9 registered members (RB1, John V6, dmh, +8Rich, petebishop, M3W55, Arwyn Williams, rcmatt, Dougie), 71 guests, and 39 spiders.
+8Rich 149
John V6 140
OZ 4/4 122
Alistair 104
05 Roadster, John Tromans, Factotum, Dave Jones, Fester
8159 Registered Users
Spark Plug Wires
by PaulyG. 09/12/22 04:47 PM
Jet Black
by lowebird. 09/12/22 03:01 PM
It is crowded up there
by John V6. 09/12/22 01:52 PM
Autocar YouTube
by ProfessorM. 09/12/22 01:43 PM
M3W oil pressure switch
by planenut. 09/12/22 12:02 PM
Shed Racing vid
by Luddite. 08/12/22 04:23 PM
New Morgan Pedal Car - Kettcar
by flyfisher. 08/12/22 03:42 PM
Cover Girl_MOG414
Under the clouds....
Ms Marple's island/s connection...
Autumn Sunshine
Back Onshore
Topics44,401
Posts750,315
Members8,159
Most Online1,033
Dec 28th, 2019
silverbullet, Vianney Colombo
Inconsistent Starting Issue #710995
22/07/21 06:29 PM
22/07/21 06:29 PM
BearDee Offline OP
BearDee  Offline OP
I have an inconsistent starting problem with my M3W. When cold, starts ok, usually after the second or third hit of the starter button.
But after driving normally for more than 20 minutes, if I stop and turn the car off, It struggles to start again easily & in some cases taking 10 attempts.
The problem started when I changed over the old fuel pump for a new Walbro fuel pump and I'm wondering if there is anything obvious that I'm missing. My initial thoughts are that the engine is running rich, hence the problem of starting after a run. To be clear, it always starts and I've never been stranded but it is annoying, being inconsistent is the issue. My main concern is stalling it pulling out of a junction, I'd struggle to start quickly.
I have a good local mechanic who is keen to solve the problem so any pointers I can supply him through this wonderful forum would be greatly appreciated.
Thanks
Re: Inconsistent Starting Issue [Re: BearDee] #711008
22/07/21 07:41 PM
22/07/21 07:41 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
After replacing the fuel pump did you put Protune 2 on the ECU and clear the adaptive maps? The original pump may well have been operating at less than a regulated 58 psi for some time and the adaptive maps will....adapt. With the new pump you should be operating at a steady regulated 58 psi (check this at the Schrader test point on the RH injector body) but the adaptive maps will be still working for a lower delivery pressure maybe? It's a good idea to "zero" the ECU after the fuel pump change anyway.
As the problem has only started since the fuel pump change, it is logical to think it is related to that but it will still be sensible to check all the other things like plugs and leads, you never can tell with a M3W. I assume you don't touch the throttle pedal when cranking? It's a bad idea as the ECU zeros the throttle position every time the ignition is turned on and gets a false figure if you touch it.
Re: Inconsistent Starting Issue [Re: planenut] #711015
22/07/21 07:59 PM
22/07/21 07:59 PM
BearDee Offline OP
BearDee  Offline OP
Thanks Planenut
I have double checked all the leads & I never touch the throttle when starting as I know that it Zero's the ECU.
This is great advise and if you expand on how I zero the ECU, that would be helpful
Very much appreciated
Re: Inconsistent Starting Issue [Re: BearDee] #711019
22/07/21 08:24 PM
22/07/21 08:24 PM
Las Vegas
JohnMat Offline
JohnMat  Offline
Las Vegas
I believe they are reset if you disconnect the battery for a few minutes. It is an easy experiment to try.
2020 M3W
Re: Inconsistent Starting Issue [Re: BearDee] #711028
22/07/21 09:52 PM
22/07/21 09:52 PM
planenut Offline
planenut  Offline
As JohnMat says, disconnect the battery for half an hour or so and it should clear the ECU. The best way to be sure the adaptive maps are cleared is is to download Protune 2 from the S&S website https://www.sscycle.com/racing/support , make sure you download Protune 2, not Easimap. You will need a Windows laptop for this and a Mobile phone type lead to connect to the ECU, the socket is under the small plate with two Allen screws. With a locked ECU there is very little chance of you doing anything critical. There is a "Reset Adaptive Maps" selection in the Options menu. You can also read the fault codes, that may give an indication of any other issues. A full set of Protune 2 instructions are on the S&S website.
Re: Inconsistent Starting Issue [Re: planenut] #711031
22/07/21 10:44 PM
22/07/21 10:44 PM
BearDee Offline OP
BearDee  Offline OP
Very much appreciated & understood planenut
Thank you
Re: Inconsistent Starting Issue [Re: JohnMat] #711032
22/07/21 10:46 PM
22/07/21 10:46 PM
BearDee Offline OP
BearDee  Offline OP
John, thank you for the advice - appreciated
Re: Inconsistent Starting Issue [Re: BearDee] #711064
23/07/21 11:22 AM
23/07/21 11:22 AM
BearDee Offline OP
BearDee  Offline OP
Seems to of worked
Will test drive today - Thanks again
Craig
Re: Inconsistent Starting Issue [Re: BearDee] #711076
23/07/21 02:27 PM
23/07/21 02:27 PM
BearDee Offline OP
BearDee  Offline OP
Take the last reply back.
The issue remains the same. I will Download Protune 2 and clear the maps next
Thanks
Re: Inconsistent Starting Issue [Re: BearDee] #711088
23/07/21 03:51 PM
23/07/21 03:51 PM
France
Black Adder Offline
Toys for Boys
Black Adder  Offline
Toys for Boys
France
It might be worth trying the S&S 106-0744 Crank Position Sensor, not a cheap part but has been known to degrade and cause this type of inconsistent error.
Omne trium perfectum
