2 registered members (westgardronning, Taffmog), 107 guests, and 10 spiders.
+8Rich 220
John V6 135
RichardV6 114
CooperMan 112
OZ 4/4 94
Wheelybin, Bonnie66, RichT56, Morgandave, Ulas A White
8323 Registered Users
Cracking 4/4 Sport for sale
by +8Rich. 29/03/23 09:40 PM
ARP4 video
by Lordofthewings. 29/03/23 02:38 PM
Snow worries..
by +8Rich. 29/03/23 02:28 PM
Morgan EV3
by Lordofthewings. 29/03/23 01:58 PM
What is under this?
by Topline123. 29/03/23 12:35 PM
2013 Plus 8 Relays and Fuses
by ADC. 29/03/23 10:43 AM
Introduction plus Goodwood accommodation
by Bishmog. 28/03/23 10:39 PM
M3W season '23 started! (@ 7 °C), 12.02.2023
Rat Rod style Threewheeler
Bimble to the New Forest
Brum by the sea
LM62
Topics44,883
Posts759,578
Members8,323
Most Online1,033
Dec 28th, 2019
PhilRoyle
Page 7 of 9 1 2 3 4 5 6 7 8 9
Re: Jacking a plus four [Re: RichardV6] #738149
06/04/22 12:33 PM
06/04/22 12:33 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
By nature of design all scissor jack's are at lowest mechanical advantage when operated from collapsed. Thoroughly grease threads and confirm you can use it in an emergency.
Had to use mine whilst on holiday and jacking car on gravel but it did work, just wink
Sage advice indeed.
I attempted to change a flat for a friend, whilst on tour.
The jack was so stiff as to make it almost impossible to use...not rust, simply unused and with no lubrication
Having got the car up, I then went to retrieve the spare wheel only to find that is was secured with a thick bowden cable and padlock. The padlock was too corroded for the key to turn and no one had a cutter suitable for the cable...so RAC to the rescue and a wasted hour or two!
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: Jacking a plus four [Re: Robbie] #738698
12/04/22 12:21 PM
12/04/22 12:21 PM
Northants
JJR Offline
JJR  Offline
Northants
Hi Gaston,
I'm back at home and here is the information on the jack. It is a Sealey Model 57m one tonne heavy duty scissor jack.
Dimensions: Closed length 373mm, Minimum height 90mm, Maximum Height 325mm. The scissor mechanism is 45mm wide.
Here is the link to the Sealey website for further information: https://www.sealey.co.uk/product/5637173367/1tonne-heavy-duty-scissor-jack
The photo below shows the two bags you mentioned and their contents. I also carry one of Peter Mulberry's excellent spanners.
Hope this helps,
Best regards,
John R Marchant
Plus Four JT10MOG "Florence"
Re: Jacking a plus four [Re: Robbie] #739313
18/04/22 03:52 PM
18/04/22 03:52 PM
France, Dunkerque
gaston Offline
gaston  Offline
France, Dunkerque
Thank you John.
Re: Jacking a plus four [Re: Robbie] #760355
04/11/22 09:46 PM
04/11/22 09:46 PM
Black Forest Germany
CLPlusFour Offline
CLPlusFour  Offline
I am a little unsure now. At the beginning of this thread was written that no jack is supplied with the PlusFour. Now there are two bags with it and in one is a jack. What is correct now?
Clemens
PlusFour MY 2022
Re: Jacking a plus four [Re: Robbie] #760356
04/11/22 09:51 PM
04/11/22 09:51 PM
Suffolk, England
John V6 Offline
Brooklands Register contact
John V6  Offline
Suffolk, England
You get a jack now
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Jacking a plus four [Re: Robbie] #760376
05/11/22 07:30 AM
05/11/22 07:30 AM
Katikati NEW ZEALAND
NZPlusSix Offline
NZPlusSix  Offline
You lucky Plus Four owners. Try buying a Plus Six and you don't get a jack or wheel spanner. Not even a can of sealant! Just a note to say if you get a flat tire then call for roadside assistance.
Kerry
2019 First Edition Plus Six Moonstone Blue
Prev
2017 Plus 4 Auto Ivory
2011 4/4 Grey
1939 4-4 Blue
Re: Jacking a plus four [Re: Robbie] #760623
07/11/22 01:43 PM
07/11/22 01:43 PM
Co Wexford, Ireland
Robbie Offline OP
Robbie  Offline OP
Co Wexford, Ireland
It would have been nice if the factory supplied a jack to the owners who got cars without one!! I have purchased a jack similar to the one above but with a little motor that plugs into the cigarette lighter socket and does the twisting for you - best of Chinese!!!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Re: Jacking a plus four [Re: Robbie] #760630
07/11/22 02:18 PM
07/11/22 02:18 PM
AndyMog57 Offline
AndyMog57  Offline
Hi Robbie,
I am intrigued. A cigarette lighter socket in a 2021 Plus Four!?
I have a 2022 Plus Four but two USB sockets; no 12V Hella socket? Did you retrofit the Hella socket? I ask as I have a small compressor which I intend to take when touring and was going to wire a Hella socket in for said purpose. I also note that Ring offer a portable battery compressor which can be charged off a 5V USB socket.
Andy
2022 Plus Four / San Marino Blue
Re: Jacking a plus four [Re: AndyMog57] #760632
07/11/22 02:38 PM
07/11/22 02:38 PM
UK
DalesPlusFour Offline
UK
If you’re looking for a non wired alternative to the socket powered air compressor, I have been using this for a year and it’s brilliant. Wireless and cordless and charges from usb. Highly recommend for ease of use and peace of mind.
https://www.amazon.co.uk/Oasser-Inf...psc=1&ref_=pd_basp_bia_rpt_ba_s_1_sc
Instagram: @DalesPlusFour
Re: Jacking a plus four [Re: Robbie] #760633
07/11/22 02:46 PM
07/11/22 02:46 PM
CLPlusFour Offline
CLPlusFour  Offline
There are adapters from USB to cigarette lighter.
Amazon Link
Clemens
PlusFour MY 2022
