11 registered members (Image, HJF, MOG1992, thelastgizmo, mph, TBM, waikiore, BLUE+4, sprinty, John V6, Cumbriankeith), 65 guests, and 20 spiders.
+8Rich 410
John V6 190
TBM 116
CooperMan 115
Bill Box, John H, Colin McFadden, N2S3, Davetherave
7656 Registered Users
Boshly sighting
by A11OGE. 20/09/21 10:56 AM
Vintage pressed metal silver on black plates
by Lindo. 20/09/21 08:22 AM
aero 8 series 4 radio problems
by Simon m wright. 19/09/21 07:52 PM
Suddenly the S&S doesnt seem so big...
by PaulV. 19/09/21 06:35 PM
Farewell Boycie
by +8Rich. 19/09/21 05:24 PM
Steering rack
by Drillrep. 19/09/21 07:59 AM
Merlin Music
by IvorMog. 18/09/21 07:45 PM
Guernsey Escape
Another Bride, Another Vroom
Madeira
SPRING PRESERVATION
West Highland Wandering 2003
Topics42,087
Posts705,508
Members7,656
Most Online1,033
Dec 28th, 2019
Fuel.inj
Gear Shift Rattle #717993
14/09/21 11:47 AM
14/09/21 11:47 AM
Gwyn D Offline OP
Gwyn D  Offline OP
Hi all…
Looking for some advice if I may.
Our 1996 Morgan Plus 4 has developed a noticeable rattle of the gear shift in 3rd gear position.
It only occurs in 3rd gear, no other gear is affected (yet?).
It occurs from about 2500 to 3000 RPM, after which it clears.
The car has the 2ltr Rover T16 engine if that helps, and is fairly low mileage, circa 21k.
I’d be very grateful for any advice but particularly keen to hear from anyone who has had the same issue, and what you did to resolve.
Many thanks in anticipation.
Regards
Gwyn
Re: Gear Shift Rattle [Re: Gwyn D] #718001
14/09/21 12:22 PM
14/09/21 12:22 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
Which gearbox do you have?
Red Plus8
Re: Gear Shift Rattle [Re: Gwyn D] #718004
14/09/21 12:31 PM
14/09/21 12:31 PM
Essex
jbk Offline
jbk  Offline
Essex
Suggest the first thing to check is the rubber bushes on the remote, these are prone to perishing and even dropping off, happened on my 93 plus 4 with the LT77 box, the R380 has the same remote, may not be the gearbox itself hopefully. Also may not be mileage related, just ageing rubbber.
1993 T16 +4 Lancia Blue.
Re: Gear Shift Rattle [Re: Gwyn D] #718005
14/09/21 12:35 PM
14/09/21 12:35 PM
Essex
jbk Offline
jbk  Offline
Essex
Full instructions on Go Mog Btw....
Re: Gear Shift Rattle [Re: sospan] #718031
14/09/21 03:09 PM
14/09/21 03:09 PM
Gwyn D Offline OP
Gwyn D  Offline OP
It’s the Rover 5 speed box I believe…which is as much as I know I’m afraid 😳!
Re: Gear Shift Rattle [Re: Gwyn D] #718032
14/09/21 03:11 PM
14/09/21 03:11 PM
Gwyn D Offline OP
Gwyn D  Offline OP
@jbk…thanks for that. I’ll check Go Mog as you suggest.
Re: Gear Shift Rattle [Re: Gwyn D] #718048
14/09/21 05:00 PM
14/09/21 05:00 PM
Suffolk
John V6 Online content
Brooklands Register contact
John V6  Online Content
Suffolk
It is the little tang that holds the bowl over the spring on the gearshift breaking offer it is the bushes.all details are in gomog
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Gear Shift Rattle [Re: Gwyn D] #718052
14/09/21 05:41 PM
14/09/21 05:41 PM
Essex
jbk Offline
jbk  Offline
Essex
As John says, could be that, but as you need to take the seats and gearbox /propshaft cover off to investigate its worth replacing the 'rubber' bushes while you are there, its not a technically difficult job just a bit invasive and not something you want to do again so replace the bushes anyway, these are polyurethane and wont perish
https://www.ebay.co.uk/itm/233344985142?hash=item365471e836:g:H4IAAOSwy8Jcrz94
My bushes failure was extreme and caused the remote to drop and I had to hold it up to get home I was unable to select any gear but third.
You might want to check if the remote has any up and down play by lifting the gear knob.
Re: Gear Shift Rattle [Re: Gwyn D] #718060
14/09/21 07:33 PM
14/09/21 07:33 PM
Gwyn D Offline OP
Gwyn D  Offline OP
Thank you John, and thanks again jbk…really grateful for your advice. I think you’re right, I’ll certainly check / replace that tang and either way, the bushes. Thanks for the eBay link too, which I’ll take advantage of.
One last smidgen of information that I could have mentioned is that the gear shift ‘action’ has definitely changed - it hasn’t become sloppy and loose, it’s just become less defined if you can imagine what I mean, kind of harder to move and therefore more difficult to engage gear. I’ve never failed to find a gear though so not as extreme as your case jbk by the sound of it. .
Re: Gear Shift Rattle [Re: Gwyn D] #718065
14/09/21 07:58 PM
14/09/21 07:58 PM
UK
BuyBritish Offline
BuyBritish  Offline
UK
Its highly likely the cup over the gear lever see photos...
The repaired cup in place with additional fixing nuts
[Linked Image]IMG_1363 by Robert & Ali Davies, on Flickr
The cup repaired and before refitting
[Linked Image]IMG_1357 by Robert & Ali Davies, on Flickr
Rob Davies
Morgan 3 Wheeler 1934 MX
Morgan Series 1 1947
Morgan +4 1956 TR4
Morgan +4 2000 T16 Rov
