0 registered members (), 87 guests, and 23 spiders.
+8Rich 393
John V6 191
TBM 134
CooperMan 117
Hamwich 103
Bill Box, John H, Colin McFadden, N2S3, Davetherave
7656 Registered Users
2016 Roadster. Head light questions
by Davetherave. 24/09/21 05:21 PM
Front steering geometry
by PaulJ. 24/09/21 02:47 PM
Footwell light cover
by Alan Patterson. 24/09/21 01:22 PM
M3W interest..?
by Luddite. 24/09/21 12:57 PM
Mike Duncan
by john humphreys. 24/09/21 08:36 AM
“The Very Last of the M3W”
by IMHO. 23/09/21 09:03 PM
Unknown badge.
by Grumpy2. 23/09/21 07:23 PM
Reinforced battery cradle for 2015 4/4
And for my next trick...
Guernsey Escape
Another Bride, Another Vroom
Madeira
Topics42,108
Posts705,984
Members7,656
Most Online1,033
Dec 28th, 2019
chocadoodledoo, Phil C
LED headlamp conversions #696006
28/03/21 10:09 AM
28/03/21 10:09 AM
Aberdeenshire
TimG Offline OP
TimG  Offline OP
Aberdeenshire
There has been an update on MOT requirements on LED headlamp conversions see this thread in Maintenance & Servicing
http://www.talkmorgan.com/ubbthreads.php/topics/694863/1
Basically you cannot use LED headlamp bulbs in a post April 1968 car. If you want LED headlamps you need to replace the whole unit, reflector & lens not just bulb.
Re: LED headlamp conversions [Re: TimG] #696010
28/03/21 10:19 AM
28/03/21 10:19 AM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
68 or 86?
1972 4/4 4 seater - 3G Morganeer
Too many ratty motorbikes
Re: LED headlamp conversions [Re: TimG] #696031
28/03/21 11:48 AM
28/03/21 11:48 AM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
86
Re: LED headlamp conversions [Re: TimG] #696162
29/03/21 07:02 AM
29/03/21 07:02 AM
Nr Watership Down UK
JMD Offline
JMD  Offline
Some of the LED replacement bulbs I have seen will be quite a bit different optically than the original filament designs in terms of origin of light vs the focal point of the reflector/projector.
So there is some logic to the latest regulation change.
We fitted one of the LED full replacement units to our 2012 M3W and like others we found that went through the last MOT OK and is a great improvement for night driving...hope the next MOT will be OK....
Re: LED headlamp conversions [Re: JMD] #696196
29/03/21 11:42 AM
29/03/21 11:42 AM
Guildford, UK
R1NGA Offline
R1NGA  Offline
Guildford, UK
Seems that there's quite a clamp-down on LED conversions now. Whilst I agree that LED bulbs in halogen units can be very bad with cheap LED bulbs (less so with properly designed and suitable expensive Phillips type replacements) and produce nasty glare, full replacement LED 7" units as many have on M3W's have been accepted before. In fact Wipac make a fully compliant, glare-free version for retrofit, as seen on many Land Rover 90's etc. However, even these are now outlawed on post '86 vehicles, which is a shame, as they are correctly patterned and improve safety at night hugely. Will be interesting to see how those with the replacement units get on at next MoT time.
DVSA Link for MoT Changes
Wipac Replacement Units
Re: LED headlamp conversions [Re: TimG] #696200
29/03/21 11:52 AM
29/03/21 11:52 AM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
I wonder why the Wipac LED headlamps you linked to are outlawed, unless it's due to lack of "E" mark of course. They seem to fit the bill in other respects being a fully integrated LED unit.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: LED headlamp conversions [Re: R1NGA] #696201
29/03/21 11:53 AM
29/03/21 11:53 AM
AndyrIch Offline
AndyrIch  Offline
Why would the wipac units fail? the DVSA link talks about headlamps fitted with replacement LED bulbs, I cant see anything about failing a complete replacement headlamp.
Re: LED headlamp conversions [Re: AndyrIch] #696281
29/03/21 06:21 PM
29/03/21 06:21 PM
Guildford, UK
R1NGA Offline
R1NGA  Offline
Guildford, UK
Good question, but they specifically state;
"For class 3,4,5 and 7 vehicles, the defect ‘Light source and lamp not compatible’ only applies to vehicles first used on or after 1 April 1986.
Should a vehicle be presented for an MOT test with conversions before 1 April 1986 they must not be failed with immediate effect.
Vehicles presented with converted halogen headlamp units first used on or after 1 April 1986 will continue to be failed."
So it's down to interpretation by the tester perhaps. Time will tell.
Re: LED headlamp conversions [Re: R1NGA] #696284
29/03/21 06:29 PM
29/03/21 06:29 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
It specifically says 'converted halogen headlamp' - the WIPAC units are dedicated LED headlamps, not converted halogen.
A converted halogen headlamp is a lamp designed for halogen bulbs that you've fitted with LED bulbs.
Re: LED headlamp conversions [Re: TBM] #696307
29/03/21 08:19 PM
29/03/21 08:19 PM
AndyrIch Offline
AndyrIch  Offline
That was my thinking as well.
Also it wouldn't fail on "the light source and lamp not compatible" as its its a complete assembly.
My only reservation would be whether they were E Marked.
It would be good to have headlamps brighter than the blue main beam warning light in the cabin.
