1 registered members (bilibib), 112 guests, and 12 spiders.
+8Rich 123
John V6 104
OZ 4/4 100
8359 Registered Users
One for the Morgan Boy Racers..
by +8Rich. 30/05/23 11:00 PM
Green S1, based in London, spotted in Cotswolds
by verysideways. 30/05/23 08:56 PM
Roll Bars
by IvorMog. 30/05/23 08:01 PM
Used car purchase scam?
by KennethM. 29/05/23 09:50 PM
M3W - check the following
by Chris99. 29/05/23 05:12 PM
4/4 Four seater outdoor car cover
by Tim W. 29/05/23 08:11 AM
Book recommendation..
by +8Rich. 28/05/23 01:29 PM
Spotted In Amboise Loire
Wiscombe Park
Sod the rain
Forums32
Topics45,130
Posts764,432
Members8,359
Most Online1,033
Dec 28th, 2019
7024, hbatts
Brake squeal fix #704690
26/05/21 04:33 PM
26/05/21 04:33 PM
Suffolk, England
John V6 Offline OP
Brooklands Register contact
John V6  Offline OP
Suffolk, England
A "source" told me today the fix is to reverse the calipers so n/s to o/s but upside down. Then they only squeal going in reverse. Is that true? It seems a very MMC solution
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Brake squeal fix [Re: John V6] #704699
26/05/21 05:33 PM
26/05/21 05:33 PM
tervuren belgium
thierry242 Offline
thierry242  Offline
tervuren belgium
Yes it is true,but there is a kit
Re: Brake squeal fix [Re: John V6] #704704
26/05/21 06:05 PM
26/05/21 06:05 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Spanner and bottle of Dot 4 [Linked Image]
2018 Roadster - Red/Magnolia - Morton
1966 Land Rover S2a 88 - Lenny
1945 Moto Guzzi Airone
Re: Brake squeal fix [Re: John V6] #704708
26/05/21 06:23 PM
26/05/21 06:23 PM
Suffolk, England
John V6 Offline OP
John V6  Offline OP
Suffolk, England
And maybe new decals on the calipers? Or maybe you need slightly different pipes
Re: Brake squeal fix [Re: John V6] #705462
02/06/21 07:59 AM
02/06/21 07:59 AM
tervuren belgium
thierry242 Offline
thierry242  Offline
tervuren belgium
Dont know if it's due to the kit but two times my brake pedal went to the bottom just after starting up the engine
Re: Brake squeal fix [Re: John V6] #705463
02/06/21 08:01 AM
02/06/21 08:01 AM
Suffolk, England
John V6 Offline OP
John V6  Offline OP
Suffolk, England
I think I would be calling the dealer ASAP.
Re: Brake squeal fix [Re: John V6] #705495
02/06/21 02:35 PM
02/06/21 02:35 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
If the calipers are turned upside down, and the bleed nipples are then at the bottom, bleeding becomes harder.
But if the pedal drops on starting the engine, it also suggests the servo is causing that effect. Maybe some air still in the system.
Whatever is going on, it needs looking at.
Re: Brake squeal fix [Re: John V6] #705497
02/06/21 02:47 PM
02/06/21 02:47 PM
Staffordshire
IvorMog Offline
IvorMog  Offline
Staffordshire
But I wonder if the kit adapts the calliper so that the bleed nipple is on the top?
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Re: Brake squeal fix [Re: John V6] #705508
02/06/21 04:06 PM
02/06/21 04:06 PM
tervuren belgium
thierry242 Offline
thierry242  Offline
tervuren belgium
I have found it occurs only when the wheel is turned at the maximum at slow speed ( 1gear).
Same max left or max right.it was not there before the correction for the squeal.
Tomorrow the garage will check with a plus four with the modification. If i release the wheel
A little the brakes come back.
Re: Brake squeal fix [Re: John V6] #705509
02/06/21 04:12 PM
02/06/21 04:12 PM
Suffolk, England
John V6 Offline OP
John V6  Offline OP
Suffolk, England
It could be I guess a trapped pipe on full lock.
Re: Brake squeal fix [Re: IvorMog] #705541
02/06/21 09:06 PM
02/06/21 09:06 PM
RichardV6 Offline
RichardV6  Offline
Depends on caliper design but it's sometimes possible to swap the balance pipe between caliper halves and bleed nipples end to end as threads are usually the same.
Re: Brake squeal fix [Re: John V6] #707112
17/06/21 11:46 AM
17/06/21 11:46 AM
tervuren belgium
thierry242 Offline
thierry242  Offline
tervuren belgium
The top of a bolt fixing the lower suspension arm was hitting the brake calliper when the wheel was at the maximum.
As it is a floating brake the part moved a little and the brake pads where not in contact with the disk.
The same bolt has been reversed to avoid contact and now it is ok.
Re: Brake squeal fix [Re: John V6] #707113
17/06/21 12:01 PM
17/06/21 12:01 PM
Northern Germany
numog Offline
numog  Offline
Northern Germany
doh ...but good they found the fault in the end! thumbs
drive 2015 Roadster 3.7
