7 registered members (James B W, Marchogion, Montegue, Graeme Morrison, Rog G, Rainer Duell, Image), 50 guests, and 13 spiders.
OZ 4/4 151
John V6 130
+8Rich 122
Luddite 113
CooperMan 109
JJD1776, Newboy, Tractor Driver, Phil Bordeaux, Slushymud
8127 Registered Users
Sidescreen window sticking
by Felix42. 28/09/22 09:22 PM
CANBUS & LEDs
by Buzz44. 28/09/22 02:32 PM
S1 Aero on live UK online auction - Ends 27 Sept
by Volvos60s60. 28/09/22 08:07 AM
Whilst I'm at it...
by Treesurveyor. 27/09/22 08:06 PM
Wobbly Steering Wheel
by Treesurveyor. 27/09/22 06:56 PM
Greasing the front UJs
by John V6. 27/09/22 01:23 PM
Roaster 3.0 MK 1 Pulley Noise / Wobble
by flyfisher. 27/09/22 12:23 PM
MORGAN SUPER 3 SUPER CLASSIC
Mirror
Fun in the Sun
My 1991 Plus 8
Morgan Super 4 EV
Topics44,095
Posts743,434
Members8,127
Most Online1,033
Dec 28th, 2019
Dutch
Page 10 of 11 1 2 8 9 10 11
Re: Ugh...check engine light is on [Re: NickValentine] #700177
21/04/21 06:04 PM
21/04/21 06:04 PM
Houston, Texas USA
CasaLobo Offline
CasaLobo  Offline
Houston, Texas USA
Those codes can also be related to fuel pressure, so you might want to confirm that is at 58, I believe. If the engine was out, perhaps, there is some fuel pressure issue at the engine fuel lines. Hope it gets sorted out quickly.
Re: Ugh...check engine light is on [Re: CasaLobo] #700186
21/04/21 07:24 PM
21/04/21 07:24 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
Very true CasaLobo but I assume that as a long time Talk Morgan member PhilipNZ would have replaced his standard fuel pump for a more reliable Walbro one long ago...... As you say, always worth a check of the fuel pressure at the test point, particularly with those codes.
Re: Ugh...check engine light is on [Re: planenut] #700224
21/04/21 11:05 PM
21/04/21 11:05 PM
Auckland, New Zealand
PhilipNZ Offline
ZK-Mog
PhilipNZ  Offline
ZK-Mog
Thanks guys - I'll check that. No I haven't replaced the fuel pump, I've never had an issue with the car until the rollers failed at 10000km
Re: Ugh...check engine light is on [Re: NickValentine] #700252
22/04/21 07:22 AM
22/04/21 07:22 AM
PhilipNZ Offline
ZK-Mog
PhilipNZ  Offline
ZK-Mog
Thanks again, found a local supplier and ordered the kit
Re: Ugh...check engine light is on [Re: NickValentine] #700272
22/04/21 08:03 AM
22/04/21 08:03 AM
planenut Offline
planenut  Offline
This is the most up to date version of the fuel pump replacement instructions. https://www.mtwc.co.uk/wp-content/u...l-pump-replacement-April-2020-update.pdf
Re: Ugh...check engine light is on [Re: NickValentine] #701657
03/05/21 02:47 AM
03/05/21 02:47 AM
PhilipNZ Offline
ZK-Mog
PhilipNZ  Offline
ZK-Mog
Well I ran all the old fuel out and refilled. The car is going great with non of the tardiness it had with the old fuel. Trouble is the light still comes on so I've ordered a replacement fuel pump and will talk to my mechanic.
Re: Ugh...check engine light is on [Re: NickValentine] #701662
03/05/21 06:11 AM
03/05/21 06:11 AM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
It could take 10 or so cycles of running the engine for the fault code to clear and the light go out.
Red Leader drive
Re: Ugh...check engine light is on [Re: NickValentine] #701918
04/05/21 11:41 AM
04/05/21 11:41 AM
Madrid, Spain
Marmota Offline
Marmota  Offline
Madrid, Spain
In our case, this silly engine light issue was solved sending the ECU to MMC. They loaded a new program to the ECU. Was it an update? Or the Euro3 mapping? I can't say because they don't want to tell... But both Ana María and I feel that the engine runs much stronger between 2500-3000 rpm than before... confused2
And the light (until now. I hope it keeps that way) has not come back.
www.speedymarmots.com
Re: Ugh...check engine light is on [Re: Marmota] #702428
07/05/21 08:59 PM
07/05/21 08:59 PM
Auckland New Zealand
P964 Offline
P964  Offline
With regard to reflashing the ecu, i have got a box file with the cooling fan code.
I used this when fitting the fan to my car.
It is a 30 sec job to upload to the ecu using ProTune software
Box file can be sent by email.
What file is currently in your ecu can be seen by using Protune and looking at 'comments'
Re: Ugh...check engine light is on [Re: P964] #702440
07/05/21 10:42 PM
07/05/21 10:42 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
You must have an unlocked e u?
