12 registered members (Cuna2016, HeadlessBlue, CooperMan, Bunny, Alistair, Player99, Craig Jezz, britmog, +8Rich, RJW, Image, Black Adder), 70 guests, and 19 spiders.
John V6 232
+8Rich 225
TBM 114
DaveW 98
Mac M, aircool, AJ65, Newhorizon529, JP2996
7723 Registered Users
Interview with Jon Wells
by CooperMan. 26/10/21 07:59 AM
Handed drive change
by Scartans72nad. 25/10/21 11:46 PM
Talking of coolants
by IcePack. 25/10/21 09:12 PM
E405JUY where are you now ?
by Lordofthewings. 25/10/21 04:13 PM
Fractional Orbital Bombardment System
by +8Rich. 24/10/21 06:33 PM
For Sale - Vintage Leather Suitcases
by Mike Woodroffe. 24/10/21 10:40 AM
bump stops turned to powder
by craig from mich. 24/10/21 12:09 AM
Picked up our Morgan ARP4!
A Special Little Chip off the Laminate
Baa baa
Anglemog visit to Bentwaters
A Norwegian coastal scenery
Topics42,275
Posts709,424
Members7,723
Most Online1,033
Dec 28th, 2019
No Birthdays
Brooklands steering wheel rattle #721341
12/10/21 10:49 PM
12/10/21 10:49 PM
Surrey UK
Malcolm M3W Offline OP
Surrey UK
My Brooklands steering wheel gets what I would call a harmonic rattle at about 2900 rpm on a balanced throttle. A finger pushed on the wheel centre stops it, but it is a medium hard push. Does anyone else get this and if so have you solved it?
My current action is putting layers of a fairly stiff foam down the wheel centre so that the column will push against the foam and stop the rattle from the rear. Building up the layers slowly and all the time ensuring the clip on action is not overridden for obvious safety reasons. Reduced the rattle but not fully solved. Its an annoying rattle compared to rest of the rattles and noises the car makes!
Re: Brooklands steering wheel rattle [Re: Malcolm M3W] #721344
12/10/21 11:39 PM
12/10/21 11:39 PM
Near Chicago, USA
HalfFull Offline
HalfFull  Offline
Near Chicago, USA
2 things to check:
- I once noticed the center bolts getting loose. Make sure those are tight.
- similar to your foam idea, I place a bit of masking tape (just enough) around the spindle and then mount the wheel. It acts as a slight buffer from rattles. Not too much, and it will tear easily if you take the wheel on and off frequently.
Aka Joejoe
Re: Brooklands steering wheel rattle [Re: Malcolm M3W] #721345
13/10/21 01:15 AM
13/10/21 01:15 AM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
"My current action is putting layers of a fairly stiff foam down the wheel centre.."
I posted some time ago on this forum about using a rubber bottle stop in a similar way. The rubber is about 1/16" longer than open area between the steering column and the back of my steering wheel. Works really well for me, though I don't have a Brooklands steering wheel. When the car is parked in the garage I pop the wheel loose to allow the rubber to 'recover' so as to keep it from taking a compression set.
Link to my previous posts:
http://www.talkmorgan.com/ubbthread...ck-release-steering-boss-part#Post650913
http://www.talkmorgan.com/ubbthread...ck-release-steering-boss-part#Post650938
Late 2012 M3W
Re: Brooklands steering wheel rattle [Re: Malcolm M3W] #721360
13/10/21 08:07 AM
13/10/21 08:07 AM
Surrey UK
Surrey UK
Thanks, so it looks like I am on the right track! I have other cars with QR wheels but this is the only rattle I have come across. However none of the other cars have a V twin!
Re: Brooklands steering wheel rattle [Re: HalfFull] #721374
13/10/21 09:29 AM
13/10/21 09:29 AM
Leicestershire, UK
Bunny Online content
Bunny  Online Content
Leicestershire, UK
+1
Andy
Re: Brooklands steering wheel rattle [Re: Malcolm M3W] #721423
13/10/21 03:55 PM
13/10/21 03:55 PM
Hampshire, UK
I
IMHO Offline
IMHO  Offline
I
Hampshire, UK
I’m usually gripping the wheel so tight that it doesn’t rattle, but my teeth do. I do like the look of my Brooklands wheel but having driven a friends M3W with a padded wheel, boy is the padded one a lot more comfortable to hold.
M3W Brooklands (2015)
Moody 41 (2013)
Re: Brooklands steering wheel rattle [Re: Malcolm M3W] #722211
21/10/21 08:58 PM
21/10/21 08:58 PM
Leicestershire
Farmer Giles Offline
Leicestershire
Off topic but sort of related . . . . . my Brooklands doesn't suffer from steering wheel rattle (yet) but at most rpm the off-side mirror vibrates to the extent that it becomes virtually useless. Usually the nearside mirror is unaffected and never are they both affected at the same time i.e. by the same revs. has anyone got a simple solution?
Johnny
Johnny Vans
Brooklands Edition M3W
1935 F2
2021 Mini Electric
Re: Brooklands steering wheel rattle [Re: Malcolm M3W] #722217
21/10/21 09:52 PM
21/10/21 09:52 PM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
Yes, put on mirrors with shorter stalks.
Late 2012 M3W
Re: Brooklands steering wheel rattle [Re: Malcolm M3W] #722247
22/10/21 08:31 AM
22/10/21 08:31 AM
Surrey UK
Surrey UK
My car has short stalk side mirrors which don't vibrate at all. But the downside is they have restricted vision as the occupants shoulders get in the way. Wondered whether a centre mirror has been used successfully by anyone?
Re: Brooklands steering wheel rattle [Re: Malcolm M3W] #722278
22/10/21 10:00 AM
22/10/21 10:00 AM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
A central mirror is a big help with rear vision I find. I have one fixed to the central support on my Fairbourne screen but there are ones on a stalk mount that work well with the small aero screens as well. Back on topic, I vote for the masking tape fix as well, it works for me.
