Topics44,883
Posts759,578
Members8,323
Most Online1,033 Dec 28th, 2019
Re: Jacking a plus four
[Re: Robbie]
#760636
07/11/22 03:08 PM
07/11/22 03:08 PM
Posts: 3,274 Co Wexford, Ireland
Robbie
Co Wexford, Ireland
Andymog 57 -- My Plus four was produced before the change to USB sockets so I have a lighter socket to which I can plug an adaptor with USB sockets for the sat nav etc.!! Cheers!
[Re: CLPlusFour]
#760648
07/11/22 04:39 PM
07/11/22 04:39 PM
AndyMog57
There are adapters from USB to cigarette lighter. Amazon Link![[Linked Image]](https://www.tm-img.com/images/2022/11/07/Adapter.jpg) That's what I need!
Andy 2022 Plus Four / San Marino Blue
[Re: Robbie]
#760649
07/11/22 04:42 PM
07/11/22 04:42 PM
AndyMog57
Andymog 57 -- My Plus four was produced before the change to USB sockets so I have a lighter socket to which I can plug an adaptor with USB sockets for the sat nav etc.!! Cheers! I would have preferred a hella socket as I use hella to USB adaptors on my motorcycles and have them at hand. Nevertheless, 2 x USB sockets are also welcome, I use one to power my mobile telephone and use that in turn as a satnav.
[Re: AndyMog57]
#760652
07/11/22 05:21 PM
07/11/22 05:21 PM
AndyMog57
There are adapters from USB to cigarette lighter. Amazon Link![[Linked Image]](https://www.tm-img.com/images/2022/11/07/Adapter.jpg) That's what I need! Just noticed maximum output is 8W, whereas my compressor is rated at 18W.
[Re: Robbie]
#760696
07/11/22 10:27 PM
07/11/22 10:27 PM
Posts: 5,884 East Harling, Norfolk UK
Yes that lead appears to be trying to get blood put of a stone. USB sockets give nominally 5 volts in the 1 to 3 amp range. Give the loss in the voltage convertor you would be very lucky to get even the 8 watts mentioned.
If you don't have a cigar lighter socket and need a 12 volt up to 15 amp supply fit a Hella style socket and wire it in to a 15 -20 amp fused battery supply. Cigar lighter sockets are rubbish.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
[Re: DalesPlusFour]
#760700
07/11/22 11:33 PM
07/11/22 11:33 PM
Posts: 32 Bedfordshire
jim109b
Bedfordshire
Me too - I've got one of these too - beats the wired up ones easily.
Morgan Plus Four Metallic Emerald Green and Pebble Biscuit, 'clutchless'
[Re: AndyMog57]
#760745
08/11/22 02:06 PM
08/11/22 02:06 PM
Posts: 116 West Somerset
Davetherave
West Somerset
I have a Ford mini compressor kit with tyre goo for punctures, which I carry in the Plus 6. It uses the standard male type power connector that goes into a cigarette lighter socket. In order to get around the power needed I found on ebay a female connector with several metres of extension lead and crocodile clips on the other end. As a CX gen cars battery is easy access under the bonnet you can clip it to the battery terminals directly and still power a small 12v compressor. The only word of warning is to make sure the extension wiring is big enough for the power draw needed. The variants from China were too small a wire gauge, in the end I purchased one that was made in Germany, slightly more expensive but it was rated to handle the power draw.
Dave Plus 6 "Squeak" Roadster departed. 1936 BSA Empire Star Q8. 1935 BSA W7-35. 1938 BSA M20
[Re: RichardV6]
#761004
10/11/22 05:27 PM
10/11/22 05:27 PM
AndyMog57
If you don't have a cigar lighter socket and need a 12 volt up to 15 amp supply fit a Hella style socket and wire it in to a 15 -20 amp fused battery supply. Cigar lighter sockets are rubbish. Agreed. I had already thought that this is the only sensible option. I already have the necessary hardware and will make up a small fused harness which I will permanently connect to the battery.
[Re: AndyMog57]
#762734
28/11/22 12:22 PM
28/11/22 12:22 PM
AndyMog57
If you don't have a cigar lighter socket and need a 12 volt up to 15 amp supply fit a Hella style socket and wire it in to a 15 -20 amp fused battery supply. Cigar lighter sockets are rubbish. Agreed. I had already thought that this is the only sensible option. I already have the necessary hardware and will make up a small fused harness which I will permanently connect to the battery. Which I have now manufactured and fitted with interchangeable plugs so exchange between trickle charger and power for compressor is a few seconds work. So, now all I have to do is find somewhere to stash the compressor, the jack, the can of goo, the spanner etc. Pity there is no quick and easy access to the cover over the spare wheel well. Plenty of space there!
