10 registered members (britmog, +8Rich, Player99, RJW, Image, Black Adder, The Austrian, Dave Collis, bmgermany, Gabriel), 66 guests, and 19 spiders.
John V6 232
+8Rich 224
TBM 114
DaveW 98
Mac M, aircool, AJ65, Newhorizon529, JP2996
7723 Registered Users
Interview with Jon Wells
by CooperMan. 26/10/21 07:59 AM
Handed drive change
by Scartans72nad. 25/10/21 11:46 PM
Talking of coolants
by IcePack. 25/10/21 09:12 PM
E405JUY where are you now ?
by Lordofthewings. 25/10/21 04:13 PM
Fractional Orbital Bombardment System
by +8Rich. 24/10/21 06:33 PM
For Sale - Vintage Leather Suitcases
by Mike Woodroffe. 24/10/21 10:40 AM
bump stops turned to powder
by craig from mich. 24/10/21 12:09 AM
Picked up our Morgan ARP4!
A Special Little Chip off the Laminate
Baa baa
Anglemog visit to Bentwaters
A Norwegian coastal scenery
Topics42,275
Posts709,422
Members7,723
Most Online1,033
Dec 28th, 2019
No Birthdays
Steering rack #718553
19/09/21 07:59 AM
19/09/21 07:59 AM
North West England
Drillrep Offline OP
Drillrep  Offline OP
North West England
Hi, I've ben a long time lurker here, and have enjoyed reading all the posts, I've had my Three-wheeler for a few years now, and recently i have noticed that my steering rack appears to be getting stiff, by that i mean after turning a corner the steering wheel does not come back to center, when its cold and for the first few miles its is almost normal, but as the engine warms it gets progressively worse, i can put it into a good corner and take my hands of the wheel and it will stay turned into the bend, i have to physically turn the wheel straight again. I'm assuming heat from the engine or bearings somewhere is causing it, has anyone experienced this. Thanks in Advance,
M3W Gulf Edition
Re: Steering rack [Re: Drillrep] #718555
19/09/21 08:21 AM
19/09/21 08:21 AM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Is steering stiff when the front is off the ground on axle stands?
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Steering rack [Re: Drillrep] #718560
19/09/21 09:13 AM
19/09/21 09:13 AM
North West England
Drillrep Offline OP
Drillrep  Offline OP
North West England
I haven't tried that yet, I'm abroad working at the moment, but when i get home i guess i could try it cold, then take for a drive and try again to see if there is a difference
M3W Gulf Edition
Re: Steering rack [Re: Drillrep] #718561
19/09/21 09:15 AM
19/09/21 09:15 AM
exagone
GLLOQ Offline
GLLOQ  Offline
exagone
The corrosion (rust) of the steering rack may be the cause, or the front axle lower ball joints worn.
Re: Steering rack [Re: Drillrep] #718565
19/09/21 10:14 AM
19/09/21 10:14 AM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
I had this after it was left overnight in the rain, there is a hole in the body of the steering rack close to the centre.
I believe it is used for steering alignment purposes.
To ease my stiff rack, with the front on axle stands, just dripped in some light oil into this hole and worked the steering back and forth, repeating on a few further days.
After a couple of trips it was back to normal.
From a tip from Phil Bleazey I fitted a section of slit plastic pipe over the rack so covering the hole.
No problems since.
Re: Steering rack [Re: nippymog] #718569
19/09/21 10:57 AM
19/09/21 10:57 AM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
No problems since.
Covering that hole sounds like a good thing to do. When i first spotted it i was wondering why it was left open to the elements.
Re: Steering rack [Re: GLLOQ] #718571
19/09/21 12:09 PM
19/09/21 12:09 PM
Oxon
PaulV Offline
PaulV  Offline
Oxon
Indeed if you check Phil Bleazey's post at Re:_Steering_rack_rainproofing it sounds like you may have fallen foul of Morgan's rack positioning (ie the hole letting water in...)
Last edited by PaulV; 19/09/21 12:11 PM. Reason: oops late reply - point already made
Re: Steering rack [Re: Drillrep] #718584
19/09/21 03:47 PM
19/09/21 03:47 PM
North West England
Drillrep Offline OP
Drillrep  Offline OP
North West England
Thanks for the replies, I'll be trying the oil in the rack when i get home, and post if it helps
M3W Gulf Edition
Re: Steering rack [Re: Drillrep] #719444
26/09/21 09:13 PM
26/09/21 09:13 PM
Gods own county! Oop north
Dab of oppo Offline
Dab of oppo  Offline
I put Millers EP140 in mine, same as the bevel box. Lock to lock smooth as silk.
Re: Steering rack [Re: Drillrep] #719653
28/09/21 04:48 PM
28/09/21 04:48 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
I have worked up a cover for the holes. I have not gotten the rack back into the car yet but this fits perfectly and would keep out all debri nd water from the rack. It clicks into place and is solid on the rack. You could get more cautious by adding band clamps, but as yet I am not sure the clearance in the vehicle.
I will try to add a video of it clicking into place.
