15 registered members (Alan Patterson, JMcL, Rog G, Robbie Mathisen, Spanner Juggler, John07, Saxonian, mph, ShaunD, HeadlessBlue, petemog, PeterVD, dmh, TBM, nick w), 164 guests, and 18 spiders.
John V6 310
+8Rich 284
Peter J 175
Maintenance Day
by Saxonian. 21/04/21 08:27 AM
How many Morgan 3 Wheelers left to be made?
by Red3W. 21/04/21 07:23 AM
maybe the era hasnt ended.
by howard. 21/04/21 06:58 AM
Brake pads Roadster 3,7
by Mats. 21/04/21 06:51 AM
Headlight bezel
by Tim Caddey. 20/04/21 10:19 PM
Bonnet hinge 97 +8
by Fus969. 20/04/21 06:06 PM
Advice re hardtop front mountings, please
by vbalddave. 20/04/21 09:36 AM
Lap of the Cairngorms
2017 Sport Blue M3W
Front spoiler
My M3W
Spring has sprung at Hintlesham...
tony1966, Grahameeyore, Animal, prf, Morgs52
7485 Registered Users
Topics41,048
Posts686,993
Members7,485
Most Online1,033
Dec 28th, 2019
Kurt
occasional starting during winter? #692107
06/03/21 06:52 PM
06/03/21 06:52 PM
Near Chicago, USA
HalfFull Offline OP
HalfFull  Offline OP
Near Chicago, USA
For those in cold climates with salt on the roads...I will not get my M3W back on the roads until a few spring rains have washed salt off the roads of Chicagoland. Probably not til late April (I am also having shoulder surgery this month, so that factors into my annual 'bring her back from hibernation'). I have usually not touched the vehicle during the winter, but do you advocate starting it and letting her idle for a while periodically? I have generally resisted that, since I figured idling may do more harm than good. No chance to get her out on the roads for at least a few more weeks, and she has sat since November at this point.
Aka Joejoe
Re: occasional starting during winter? [Re: HalfFull] #692112
06/03/21 07:03 PM
06/03/21 07:03 PM
Dorset, UK
milligoon Offline
milligoon  Offline
Dorset, UK
I would drain the fuel tank especially if you've had any Ethanol mix Petrol/gas in it, as the ethanol absorbs water.
Mark - No Longer driving
Re: occasional starting during winter? [Re: HalfFull] #692115
06/03/21 07:23 PM
06/03/21 07:23 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
I would be tempted every two or three months to take the plugs out and turn engine over on starter until oil pressure is up and perhaps more important on this dry sump engine, so the crankcase is scavenged of oil. Remember to re-charge the battery afterwards.
Certainly not starting the engine though unless you are going to take it for a drive.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: occasional starting during winter? [Re: HalfFull] #692128
06/03/21 08:37 PM
06/03/21 08:37 PM
M3W55 Offline
M3W55  Offline
...but do move it back and forth a bit to avoid tyre flat spots.
Re: occasional starting during winter? [Re: HalfFull] #692141
07/03/21 12:55 AM
07/03/21 12:55 AM
Taffmog Offline
Taffmog  Offline
Hey Joe, I would drain the engine oil and refill before starting, chances are it will have wet sumped by then.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Re: occasional starting during winter? [Re: HalfFull] #692146
07/03/21 03:17 AM
07/03/21 03:17 AM
Near Chicago, USA
HalfFull Offline OP
HalfFull  Offline OP
Near Chicago, USA
I appreciate the suggestions. Before winter, I mix fuel stabilizer in and fill the tank, run it through for several miles. I then over-inflate the tires and place them on carpet mats to keep them off the concrete of my frigid garage. I do move it once in a while just to minimize tire flat-spotting. I keep a CTEK hooked up for the battery the entire time, and that has been it until the spring. It has started up easily every year without any issue, going on 5 winters. Sounds like there is plenty more that many of you do than I, so I appreciate the input.
Aka Joejoe
