8 registered members (brian battersby, Mark H, BertR, nick w, Edwin, Bunny, Dougie, Image),
77
guests, and 16
spiders. |
Topics43,595
Posts733,724
Members8,033
Most Online1,033 Dec 28th, 2019
Staggered rubber
#703306
14/05/21 04:10 PM
14/05/21 04:10 PM
Posts: 1,819 Sevenoaks,Kent
Viper
Sir S1'a'lot
Sir S1'a'lot
Sevenoaks,Kent
It’s a ballache trying to find staggered tyres.
Why is there no easy way of finding both sizes in one shot??
You chaps with 224/40/18 and 255/35/18
What you fitted?
2000 Plus 8 4.6 2002 Aero 8 S1
Re: Staggered rubber
[Re: Viper]
#703319
14/05/21 05:05 PM
14/05/21 05:05 PM
SimonH
Why do you want staggered tyres?
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
[Re: Viper]
#703350
14/05/21 08:57 PM
14/05/21 08:57 PM
Viper
Sir S1'a'lot
Sir S1'a'lot
Sevenoaks,Kent
Fat jobbies up back.
Have always run them, got them now
[Re: Viper]
#703381
15/05/21 09:56 AM
15/05/21 09:56 AM
Posts: 8,428 Llanelli
sospan
Llanelli
Bloody hell Viper those are low profiles! OK for a track but on our “great” roads? Other issues.......will they fit under the wings? Less cushioning due to small sidewalls making for a harsher ride. Ground clearance? I haven’t looked at calcs road speed effect either. Maybe wider with same profiles as original would be better if you can find some.you’d get the “look” with maintained ride.
Red Plus8
[Re: Viper]
#703386
15/05/21 10:36 AM
15/05/21 10:36 AM
Viper
Sir S1'a'lot
Sir S1'a'lot
Sevenoaks,Kent
It’s what I have fitted here. 35 is only an aspect ratio so the tyre being a 255 means the sidewall is taller than a 40 on a 225 if anything. ![[Linked Image]](https://tm-img.com/images/2021/05/02/34B55750-BFF5-4B8A-9CAA-DB34A10C3586.jpg)
[Re: Viper]
#703390
15/05/21 11:09 AM
15/05/21 11:09 AM
Posts: 1,290 Lampeter, Wales
Jon G4LJW
Lampeter, Wales
Looks good! It’s what I have fitted here. 35 is only an aspect ratio so the tyre being a 255 means the sidewall is taller than a 40 on a 225 if anything. ![[Linked Image]](https://tm-img.com/images/2021/05/02/34B55750-BFF5-4B8A-9CAA-DB34A10C3586.jpg)
[Re: Viper]
#703391
15/05/21 11:11 AM
15/05/21 11:11 AM
Posts: 9,421 Hampshire
Alistair
Smile, it confuses them
Hampshire
I have the same sizes on the Series 2 and last time I purchased I found Michelin Pilot Super Sport in those sizes. I realise they are now replaced with MPS4S in the range so not certain if you can still find fresh ones. Absolutely great grip and feel.
They are certainly more forgiving than the lower profile 19's on the Coupe.
Just time to rent a thimble more petrol before dinner.
[Re: Viper]
#703393
15/05/21 11:21 AM
15/05/21 11:21 AM
Viper
Sir S1'a'lot
Sir S1'a'lot
Sevenoaks,Kent
Yeah I love the MPS4S but they don’t do both sizes.
[Re: Viper]
#703699
17/05/21 07:57 PM
17/05/21 07:57 PM
Posts: 1,835 Buckinghamshire
NickCW
Buckinghamshire
They do in the US, you just need to find someone to import them..  Otherwise its MPS4 (the non-S) version only in those sizes for UK. Or if you go for 245/40 on the back then you can have Cup Sport 2s, or Cup Sport 2s with build in tyre sensors (called connect). Re the tirewall size a 255/35 is almost identical in sidewall height to a 225/40, which is why BMW use that staggered configuration on some of their cars. There is a handy online calculator below where you can compare two tyre sizes: https://tiresize.com/tyre-size-calculator/
Aero 8 S1
[Re: Viper]
#703737
18/05/21 08:17 AM
18/05/21 08:17 AM
Alistair
Hampshire
Nick makes a good point, often the UK importer will not bring all products in based on historic volumes. I found this out when trying to find some tyres for an R33 GTR a long time ago. I approached them with a couple of other GTR owners and we all bought 2 sets each so they did a special order. It took about 2 months to arrive as they it was a Japanese manufactured item not EU. The other option is to hit the EU or US web sites and look at the availability. US - https://www.tirerack.com/content/tirerack/desktop/en/homepage.htmlEU and so more chance of shipment Mytyres, most of the shipments come from france and germany anyway and I believe tyre are a german company from the invoices. Tyreleader are similar to the above but I have had a couple of bad service attempts with so don't use them anymore. They both have UK .co.uk sites but can also be found in EU blends which offer tyres I do not see on the UK ones like Blackcircles. If you can get the Mich Pilot Super Sports they are still pretty good but do check the age of manufacture.
