8 registered members (Osama, CPN, John V6, JoeSpeetjens, DJC, HJP, Black Adder, John07), 165 guests, and 13 spiders.
+8Rich 152
John V6 143
OZ 4/4 126
Alistair 108
RichardV6 100
05 Roadster, John Tromans, Factotum, Dave Jones, Fester
8159 Registered Users
A booze cruise!
by IMHO. 06/12/22 06:49 PM
Motoring Themed Cafes....
by TBM. 06/12/22 10:27 AM
Boot liner screws
by Jonathan G. 04/12/22 09:44 AM
Noel gift
by atalante83. 04/12/22 07:39 AM
One for Tim (Hamwich)
by +8Rich. 03/12/22 10:30 PM
What are you asking for xmas gifts ?
by Bonesie. 03/12/22 08:49 PM
My new watch release ! 6B GRAND SLAM
by Bonesie. 03/12/22 08:25 PM
Cover Girl_MOG414
Under the clouds....
Ms Marple's island/s connection...
Autumn Sunshine
Back Onshore
Topics44,384
Posts750,006
Members8,159
Most Online1,033
Dec 28th, 2019
Gary In Devon
Page 10 of 11 1 2 8 9 10 11
Re: Ugh...check engine light is on [Re: NickValentine] #700177
21/04/21 06:04 PM
21/04/21 06:04 PM
Houston, Texas USA
CasaLobo Offline
CasaLobo  Offline
Houston, Texas USA
Those codes can also be related to fuel pressure, so you might want to confirm that is at 58, I believe. If the engine was out, perhaps, there is some fuel pressure issue at the engine fuel lines. Hope it gets sorted out quickly.
Re: Ugh...check engine light is on [Re: CasaLobo] #700186
21/04/21 07:24 PM
21/04/21 07:24 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
Very true CasaLobo but I assume that as a long time Talk Morgan member PhilipNZ would have replaced his standard fuel pump for a more reliable Walbro one long ago...... As you say, always worth a check of the fuel pressure at the test point, particularly with those codes.
Re: Ugh...check engine light is on [Re: planenut] #700224
21/04/21 11:05 PM
21/04/21 11:05 PM
Auckland, New Zealand
PhilipNZ Offline
ZK-Mog
PhilipNZ  Offline
ZK-Mog
Thanks guys - I'll check that. No I haven't replaced the fuel pump, I've never had an issue with the car until the rollers failed at 10000km
Re: Ugh...check engine light is on [Re: NickValentine] #700252
22/04/21 07:22 AM
22/04/21 07:22 AM
PhilipNZ Offline
ZK-Mog
PhilipNZ  Offline
ZK-Mog
Thanks again, found a local supplier and ordered the kit
Re: Ugh...check engine light is on [Re: NickValentine] #700272
22/04/21 08:03 AM
22/04/21 08:03 AM
planenut Offline
planenut  Offline
This is the most up to date version of the fuel pump replacement instructions. https://www.mtwc.co.uk/wp-content/u...l-pump-replacement-April-2020-update.pdf
Re: Ugh...check engine light is on [Re: NickValentine] #701657
03/05/21 02:47 AM
03/05/21 02:47 AM
PhilipNZ Offline
ZK-Mog
PhilipNZ  Offline
ZK-Mog
Well I ran all the old fuel out and refilled. The car is going great with non of the tardiness it had with the old fuel. Trouble is the light still comes on so I've ordered a replacement fuel pump and will talk to my mechanic.
Re: Ugh...check engine light is on [Re: NickValentine] #701662
03/05/21 06:11 AM
03/05/21 06:11 AM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
It could take 10 or so cycles of running the engine for the fault code to clear and the light go out.
Red Leader drive
Re: Ugh...check engine light is on [Re: NickValentine] #701918
04/05/21 11:41 AM
04/05/21 11:41 AM
Madrid, Spain
Marmota Offline
Marmota  Offline
Madrid, Spain
In our case, this silly engine light issue was solved sending the ECU to MMC. They loaded a new program to the ECU. Was it an update? Or the Euro3 mapping? I can't say because they don't want to tell... But both Ana MarĂ­a and I feel that the engine runs much stronger between 2500-3000 rpm than before... confused2
And the light (until now. I hope it keeps that way) has not come back.
www.speedymarmots.com
Re: Ugh...check engine light is on [Re: Marmota] #702428
07/05/21 08:59 PM
07/05/21 08:59 PM
Auckland New Zealand
P964 Offline
P964  Offline
With regard to reflashing the ecu, i have got a box file with the cooling fan code.
I used this when fitting the fan to my car.
It is a 30 sec job to upload to the ecu using ProTune software
Box file can be sent by email.
What file is currently in your ecu can be seen by using Protune and looking at 'comments'
Re: Ugh...check engine light is on [Re: P964] #702440
07/05/21 10:42 PM
07/05/21 10:42 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
You must have an unlocked e u?
