10 registered members (TBM, HJF, MOG1992, Image, thelastgizmo, mph, waikiore, BLUE+4, sprinty, John V6), 70 guests, and 19 spiders.
+8Rich 410
John V6 190
TBM 116
CooperMan 115
Bill Box, John H, Colin McFadden, N2S3, Davetherave
7656 Registered Users
Boshly sighting
by A11OGE. 20/09/21 10:56 AM
Vintage pressed metal silver on black plates
by Lindo. 20/09/21 08:22 AM
aero 8 series 4 radio problems
by Simon m wright. 19/09/21 07:52 PM
Suddenly the S&S doesnt seem so big...
by PaulV. 19/09/21 06:35 PM
Farewell Boycie
by +8Rich. 19/09/21 05:24 PM
Steering rack
by Drillrep. 19/09/21 07:59 AM
Merlin Music
by IvorMog. 18/09/21 07:45 PM
Guernsey Escape
Another Bride, Another Vroom
Madeira
SPRING PRESERVATION
West Highland Wandering 2003
Topics42,087
Posts705,508
Members7,656
Most Online1,033
Dec 28th, 2019
Fuel.inj
+8 breakdown #712230
31/07/21 02:19 PM
31/07/21 02:19 PM
Burgundy, France
Mick Annick Offline OP
Burgundy, France
I need some help please, diagnostics is not my thing, particularly sparky stuff.
Car is a 2000 3.9 +8 14CUX, out for a ride yesterday and the engine just cut out - no warning, spluttering or anything - so we ground to a halt. Engine spins over on the starter fine. Got recovered to home so now need to find the problem, I’ve had the fuel delivery pipe off at the engine end and the pump is working fine, so we have fuel as far as there, so I suspect something electrical.
I serviced the car about 1,000 miles ago and replaced at the time plugs, leads, coil, ignition module and all the relays - I’ve just swapped the ignition module again as the new one I fitted was from the prince of darkness, and pulled and refitted all connectors.
What should I be checking next please?
Mike H
2000 Plus 8
Re: +8 breakdown [Re: Mick Annick] #712239
31/07/21 03:12 PM
31/07/21 03:12 PM
Buckinghamshire
lumpy Offline
lumpy  Offline
Buckinghamshire
Check the earth connections on the amplifier, and coil are clean, I had similar experience recently and ended up replacing the spade connectors which were really dirty. It's a very easy job, given that your coil is new its likely to be the connectors on the loom.
Silver Morgan +8 " The Duchess"
'69 Triumph Bonneville
Life is a journey, best traveled in a Morgan
Re: +8 breakdown [Re: Mick Annick] #712240
31/07/21 03:18 PM
31/07/21 03:18 PM
North Yorkshire
V
vbalddave Offline
vbalddave  Offline
V
North Yorkshire
Hi Mike,
I feel your pain - I have had a horrible season of (not) sprinting and hillclimbing this year as a result of very similar problems.
At one point I replaced the injection relays with the correct new Bosch items (0986AH0602), and one of the new relays was faulty. Whilst it allowed the car to start, the minute it got hot and the ignition was turned off, the car would then not run until everything cooled down. Talking with Techniques' Brian Gateson, he indicated that he has had many duff (new out of the box) Bosch relays, and had experienced very similar problems.
It would be worth pulling a plug lead, popping a spare plug into it, grounding it and seeing whether you are getting a spark when the engine turns over. Assuming that you have a spark at the plug, I'd suggest swapping the injection relays back for your originals, or put new ones in again, and seeing whether that works. I was guided to buy some noid lights (I got Draper ones for £15 from Demon Tweeks); basically, by removing the electrical feed at one of the injectors, and plugging in the light to the connector, you can check whether a signal is getting to the injectors or not. In my case it was clearly not, and replacing the defective relay sorted it out.
There are a lot of supportive people on TalkMorgan with a very detailed knowledge of +8 electrics of our vintage, and I'm sure that some will be along soon to proffer help. I'm definitely NOT one of those knowledgeable people, but I have learned a little going through my troubles. Those more knowledgeable folks may well suggest some simpler/more elegant analysis paths than mine.....
Good luck, and please let us know how you get on.
Dave
vbalddave
Red 1993 +8 3.9
North Yorkshire
Re: +8 breakdown [Re: Mick Annick] #712243
31/07/21 03:33 PM
31/07/21 03:33 PM
Burgundy, France
Burgundy, France
After a process of elimination it appears the new coil has died - I’ve put the old back on and it fired up straight away - now to look back and see where \I bought it and try and get it replaced.
Thanks for the advice given!
Mike H
2000 Plus 8
Re: +8 breakdown [Re: Mick Annick] #712249
31/07/21 04:37 PM
31/07/21 04:37 PM
North Yorkshire
V
vbalddave Offline
vbalddave  Offline
V
North Yorkshire
Mike,
Great that you got there with it.
Failure of a new coil was one of my many issues, too.....still waiting for Rimmer Bros to sort out the warranty claim.
Dave
vbalddave
Red 1993 +8 3.9
North Yorkshire
Re: +8 breakdown [Re: vbalddave] #712257
31/07/21 05:24 PM
31/07/21 05:24 PM
Burgundy, France
Burgundy, France
Originally Posted by vbalddave
Mike,
Dave
Thanks Dave, I’ve just emailed RPI V8 about mine, let’s see…
Regards
Mike
Mike H
2000 Plus 8
Re: +8 breakdown [Re: Mick Annick] #712289
31/07/21 08:44 PM
31/07/21 08:44 PM
Derby
PhilRoyle Offline
PhilRoyle  Offline
Derby
Glad you sorted it - I was going to suggest fuel cut off switch if you had just hit a pothole.
Re: +8 breakdown [Re: PhilRoyle] #712303
31/07/21 10:28 PM
31/07/21 10:28 PM
Burgundy, France
Burgundy, France
Phil
We don’t have potholes in France smile
Mike H
2000 Plus 8
Re: +8 breakdown [Re: Mick Annick] #712334
01/08/21 09:32 AM
01/08/21 09:32 AM
London
MOG 615 Offline
MOG 615  Offline
London
Phil
You don't drive much in the Pas de Calais area Mick??
Andy G
1999 +8 , Indigo Blue.
Re: +8 breakdown [Re: MOG 615] #712368
01/08/21 12:00 PM
01/08/21 12:00 PM
Burgundy, France
Burgundy, France
Phil
Hi Andy
No, I stick to Bourgogne, we have roving pothole repair teams - rare for one to go unfixed for more that a week!
Mike H
2000 Plus 8
