1 registered members (Bitsobrits), 99 guests, and 20 spiders.
+8Rich 393
John V6 191
TBM 134
CooperMan 117
Hamwich 103
Bill Box, John H, Colin McFadden, N2S3, Davetherave
7656 Registered Users
2016 Roadster. Head light questions
by Davetherave. 24/09/21 05:21 PM
Front steering geometry
by PaulJ. 24/09/21 02:47 PM
Footwell light cover
by Alan Patterson. 24/09/21 01:22 PM
M3W interest..?
by Luddite. 24/09/21 12:57 PM
Mike Duncan
by john humphreys. 24/09/21 08:36 AM
“The Very Last of the M3W”
by IMHO. 23/09/21 09:03 PM
Unknown badge.
by Grumpy2. 23/09/21 07:23 PM
Reinforced battery cradle for 2015 4/4
And for my next trick...
Guernsey Escape
Another Bride, Another Vroom
Madeira
Topics42,108
Posts705,984
Members7,656
Most Online1,033
Dec 28th, 2019
chocadoodledoo, Phil C
Clunking from rear wheel #707363
20/06/21 01:38 PM
20/06/21 01:38 PM
Cheshire
Fus969 Offline OP
Fus969  Offline OP
Cheshire
Hi my 97 +8 has a clunking sound when I roll it forward or backwards sounds like it’s off side rear wheel, had the brakes done recently unrelated to this issue that made no difference so I’m thinking maybe bearings? It happens whether it been stood or just back from a spin and more notable on full lock . Any suggestions would be appreciated
Re: Clunking from rear wheel [Re: Fus969] #707365
20/06/21 01:47 PM
20/06/21 01:47 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
If you have wire wheels, make sure the centrelock nuts are tight.
Sometimes the LSD can click, which resonates through the spokes, and is more obvious on lock.
When was the diff oil last changed? You need an oil with friction modifier...... Friction modifier makes the fluid "slicker" so without the additive the limited slip clutches will grab and it will shudder going around tight turns.
Re: Clunking from rear wheel [Re: Fus969] #707369
20/06/21 01:51 PM
20/06/21 01:51 PM
Suffolk
John V6 Offline
Brooklands Register contact
John V6  Offline
Suffolk
Have the UJs on the drive shaft been greased.
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Clunking from rear wheel [Re: Fus969] #707403
20/06/21 06:20 PM
20/06/21 06:20 PM
Cheshire
Fus969 Offline OP
Fus969  Offline OP
Cheshire
The car was serviced in December at Oakmere and I asked them to check all the fluids and grease points that was 200 miles ago .I may have to get under it and check all was done . Wasn’t to impressed with them the car had no oil leaks before service now I have two ! Very minor but there
Re: Clunking from rear wheel [Re: Fus969] #707404
20/06/21 06:20 PM
20/06/21 06:20 PM
Northern Capital of Cool
CooperMan Offline
CooperMan  Offline
My money's on Dave W's comment re the LSD, it needs an oil change
Re: Clunking from rear wheel [Re: CooperMan] #707407
20/06/21 06:35 PM
20/06/21 06:35 PM
Cotswolds
Treesurveyor Offline
Cotswolds
+2 for the diff oil change, and thanks for the reminder, mines due. I also have light intermittent clunk on takeup.
Syntrans is pretty much all in with FM additive
https://www.eurocarparts.com/search...Yg8q2TMGP2GuiQiK4Bm1XJN36VRoCsR4QAvD_BwE, available from other outlets.
I'm using MTF94 which I buy in 5l, with redline FM, but I'm likely changing diff oil every 18 months or so.
https://www.googleadservices.com/pa...bxAhXRfMAKHfxnAL8Qwg96BAgBEBc&adurl=
It's worth doing the gearbox at the same time, unless it was changed at last service/<25k miles.
06 Saab 93
Re: Clunking from rear wheel [Re: Fus969] #707408
20/06/21 06:37 PM
20/06/21 06:37 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
Worth checking the U bolts on axle too.
Regards Richard
1994 Connaught Green +8 prev
Re: Clunking from rear wheel [Re: Fus969] #707410
20/06/21 06:41 PM
20/06/21 06:41 PM
Cotswolds
Cotswolds
quote=+8Rich]Worth checking the U bolts on axle too.[/quote]
Good point Richard, added to my checklist thumbs
06 Saab 93
Re: Clunking from rear wheel [Re: Treesurveyor] #707411
20/06/21 06:47 PM
20/06/21 06:47 PM
Cotswolds
Cotswolds
These fluids are for the BTR axles, Salisbury are different.- see below from GOMOG site
The recommended oil for a LSD Salisbury (Plus 8s & 7HA and 12HA) is a 80/90 Hypoy oil for limited slip differential (LSD) axles (for example;
1. Castrol Hypoy LS90
2. Mobilube Mineral LSD 80/90
3. Royal Purple 80/90 LSD
4. Valvoline
5. Mobil 75/90
Capacity
4/4s Imperial Pints 1.3-1.4 liters Castrol SMX
Plus 4s 2.5 Imperial Pints 1.3-1.4 liters Castrol SMX
Plus 8s 2.5 Imperial Pints 1.3-1.4 liters Castrol Hypoy LS
The recommended oil for a non-LSD Salisbury (4/4s and Plus 4s) is now Castrol 75/90 or its equivalent. Salisbury axle fluid should be ideally changed at 3000 miles intervals. One cannot exaggerate the need to be careful. Never mix old and new oils. Some of the newer dealers suggest what they believe to be modern synthetic equivalents. However, the Salisbury's are not noted for strength and parts are no longer made. A chipped Crown Wheel and/or Pinion will and has sidelined many Salisbury Morgans indefinitely, though they can be had with GREAT DIFFICULTY. As Salisbury's original recommendation has worked for 60 years, there is no logic in taking risks. A BTR can be fit, but MMC waiting times run into many months for a BTR and it is no longer known whether Classic Morgans will be supplied since these models have been abandonned. The cost of the axle and labor to remove the hubs, swap and weld the brackets and install a new BTR will cost £4000...unless the work is done by the owner and he is VERY lucky in their part sourcing.
06 Saab 93
Re: Clunking from rear wheel [Re: Fus969] #707418
20/06/21 07:17 PM
20/06/21 07:17 PM
Arwyn Williams Offline
Salisbury's are not noted for their strength? Oh really?
Never had a problem with Salisbury axle at all!!
Did a rebuild on a 7HA in a sprint/hillclimb car over Christmas, one that had done 175,000 miles, replacement engine but still the same axle! Speed Mog championship winning car too!
Arwyn
