1 registered members (davewhite),
241
guests, and 24
spiders. |
Topics43,535
Posts732,587
Members8,015
Most Online1,033 Dec 28th, 2019
Steering rack
#718553
19/09/21 07:59 AM
19/09/21 07:59 AM
Posts: 3 North West England
Drillrep
North West England
Hi, I've ben a long time lurker here, and have enjoyed reading all the posts, I've had my Three-wheeler for a few years now, and recently i have noticed that my steering rack appears to be getting stiff, by that i mean after turning a corner the steering wheel does not come back to center, when its cold and for the first few miles its is almost normal, but as the engine warms it gets progressively worse, i can put it into a good corner and take my hands of the wheel and it will stay turned into the bend, i have to physically turn the wheel straight again. I'm assuming heat from the engine or bearings somewhere is causing it, has anyone experienced this. Thanks in Advance,
M3W Gulf Edition
Re: Steering rack
[Re: Drillrep]
#718555
19/09/21 08:21 AM
19/09/21 08:21 AM
Posts: 4,902 East Harling, Norfolk UK
Is steering stiff when the front is off the ground on axle stands?
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
Re: Steering rack
[Re: Drillrep]
#718560
19/09/21 09:13 AM
19/09/21 09:13 AM
Drillrep
North West England
I haven't tried that yet, I'm abroad working at the moment, but when i get home i guess i could try it cold, then take for a drive and try again to see if there is a difference
M3W Gulf Edition
Re: Steering rack
[Re: nippymog]
#718569
19/09/21 10:57 AM
19/09/21 10:57 AM
Posts: 3,622 Port Orchard, WA.
LightSpeed
Port Orchard, WA.
I had this after it was left overnight in the rain, there is a hole in the body of the steering rack close to the centre. I believe it is used for steering alignment purposes. To ease my stiff rack, with the front on axle stands, just dripped in some light oil into this hole and worked the steering back and forth, repeating on a few further days. After a couple of trips it was back to normal. From a tip from Phil Bleazey I fitted a section of slit plastic pipe over the rack so covering the hole. No problems since. Covering that hole sounds like a good thing to do. When i first spotted it i was wondering why it was left open to the elements.
Re: Steering rack
[Re: GLLOQ]
#718571
19/09/21 12:09 PM
19/09/21 12:09 PM
Posts: 1,440 Oxon
PaulV
Oxon
The corrosion (rust) of the steering rack may be the cause, or the front axle lower ball joints worn. Indeed if you check Phil Bleazey's post at Re:_Steering_rack_rainproofing it sounds like you may have fallen foul of Morgan's rack positioning (ie the hole letting water in...)
Last edited by PaulV; 19/09/21 12:11 PM. Reason: oops late reply - point already made
Re: Steering rack
[Re: Drillrep]
#718584
19/09/21 03:47 PM
19/09/21 03:47 PM
Drillrep
North West England
Thanks for the replies, I'll be trying the oil in the rack when i get home, and post if it helps
M3W Gulf Edition
