17 registered members (Brian G, HJF, Image, teknome, MikeFromPembroke, RobCol, V8Dave, Ollie, peterd, John V6, MJF, StevieMac, Spanner Juggler, RJW, Snowden, Doug J, Marmota),
191
guests, and 16
spiders. |
4/4 Sold
by Spanner Juggler. 18/04/21 02:49 PM
Topics41,023
Posts686,567
Members7,473
Most Online1,033 Dec 28th, 2019
Re: Plus four ground clearance
[Re: howard]
#697610
06/04/21 07:29 PM
06/04/21 07:29 PM
Posts: 4,086 Australia - NSW North Coast
OZ 4/4
There is a difference between the ground clearance on flat ground and what happens at either end when the gradient changes. You can hit a 9cm sleeping policeman with a 10cm ground clearance if the overhangs front and back of the wheels are flat. Spot on Howard. Most jurisdictions have a specification for a vehicle moving over a ramp set at a specific approach and departure angle for that very reason. This spec also sits with the usual100mm flat ground clearance and you will need every bit of that for normal road driving as you rightly point out.
[Re: Robbie]
#697997
09/04/21 09:42 AM
09/04/21 09:42 AM
Posts: 3,915 South Yorks
Clipper
South Yorks
Anybody know if the P4/P6 needs a protector for the sump like the Aero or have they designed it a bit better so it's not as vulnerable?
2017 Ravenblau Blue Aero S5 2021 Lapis Blue Plus 6  You know it makes sense!
[Re: Robbie]
#698186
10/04/21 09:33 AM
10/04/21 09:33 AM
OZ 4/4
Anyone know what the ground clearance should be on a new Plus Four? What is the lowest point? 13 replies and 736 views but we still don't have a specification.....
[Re: OZ 4/4]
#698190
10/04/21 09:49 AM
10/04/21 09:49 AM
Posts: 27,148 Devonshire
Devonshire
Anyone know what the ground clearance should be on a new Plus Four? What is the lowest point? 13 replies and 736 views but we still don't have a specification..... I seem to recall one of our European members saying his Plus Four was 90mm measured at the rear silencer box, he commented how low this was at the time. It will be a problem on slopes for sure.
Regards Richard
1999 Indigo Blue +8 2009 4/4 Sport Green prev 1994 Connaught Green +8 prev
[Re: thierry242]
#698207
10/04/21 11:17 AM
10/04/21 11:17 AM
OZ 4/4
That's what it is - not what It's supposed to be I suspect....
