would remain where it is.
This way you would remove the bulky base from the front wheel arch, but not change much.
Re: Moving seat belt mount? [Re: TBM] #691783
04/03/21 03:33 PM
04/03/21 03:33 PM
Northants, UK
Northants, UK
Yep, that's the plan. Just need to make/buy a beefy spacer plate so it doesn't just shatter the wood in an accident.
