10 registered members (jimmyw, Treesurveyor, MATTMOG, Gordon D, SimonH, Socalm3w, JB62, Gilberto, Bunny, PaulV), 420 guests, and 19 spiders.
+8Rich 188
John V6 158
TBM 83
Peter J 82
Tont, Norfolk Mog, Moggie31, Upton O'Good, BlueMorgan
7754 Registered Users
Battery Disconnection
by Topline123. 03/12/21 08:36 AM
Combat stress calendar
by Gordon D. 02/12/21 06:24 PM
Ideas around the new threewheeler
by xc68anc. 02/12/21 01:53 PM
Leaking brake fluid
by M3W Glasgow. 01/12/21 06:26 PM
What is the 3W's actual turning radius?
by MichaelS. 01/12/21 05:52 PM
Brake Rotors
by PaulyG. 01/12/21 01:26 PM
Morgan Grand Prix 1917 Replica-Progress-12/02/21
Plus 8
November in the New Forest
Shuttleworth Collection
Getting Comfortable
Topics42,476
Posts713,179
Members7,754
Most Online1,033
Dec 28th, 2019
Toi
Re: GPS Satellite Navigation mounting [Re: Themorganeer] #651693
21/07/20 07:43 AM
21/07/20 07:43 AM
Staffordshire
IvorMog Offline
IvorMog  Offline
Staffordshire
Originally Posted by Themorganeer
Pic of my dashboard. Garmin's suction devise works well so long as the dash is degreased first. Cable ties used behind the satnav on each side. [Linked Image]
I use a similar mount to this on my TomTom but I was also thinking along the lines of something that hooks over the tonneau peg so I might give Williams a call and see where their development is up to.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Re: GPS Satellite Navigation mounting [Re: jeepy] #651743
21/07/20 12:32 PM
21/07/20 12:32 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
The simplest way of achieving what you are looking for is to buy an aluminium tax disc holder (the ones sold for motorcycles). Bend it through 90 degrees over a broom handle and fit a lift-the-dot fastener in the small hole. A leather pad on the back will protect the car upholstery. You can buy self adhesive sat-nav mounting discs quite cheaply if the surface you end up with doesn’t suit your device. I cannot upload a picture as I have given my version of this away and moved on to a more refined mounting using a fixed mounting for the sat-nav. It still fits on the lift-the-dot peg for the tonneau cover.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: GPS Satellite Navigation mounting [Re: jeepy] #652142
23/07/20 10:59 AM
23/07/20 10:59 AM
PHZI Offline
PHZI  Offline
Sticky gel pad on the tunnel a couple of quid
£25 ear buds Amazon. Bluetooth to Google Maps on the phone. Gave up on the Garmin, too bulky in the Mog.
Re: GPS Satellite Navigation mounting [Re: jeepy] #715377
24/08/21 08:45 PM
24/08/21 08:45 PM
Colorado, USA
AncientMariner Offline
Colorado, USA
I once saw mention of a RAM ball with a stud that's the same thread as a dashboard screw. I looked around and the closest thing that I could find was a RAM 1" ball with a 1/4-20 female thread. That's close enough to the dash screw's M6-1.0 to be chased with a M6-1.0 tap and serve the purpose. Got a long-threaded M6 machine screw and with the head in a vise, screwed the freshly-tapped RAM ball firmly onto it. Sawed off the protruding stud to about the same length as the original dash screw and Bob's your uncle. The Garmin that I'm using doesn't have a 1" socket, so I found a 17mm ball adapter for the Garmin. It kept facing the floor until I treated the ball with some rosin that I had lying around for treating the strap on a strap wrench. That provided enough friction for the Garmin to stay pointed toward me.
Ball
double socket
ball adapter
I was afraid that the suction cup mount might eventually suck a bulge in the aluminum. With the above scheme, it's a simple matter to restore the original dash screw. Perhaps not the cheapest solution, but reasonable enough.
John, retired Marine Engineer
87 Morgan +8+, 12 Morgan 3W
Re: GPS Satellite Navigation mounting [Re: jeepy] #715420
25/08/21 07:56 AM
25/08/21 07:56 AM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
I just use a plastic disc fixed to the dash on the left hand corner with double sided tape. When not in use I add a black leather disc and its unobtrusive.
I also have a stainless pad designed to fit under the centre tonneau cover stud, which I've never used. Shed made but not by me.
Re: GPS Satellite Navigation mounting [Re: jeepy] #715632
26/08/21 04:26 PM
26/08/21 04:26 PM
Belgium Nivelles
Dada Offline
Dada  Offline
Belgium Nivelles
I made this for the Plus Six with 3D printing (white is prototype) it fix in the glovebox and I put a magnetic phone support on your it.
No hole in the dashboard, only 3 x 3mm quite invisible holes in the glovebox and the mount back plane is practically invisible.
If someone want the 3D file just ping me. (You can adjust the ball size but you have to print it with min 60% filling rate)
Dada
Re: GPS Satellite Navigation mounting [Re: jeepy] #715828
27/08/21 10:26 PM
27/08/21 10:26 PM
Perry_P_M3W Offline
Perry_P_M3W  Offline
I've used the suction cup method but I mounted it under the dash with a stick on disk for said cup. I then ordered a different elbow attachment for my Garmin which positioned it in a way that the top of the screen was just above the bottom of the dashboard itself. I personally enjoyed not having it block any of my windscreen tucked away. Happy to mount and post a pic if you wish.
Re: GPS Satellite Navigation mounting [Re: Perry_P_M3W] #715843
28/08/21 07:21 AM
28/08/21 07:21 AM
Surrey
Kevcaster Offline
Kevcaster  Offline
Surrey
Yes please
Kevin
2009 Morgan Plus 4 - 4 seater
2015 Subaru Forester 2.0ltr
Re: GPS Satellite Navigation mounting [Re: jeepy] #715855
28/08/21 08:36 AM
28/08/21 08:36 AM
North Yorks
John07 Offline
John07  Offline
North Yorks
Here's a pic of my latest mount. I remove the tonneau peg ( I don't use the t cover) and replace it with a 2BA * 1" grub screw. I then made the knurled nut and alloy bracket to hold the mount. The satnav does not intrude too far into the screen view and only covers the very tops of the small instruments. The rubber behind the mount stops it vibrating over the bumps in the road.
Cheers
Re: GPS Satellite Navigation mounting [Re: Perry_P_M3W] #715859
28/08/21 09:04 AM
28/08/21 09:04 AM
Essex
Burgundymog Offline
Black Rat
Burgundymog  Offline
Black Rat
Essex
I have done similar, works well and doesn't obstruct my view through the windscreen.
Keith
2013 narrow bodied + 4 Ruby.
