1 registered members (Bitsobrits), 99 guests, and 20 spiders.
+8Rich 393
John V6 191
TBM 134
CooperMan 117
Hamwich 103
Bill Box, John H, Colin McFadden, N2S3, Davetherave
7656 Registered Users
2016 Roadster. Head light questions
by Davetherave. 24/09/21 05:21 PM
Front steering geometry
by PaulJ. 24/09/21 02:47 PM
Footwell light cover
by Alan Patterson. 24/09/21 01:22 PM
M3W interest..?
by Luddite. 24/09/21 12:57 PM
Mike Duncan
by john humphreys. 24/09/21 08:36 AM
“The Very Last of the M3W”
by IMHO. 23/09/21 09:03 PM
Unknown badge.
by Grumpy2. 23/09/21 07:23 PM
Reinforced battery cradle for 2015 4/4
And for my next trick...
Guernsey Escape
Another Bride, Another Vroom
Madeira
Topics42,108
Posts705,984
Members7,656
Most Online1,033
Dec 28th, 2019
chocadoodledoo, Phil C
ENGINE LIGHT EASY FIX #712119
30/07/21 04:55 PM
30/07/21 04:55 PM
Andalucia
Ralph Offline OP
Ralph  Offline OP
Andalucia
Hello all. I have found a quick fix for the intermittent engine light issue. Mine came on just after buying my M3W. Worried me until I remembered my Ducati days and listened to the engine. No oil light. Have oil pressure. Engine sweet ? Yes. So don't worry. Later came to this site at a service station. Read every thing. Not satisfied so had a good hard think. Was sure that the ECU was getting confused and not adapting. Why ? probably an odd electrical input. Loose HT cap ? No. Checked aluminum nipples on plug tops. Both slightly loose. No pliers. Borrowed some. Started engine. NO LIGHT hooray. 30KM later light on again. Stop. Left plug nipple moving again. Tightened up and all good. When ever the light came on again I always found some slack . The problem is that the steel thread and Ally nipple expand and contract at different rates. This is perfect for unscrewing things. When home a brutal tightening has eradicated the issue. The tiny sparks jumping when the nipples can move, even a tiny bit puts a back emf into the ECU and it cannot adapt to the changes and puts the light on. You can have a situation where on a cold day or short run all is well. A long run may loosen the nipples and then a cool off overnight can tighten them. Try this FIRST before paying a dealer. They probably won't find this fault because the nipples tighten overnight. Hope this helps before expensive checking and ECU changes.
Re: ENGINE LIGHT EASY FIX [Re: Ralph] #712129
30/07/21 05:36 PM
30/07/21 05:36 PM
Leicestershire, UK
Bunny Offline
Bunny  Offline
Leicestershire, UK
Most, if not all M3Ws suffer from this, although on mine it just manifested itself by causing rough engine running and I didn't get a warning light. A dab of Locktite on the plug caps solves the problem for good. Or, at least until you replace the plugs.
Andy
Re: ENGINE LIGHT EASY FIX [Re: Ralph] #712152
30/07/21 07:23 PM
30/07/21 07:23 PM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
Be aware certain Locktite products are conductive , some are not.
I stayed with the brutal tightening approach when i had this issue , just in case.
